13
Well the bench is out......
eaglescout526 replied to 13 Legion's topic in Member Projects: Your Comanches
What?! I have never heard of them forcing you to sell it. You will be forced to get your vehicle repaired until it is fixed and can not be on the road until it is fixed after the third time but they don’t force you to sell it out of emissions zone. -
Have you tried Phoenix cylinder head? They are here local and they might have some heads in stock but may or may not be able to tell you if they have a 0331 head or not. I had my head rebuilt by them and they did a great job.
Clutch line quick connect/release
eaglescout526 replied to eaglescout526's topic in MJ Tech: Modification and Repairs
Alright well I’ve been searching for a few hours and I can’t seem to find the other end and a good chunk of mixed reviews of the quick connect. Guess I’ll just stick with the union fitting for now and tighten it some more. -
Has anyone ever used one of these? They come on every new slave cylinder and I have the old fashioned union fitting that I really am damn tired of using. If so does anyone have a link to what the quick connect that comes on our slave cylinders fit? I really don’t know what I’m looking for as this is new to me.
Will do! I just had the metal sleeves pressed out today so we will see what happens.
- 657 replies
- 2.5litre hurricane
- pioneer
(and 2 more)
Tagged with:
Well I got something done that has been needing to be done for over a decade: These look beautiful. The upholstery shop that I gave these to did a marvelous job. They basically made me new visors. And all this for 50 dollars. I am pleased Side note #1, The slave cylinder failed me today. Time to bring Little Red down and get to work.(Done. Started at 18:00 and finished before 22:30.) Side note #2, Snagged a take off set of JK suspension from work. I saw the write up for them and I'm gonna make free work for me.
- 657 replies
- pioneer
(and 2 more)
Tagged with:
That’s what Chrysler was putting them there for. Many people complained about pump noise in the cabin on the XJ and that was the remedy for it. It’s also a quick bypass, not really a way to disable the vehicle unless someone knows what they are looking at.
That’s the fuel ballast resistor. It’s there to quiet the amount of noise the fuel pump produces. Most everyone here bypasses it unless you want original looks to your truck
Did you steal that from Mitt Romney's family archive?
Looks like a parts basket-case
Another way to get a factory CPS
eaglescout526 replied to Strokermjcomanche's topic in MJ Tech: Modification and Repairs
It’s just a patch kit. Not the whole shabang. -
DIY Nameplate repaint/restore
eaglescout526 replied to eaglescout526's topic in MJ Tech: DIY Projects and Write-Ups
Lol. Just about everything I have painted and followed with clear coat is doing pretty well. The one that is the most noticeable is the upper trim above the grill. It’s holding pretty well. I use rustoleums automotive clear -
Dome Light Flip Fixtures 1991 Comanche
eaglescout526 replied to Lil' Nize's topic in MJ Tech: Modification and Repairs
You won’t have to entirely rewire. The original factory connectors come apart and you can use the connectors inside the plastic housing to connect to the terminals on the euramtec lights. But you’ll have to file or sand the B-pillar opening to fit the eurmatec lights. -
Go to a dealership. They are always chucking boxes of every size imaginable.
Chrysler doesn’t show it in their catalogues but my best guess is it looks like a kit that hard wires the CPS to the ECU. All Chrysler has it labeled as is “KIT” and it was only for the ‘87/88 model years. -
It’s very well possible that there could be a few more lingering. I know there’s another part number that does the same job as that kit so I wonder why Chrysler has two kits that do the same thing. 4443965 was the other kit and it’s priced at $66 with brig still around at other dealers. I think about 17 of those exist if I’m remembering correctly. -
It is hot wire switched with a ground wire going from the switch but that is only for the light on the switch itself. Behind the dash bezel should be 3(or 4) plugs where the fog light switch and other switches go, there should be a three prong switch like the fog light plug except it has pink wires. Pink plugs into a prong on the lens itself that sticks out and the ground is the two screws that attach and hold the light on to the roof. Since you have a ‘91 it very well may not be there. If you get a factory light, make sure you test it’s grounds first by using a 12v battery to make sure it works. It’s a lot easier to diagnose why it may not be working in the end if all the contacts are cleaned that way it can be narrowed down to the screws or the contact of the roof and screws.
That one was the one on eBay right? And what I mean is there is one dealer in the US that has that part left and Chrysler asks $156 which is incredibly laughable that they were asking for that for just two model years that the part is for when there is a cheaper kit from Chrysler. -
Hahahahahahahha. For $156 from Chrysler, I am not buying the last one in existence!
