13
*Q7 Cloth Low-Back Bucket Seats -SA Charcoal 133 Zone 33-Philadelphia 1AA U.S. Dealer Retail 5AS Dodge City Tracking 5KR Midland Corporation ADA Light Group ADB Protection Group ADH Heavy Duty Electrical Group AHL Heavy Duty Insulation Group ALR APA Monotone Paint BA1 100 AMP ALTERNATOR BCY BATTERY, 58-475 CC BGA Power Front Disc/Rear Drum Brakes BJA STD DUTY FRT DISC BRAKES BKP 10x2.5 Rear Drum Brakes CAC Low Back Bucket Seats CDB Reclining Front Seats CKA Carpets - Floor and Cargo Area CLA Front Floor Mats CSR Passenger Assist Handles CUF Full Length Floor Console DBB All Manual Transmissions DDX 5-Speed HD Manual Transmission DMM 3.07 Rear Axle Ratio DRJ 175MM Rear Axle EAA All Engines EAF ALL FUEL INJECTED ENGINES-GAS ERB ENGINE - 4.0L I6 MPI GAS GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEC Front Left Side Sliding Window GFD Rear Sliding Window GNA Rear View Day/Night Mirror GNB Driver Side Illuminated Sun Visor GRC Entire Fleet Key Alike (FREQ 7) GSC Right Black Mirror GTC Manual Mirrors HCD Do Not Use - See HCA HGA Hood Insulation JAA Instrument Panel JAY DO NOT USE - See JP, KA classes JBD BEZEL-I/PANEL CLUSTER - BRIGHT JCA 85 MPH Primary Speedometer JGB Digital Clock JHA Var Intermittent Windshield Wipers JJA Cigar Lighter JKB K2B STRIPE/BADGE/MOLDING/COLOR K3D STRIPE/BADGE/MOLDING/COLOR KLH LAF Seat Belt Alert-Driver Seat only LAJ Headlamps On Warning Chimes LAP Shift Indicator Warning Lamp LBB Courtesy Lamps LBC Glove Box Lamp LBD Ash Tray Lamp LBE IP LED Ambient Light Pipe LCJ DOME/READING LAMP B-PILLAR LDH U/Hood, Removable/Rechargeable Lamp LHD Headlamp Off Time Delay LMA Halogen Headlamps LNJ Front Fog Lamps LPE Cargo Lamp MB1 Black Front Bumper MBJ Black Front Bumper MCA Front Bumperettes MDA Front License Plate Bracket MFK Body Color Grille MHA Black Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMK Lower Grille Surround-Painted Silver MMP MOLDING - DOOR EDGE GUARDS NAA Federal Emissions NBA LIGHT DUTY CYCLE NBK EVAP Control System NDA Catalytic Converter NF2 18.5 Gallon Fuel Tank PS3 DOVER GREY MET CL CT PRIMARY PAINT - HS3 QS3 DOVER GREY MET C C SECONDARY PAINT - HS3 RAA All Radio Equipped Vehicles RAF AM/FM Cassette Radio RCD 4 Speakers SBA Power Steering SCG Leather Wrapped Steering Wheel SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers SUA Tilt Steering Column TAA All Tires TBB Full Size Spare Tire TBM Tire Carrier Winch TMR WJH 15X7 Aluminum Wheels XBS Pickup Box XFA -35F Protection Anti-Freeze YAA Build To U.S. Mkt. Specifications YGG 9 Additional Gallons of Gas Z01 Rear Spring Group I Z1A GVW/Payload Rating Z58 Left Front Spring Group Viii Z78 Right Front Spring Group VIII Build date 8/28/88 Body code TS61
The only difference is AC vs no AC. AMC and Mopar used the same box for the AC system from 84-96. Now the parts catalog says some part modification is required and that is true. I have a 92 air box in mine and I had to drill some holes for it to use and bolt the Renix thermistor. The heater core side remains unchanged for 84-96.
Trying to bleeding the clutch
eaglescout526 replied to blanzawa's topic in MJ Tech: Modification and Repairs
86 2.5L right? Should have the external slave set up. Even if it was internal slave, the best way to bleed the system is to open the bleeder and bleed it. -
Nothin, part removed from database and no one has it.
A New Guy that's gonna need a lot of help
eaglescout526 replied to jtm's topic in MJ Tech: Modification and Repairs
Short for distributor. Theres a lot of short names and abbreviations that you will catch on. I think theres even a post dedicated to such. -
Something told me to mention you, but I didn't. Lol. Does the instruction sheet have the switch plate part number on it? I'm not expecting any dealer t have it on a shelf but its worth a look.
I knew the keyless system sucks and honestly it would've been something id be willing to fight with as I grew up learning that you had to point the keys at the car to get the car to unlock. But knowing about the Camero is a gamechanger. As far as the Chrysler system, it almost sounds like any pre 96 Chrysler car with keyless should be avoided. The main goal for wanting a keyless entry was to use the OEM housing so I wouldn't have any more wires and boxes under the dash(like I have a lot of). But if you have no automatic trans, the lower dash panels on most 87-96 XJ's and MJ's have some studs where the TCU goes and you could easily bolt a keyless entry box there.
Whats bad is that switch plate part number is lost with time unless someone has a kit with the number on it.
Have you tested any of your EGR stuffs to see if its just being stuck open?
Oh damn you’re right Fiat! I have one good reflector from a Sears one and one decent one from the pair I have. That’s next to tackle on my list after the bumper.
"Put the wrangler on a 1500 frame" vs a cheap but well thought out uniframe design. What I don't get is why the JT has rear half doors when it has a full cab. I understand why, better to use an existing door than to make a new full door but then it just takes away the "uniqueness" the JT has.
OMG The Crewcab 6x6 Comanche
eaglescout526 replied to ThatJeepGuy's topic in Member Projects: Your Comanches
Actually on the facebook page of All things MJ, he is selling this project. -
Probably the best upgrade any 86 2.5L owner should do.
Engine shutdown? Electrical?
eaglescout526 replied to Wounded_Fighter's topic in MJ Tech: Modification and Repairs
2 MoPar reman 85 amp alts left for the 4.0L if thats a route you want to take. -
I saw this and thought the same exact thing.
235/75r15 is the highest you can go with stock height and rims.
*Q7 Cloth Low-Back Bucket Seats -SA Charcoal 174 Zone 74-Denver 1AA U.S. Dealer Retail 25H Customer Preferred Package 25H 2TH Customer Preferred Package 2TH 3VU Customer Preferred Discount 4HA Special Scheduling Condition I ADA Light Group ADH Heavy Duty Electrical Group ADL Skid Plate Group APA Monotone Paint ARM Radio AM/FM Cassette BAR 90 Amp Alternator BCD 500 Amp Maintenance Free Battery BGA Power Front Disc/Rear Drum Brakes CAC Low Back Bucket Seats CDB Reclining Front Seats CKA Carpets - Floor and Cargo Area CUF Full Length Floor Console DBB All Manual Transmissions DDQ 5-Speed Manual Transmission DHN Command-Trac Part Time 4WD System DJH 230MM Front Axle DMM 3.07 Rear Axle Ratio DRJ 175MM Rear Axle ERH 4.0L I6 Power Tech Engine GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEC Front Left Side Sliding Window GFD Rear Sliding Window GRZ Left Remote Mirror GSZ Right Remote Control Mirror GTZ Manual Remote Mirrors HAA Air Conditioning JAY DO NOT USE - See JP, KA classes JCA 85 MPH Primary Speedometer JHA Var Intermittent Windshield Wipers JJA Cigar Lighter K27 Do Not Use K2B STRIPE/BADGE/MOLDING/COLOR K3W STRIPE/BADGE/MOLDING/COLOR KLT KWD LAJ Headlamps On Warning Chimes LAP Shift Indicator Warning Lamp LBB Courtesy Lamps LBC Glove Box Lamp LBD Ash Tray Lamp LBE LDA Underhood Lamp LHD Headlamp Off Time Delay LMA Halogen Headlamps LNJ Front Fog Lamps MB1 Black Front Bumper MBJ Black Front Bumper MCA Front bumper bumperettes MDA Front License Plate Bracket MFK Body Color Grille MHA Black Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMK Lower Grille Surround-Painted Silver NAF High Altitude Emissions NBK EVAP Control System NF2 18.5 Gallon Fuel Tank NHM Speed Control PW7 Bright White Clear Coat QW7 Bright White Clear Coat RAA All Radio Equipped Vehicles RAF AM/FM Cassette Radio RCD 4 Speakers SBA Power Steering SCG Leather Wrapped Steering Wheel SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers SUA Tilt Steering Column TBB Full Size Spare Tire TBM Tire Carrier Winch TRN P225/75R15 OWL Wrangler AT Tires TZA Goodyear Brand Tires WJH 15X7 Aluminum Wheels WLZ All Aluminum Wheels XBS Pickup Box YAA Build To U.S. Mkt. Specifications YGE 5 Additional Gallons of Gas Z01 Rear Spring Group I Z5A GVW/Payload Rating Z66 Left Front Group XV Z82 Right Front Spring Group XI Build date 9/23/91 Body code JL61
Oh this dump is gonna be a good one. At least I think it should be.
Who knows, I was going off of what the book said, I should go back and reread what the symbol means for what the 1/4" is under. At least I thought it was diameter but I could be wrong. Happy to help though.
Horn is out of BEEP, where do I refill?
eaglescout526 replied to EdJarHead's topic in MJ Tech: Modification and Repairs
Lol, you don't want to know how much I spend on NOS stuff then. -
Sept 2nd. New dump.
PX6 CLASSIC BLACK CLR CT PRIMARY PAINT - FX6 QX6 CLASSIC BLACK C CT SECONDARY PAINT - FX6 SBA POWER STEERING WMC BASE WHEEL DRESS - UP (INCLS TRIM RING) Theres the paint code and WMC.
Thats a pretty low number for 87.
