13
Would you mind taking a look at your VIN again? Getting an invalid VIN error.
Lots of detergent on that carpet and let it soak in and then pressure wash it will yield some damn good results on that. Actually might be worth a try to clean it, I know I would try it.
*D1 TRIM STYLE D1 - CLOTH BENCH -H9 169 Zone 69-Phoenix 1AA U.S. Dealer Retail 5AL Low Series Tracking ADA Light Group APA Monotone Paint BAY 105 Amp Alternator BCY BATTERY, 58-475 CC BGA Power Front Disc/Rear Drum Brakes BJA STD DUTY FRT DISC BRAKES BKP 10x2.5 Rear Drum Brakes CBA Straight Back Bench Seat CKA Carpets - Floor and Cargo Area CSR Passenger Assist Handles DGB All 4-Speed Automatic Transmissions DGS 4-Speed Automatic AW4 Transmission DHA Lock-Up Torque Converter DHT Shift-on-the-Fly,P/Time T/Case DMD 3.55 Rear Axle Ratio DRK Dana 44/226MM Rear Axle DSA Anti-Spin Differential Rear Axle EAA All Engines EAF ALL FUEL INJECTED ENGINES-GAS ERB ENGINE - 4.0L I6 MPI GAS GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEC Front Left Side Sliding Window GNA Rear View Day/Night Mirror GNB Driver Side Illuminated Sun Visor GRV Left Manual Mirror GUA Open HAA Air Conditioning JAA Instrument Panel JAZ DO NOT USE - See JP, KA classes JBF Instrument Panel Black Bezel JCA 85 MPH Primary Speedometer JHA Var Intermittent Windshield Wipers JJA Cigar Lighter JKB Hood release K3Z STRIPE/BADGE/MOLDING/COLOR KWX DK QUARTZ - BADGE - "INTREPID" - DECKLID LAF Seat Belt Alert-Driver Seat only LAJ Headlamps On Warning Chimes LBB Courtesy Lamps LBC Glove Box Lamp LBD Ash Tray Lamp LBE IP LED Ambient Light Pipe LCJ DOME/READING LAMP B-PILLAR LDH U/Hood, Removable/Rechargeable Lamp LHD Headlamp Off Time Delay LMA Halogen Headlamps LPE Cargo Lamp MB1 Black Front Bumper MDA Front License Plate Bracket MFF Black Grille MHB Bright Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMJ DRIP TROUGH MLDG - TYPE I NAA Federal Emissions NBA LIGHT DUTY CYCLE NBK EVAP Control System NDA Catalytic Converter NF5 Fuel Tank - 23 Gallon PWB PEARL WHITE PRIMARY PAINT - HWB QWB PEARL WHITE SECONDARY PAINT - HWB RAA All Radio Equipped Vehicles RAC AM MTR Radio RCA SBA Power Steering SCB Steering Whl SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers SUA Tilt Steering Column TAA All Tires TAD HIGHWAY TREAD TBB Full Size Spare Tire TBM Tire Carrier Winch TNC P195/65R15 BSW AS Touring Tires WJK 15X6.0 Styled Steel Wheels WMC Bright Wheel Trim Rings XBS Pickup Box XFA -35F Protection Anti-Freeze YAA Build To U.S. Mkt. Specifications YEP Manuf Statement of Origin YGE 5 Additional Gallons of Gas Z01 Rear Spring Group I Z1A GVW/Payload Rating Z59 Left Front Spring Group Ix Z79 Right Front Spring Group IX Build date 4/2/89 Body code TL62
What Minuit knows about stock Jeep radios
eaglescout526 replied to Minuit's topic in MJ Tech: DIY Projects and Write-Ups
197? -
how to switch between the mobile and full versions of the CC site?
eaglescout526 replied to Pete M's topic in The Pub
I'll get the SE when my 6 dies. So far everything works as it should, I can actually view CC on my iPhone 5c with iOS10 with Safari. -
Do you mean with Safari or chrome on iPhone 6? Cause I'm still running the old pre-brick. -
I’ll take Pete’s hint. I’ll get some pics later if some of the other boxes I have at home but here’s the shipping labels and a set of speaker grills I got for another member(I think it was Wahoo) a while back.
Safari doesn't present an option to switch. As far as pics, it all depends on networks speeds, reception and wifi. I never have issues. -
Thats ok, i shipped a rear glass piece up to Chunk and it got there safely with the 20lbs of bubble wrap. But I'm just lookin out for a slider.
- 657 replies
- 2.5litre hurricane
- pioneer
(and 2 more)
Tagged with:
I think about every 5-6 XJ's, there was one MJ, granted I kinda goofed around and started at the earliest MJ VIN I could find and just went up in numbers and found more XJ's rolled off than MJ's and SJ's as they also shared the same VIN sequence. Now that was 86. We have seen that 87-89 was what looks like the highest volume production years so that could've easily changed to every 2 XJ's was an MJ behind it.
This is actually the only thing I do not like about it. You get four machined plates with thread sticking out and 3M adhesive tape on the other side of the plates. You stick the plates to the window(glass in my case because its not a factory window) and once theyre on there you thread on the plastic nuts you are given and its on there, it even survived some strong monsoon winds last night so a plus! I opted for the hinge package which you get two machined hinges that allow you to undo two nuts and just let it hinge down into the bed, but at that point you ought to just completely remove it if you go that route.
- 657 replies
- pioneer
(and 2 more)
Tagged with:
In the light: Looking out the rear view: Turning your head as far as you can: And taking a glance out the rear: All in all its got good visibility, keeps the cab cooler and keeps the sun from burning your neck. Honestly this thing would fit hell of a lot better on an OEM window which I do not have sadly(silently looking).
- 657 replies
- pioneer
(and 2 more)
Tagged with:
Applicable to horse shoes and hand grenades.
*X8 SEATS - CLOTH LOW-BACK BUCKET -YY APA MONOTONE PAINT PACKAGE CAC BUCKET SEAT - LO BK CGW CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ CUF FULL LENGTH FRONT CONSOLE DDJ 5SPD MANUAL TRANS A881 (JA-41) ERB ENGINE - 4.0L I6 MPI GAS GAC ALL WINDOWS - TINTED GLASS GTZ MIRRORS - MANUAL REMOTE HCC HEATER W/UPR LEVEL VENTIL - TYPE II JAY Instrument Cluster w/Tach JFH TACHOMETER - MECH JGB Clock - Digital KD8 STRIPE/BADGE/MOLDING/DELETE LAP FUEL ECONOMY SHIFT INDICATOR LIGHT LMA HALOGEN HEADLAMPS MDA FRT LICENSE PLATE ATTACH REQUIRED NAE EMISS CONTROL TESTING &&&&&&&& LABEL NMB ENGINE COOLING - STANDARD DUTY PX6 CLASSIC BLACK CLR CT PRIMARY PAINT - FX6 QX6 CLASSIC BLACK C CT SECONDARY PAINT - FX6 SBA POWER STEERING SCG LEATHER STRG WHEEL - EURO/SPORT TYPE TBG SPARE TIRE - COMPACT TBL TIRE CARRIER - INSIDE WMC BASE WHEEL DRESS - UP (INCLS TRIM RING) Build date 11/25/86 Body code TL61 @fiatslug87, Here ya go, another one made in November. Getting closer to seeing the picture of the puzzle.
Agreed.
The Astra-Hammond one with hinges, took about a month to get and my guess would be covid and it ships directly from supplier. Actually visibility at first is really weird but after a bit of driving with it on, you get used to it but it has good , not entirely obstructing, visibility. I would say you can see way more out of it than you can inside, like if your driving behind me, I can see you but I'm sure you couldn't see me sitting in the cab, I'll have to snap a pic of what I see in the seat in the rear view and turning my head. But overall well made plastic, helps keep the sun off your back and helps cool and protect the interior.
- 657 replies
- pioneer
(and 2 more)
Tagged with:
Ah, good ole snotsdale. @Pirate_Staz, is out there. He's selling his MJ soon but will hopefully have an MJ again.
Been a few weeks so here’s an update and an opinion. Opinion: the ZJ box was a damn good upgrade. My thoughts after a couple weeks. I’ve noticed less groaning from the steering but occasionally I’ll get a load pop and steering will go wonky. Probably something needs to be adjusted somewhere, not sure where though as the steering will pop on fast turns from time to time so it’s not easy to catch. But once it does this it will return to normal after a bit of driving and turning. Update. It’s been way too damn hot to do anything. No T-bird, no bumper, no nothin. I did add that rear window louvre and by golly that was hell of an upgrade. Significantly helps with cooling of the cab in these rough temps. Also since it’s been so damn hot the glue is failing on the headliner now but I’ll fix that and add insulation to the roof one day maybe soon like winter. Anyways here’s a pic of the louvre at night: I’ll have to get a good day pic. Really weird to drive with a dark cab.
- 657 replies
- pioneer
(and 2 more)
Tagged with:
*Q7 Cloth Low-Back Bucket Seats -SA CHARCOAL 172 Zone 72-Portland 1AA U.S. Dealer Retail 3V5 Customer Preferred Discount 4HC Special Scheduling Condition III ADA Light Group ALR APA Monotone Paint ARM Radio AM/FM Cassette BAF 130 Amp Alternator BCX Dual 700 Amp Maint. Free Batteries BGA Power Front Disc/Rear Drum Brakes CAC Bucket Seats CDB Reclining Front Seats CKA Carpets - Floor and Cargo Area CUF Full Length Floor Console DBB All Manual Transmissions DDQ 5-Speed Manual Transmission DMM 3.07 Rear Axle Ratio DRJ 175MM Rear Axle ERH 4.0L I6 Power Tech Engine GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEH Fixed Door Vent Glass GFD Rear Sliding Window GNC Sun Visors w/Illum Vanity Mirrors GRZ Left Remote Mirror GSZ Right Remote Control Mirror GTZ Manual Remote Mirrors HCD Do Not Use - See HCA JAY DO NOT USE - See JP, KA classes JCA 85 MPH Primary Speedometer JGB Digital Clock JHA Var Intermittent Windshield Wipers JJA Cigar Lighter K27 Do Not Use K2B STRIPE/BADGE/MOLDING/COLOR K3R STRIPE/BADGE/MOLDING/COLOR KLT KWD LAJ Headlamps On Warning Chimes LAP Shift Indicator Warning Lamp LBB Courtesy Lamps LBC Glove Box Lamp LBD Ash Tray Lamp LBE IP LED Ambient Light Pipe LDA Underhood Lamp LHD Headlamp Off Time Delay LMA Halogen Headlamps LNJ Front Fog Lamps MB1 Black Front Bumper MBJ Black Front Bumper MCA Front bumper pads MDA Front License Plate Bracket MFK Body Color Grille MHA Black Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMK Lower Grille Surround-Painted Silver NAA Federal Emissions NBK EVAP Control System NF2 18.5 Gallon Fuel Tank PE4 COLORADO RED CC PRI PNT - HE4 QE4 COLORADO RED CC SEC PNT - HE4 RAA All Radio Equipped Vehicles RAF AM/FM Cassette Radio RCD 4 Speakers SBA Power Steering SCG Leather Wrapped Steering Wheel SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers SUA Tilt Steering Column TBC Compact Spare Tire TBM Tire Carrier Winch TRM P225/75R16 BSW On/Off Road Tires TZA Goodyear Brand Tires WJH 15X7 Aluminum Wheels WLZ All Aluminum Wheels XBS Pickup Box YAA Build To U.S. Mkt. Specifications YGE 5 Additional Gallons of Gas Z01 Rear Spring Group I Z1A GVW/Payload Rating Z58 Left Front Spring Group Viii Z78 Right Front Spring Group VIII Build date 9/18/90 Body code TL61 This truck looks familiar.
89 2.5L cranks but no start
eaglescout526 replied to Myles Cyncora's topic in MJ Tech: Modification and Repairs
Theres a noid light kit you can get at your auto store to test the wiring and ECU. The injector is Ωhm tested with a voltmeter. If you remove the throttle body bonnet it will reveal the injector, there are two screws holding the injector retainer in place, remove those and the injector will pull straight out. CAUTION. When reinstalling the injector, do not overtighten the screws, they can break and are not replaceable. -
Phoenix huh? Awesome. Looks good and I’d like to see it in person sometime.
Outer door weatherstrip/trim - where to buy
eaglescout526 replied to JeepFanatik's topic in MJ Tech: Modification and Repairs
I believe the OP is referring to the outside door moldings and not the actual weather strips and pieces.
