eaglescout526
Administrators
    13
  1. I don't know much about Europe's automotive registration but this is an 80's truck we are talking about. Our across the pond members have had issues registering because of tail lights but back then the MJ tail lights didn't require the amber turn signal over there like they require it now. Just blame the U.S. for the red tail lamps.
  2. *D1 TRIM STYLE D1 - CLOTH BENCH -YY 169 Zone 69-Phoenix 1AA U.S. Dealer Retail 4HB Special Scheduling Condition II 5AL Low Series Tracking APA Monotone Paint BAY 105 Amp Alternator BCY BATTERY, 58-475 CC BGA Power Front Disc/Rear Drum Brakes BJA STD DUTY FRT DISC BRAKES BKP 10x2.5 Rear Drum Brakes CBA Straight Back Bench Seat CKA Carpets - Floor and Cargo Area CSR Passenger Assist Handles DGB All 4-Speed Automatic Transmissions DGS 4-Speed Automatic AW4 Transmission DHA Lock-Up Torque Converter DHT Shift-on-the-Fly,P/Time T/Case DMD 3.55 Rear Axle Ratio DRJ 175MM Rear Axle EAA All Engines EAF ALL FUEL INJECTED ENGINES-GAS ERB ENGINE - 4.0L I6 MPI GAS GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEH Fixed Door Vent Glass GNA Rear View Day/Night Mirror GRV Left Manual Mirror GUA Open HAA Air Conditioning JAA Instrument Panel JAZ DO NOT USE - See JP, KA classes JBF Instrument Panel Black Bezel JCA 85 MPH Primary Speedometer JKB K3Z STRIPE/BADGE/MOLDING/COLOR KDD LAF Seat Belt Alert-Driver Seat only LBC Glove Box Lamp LCJ DOME/READING LAMP B-PILLAR LMA Halogen Headlamps MB1 Black Front Bumper MDA Front License Plate Bracket MFF Black Grille MHB Bright Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMJ DRIP TROUGH MLDG - TYPE I NAA Federal Emissions NBA LIGHT DUTY CYCLE NBK EVAP Control System NDA Catalytic Converter NF2 18.5 Gallon Fuel Tank PY3 QY3 RAA All Radio Equipped Vehicles RAC AM MTR Radio RCA SBA Power Steering SCB Steering Whl SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers TAA All Tires TAD HIGHWAY TREAD TBB Full Size Spare Tire TBM Tire Carrier Winch TNC P195/65R15 BSW AS Touring Tires WJK 15X6.0 Styled Steel Wheels WMC Bright Wheel Trim Rings XBS Pickup Box XFA -35F Protection Anti-Freeze YAA Build To U.S. Mkt. Specifications YGB 1 Additional Gallons of Gas YGG 9 Additional Gallons of Gas Z01 Rear Spring Group I Z1A GVW/Payload Rating Z59 Left Front Spring Group Ix Z78 Right Front Spring Group VIII Build date 3/10/89 Body code TL61
  3. Well most, if not all MJ's and XJ's were built here and then exported to Europa. So AMC|Jeep and Chrysler still followed the U.S. automotive regulations when it came to building cars. Never understood why Europe is so finicky about car registrations.
  4. Do you not have a plate on the fire wall or the radiator support?
  5. I may be color blind but are you sure? The second clean picture looks like a good match. Either way your plastic parts could also be faded too but who knows.
  6. Bell house is under your truck, its the housing for the clutch and often looks like a bell and its what mates the transmission to the engine. You could pour brake fluid down the master and see what happens. Just listen for a leak on the ground if your slave failed.
  7. Lol, when working in parts long enough, you truly get to see Chryslers questionable expense choices aside from a $100k SUV.
  8. Bad cap wouldn't be the cause of failure. The purpose of the cap is to keep debris and air from making the brake fluid go bad on ya.
  9. Chrysler? Maximize profit? Lol.
  10. Looking good! Maybe its the camera but why do the lights look brighter in the second photo?
  11. I just talked with @CoastChief about your issue and he told me what you found. Once you get good at dropping the trans under 40 min it gets old. Pretty much all slave cylinders are junk right out of the box. Biggest problem with them is the U-clips that hold the metal hoses to the slave. If those arent replaced with something better or pushed down more securely, the pressure from the clutch master and lines will cause one of those internal slave lines to fail. Check the bell house and see if theres a mass amount of brake fluid dripping right there. I had been in your spot once where I lost all fluid and the u-clip popped out and popped the hose out of place. Also check the lines too for a failure from the master to the union fitting for the slave cylinder.
  12. Lol, I still need to replace the passenger side bracket, but after the whole bolt ordeal with the drivers side, I am very hesitant to replace it lol.
  13. 1500'S have coil suspensions for the rear.
  14. Ill be expecting another little dump sometime next week and hopefully another order to be placed at the same time.
  15. Yes, this is a build sheet/date and body code that is to your VIN. I work at a dealer and can get access to that info. Fiatslug has all the parts books to easily decode your VIN's trim and package level. No problem!
  16. Yes, I shouldn't have anymore things to do when I get home from work for a while.
  17. *A6 Seats - Vinyl High Back Bucket -YY 3LR APA MONOTONE PAINT PACKAGE BCQ Battery - 750 Amp Maintenance Free CBA BENCH SEAT - STRAIGHT BK CGX Head Restraints-Outboard Seating, RR CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ DGS TRANSMISSION-4SPD. AUTO,AISIN WARNER ERB ENGINE - 4.0L I6 MPI GAS GAC ALL WINDOWS - TINTED GLASS HAA AIR CONDITIONING - FRONT HCC HEATER W/UPR LEVEL VENTIL - TYPE II JJA CIGAR LIGHTER - FRT COMP KD8 STRIPE/BADGE/MOLDING/DELETE LMA HALOGEN HEADLAMPS MDA FRT LICENSE PLATE ATTACH REQUIRED NAA ESA W/CATALYST (EXC CALIF SYSTEM) PXH QXH SBA POWER STEERING TBG SPARE TIRE - COMPACT TBL TIRE CARRIER - INSIDE WMC BASE WHEEL DRESS - UP (INCLS TRIM RING) Build date 2/17/87 Body code TL61
  18. I feel if they're using other styling from past modern Jeeps, then it shouldn't bear 100K price tag. At least it should have the classic waggy front end, then I could justify the price tag.
  19. Nice scores! Especially the AMC plate. As for the 4 wheel drive, AMC put those on 4x4 vehicles from 84-86 except the Eagle which got that nameplate all the way to 88.
  20. Not sure if anyone has been following or watching the new "SJ" closely but the full body was revealed today and all I have to say is it looks like an Escalade.
  21. Fun fact, The drivers side cap is the one I got from you that had that weird hole in it. Thanks!
  22. Bumper has a bit more imperfections than what I first saw but thats A-ok. Its really weird to see the OEM bumper on my truck.
  23. They actually look hell of a lot better than the old Renix clips. I just might get two of them tomorrow.
  24. I thought about those damn things many many times and I always came to the conclusion that they would have to be greatly modified to fit. Glad I wasnt the only one who thought about those.
  25. Already PM's him. He told me the owner would like to keep the truck whole as a future project. Dislike it when people do that but its the junkyards.
