eaglescout526
Administrators
    13
  1. The Astra-Hammond one with hinges, took about a month to get and my guess would be covid and it ships directly from supplier. Actually visibility at first is really weird but after a bit of driving with it on, you get used to it but it has good , not entirely obstructing, visibility. I would say you can see way more out of it than you can inside, like if your driving behind me, I can see you but I'm sure you couldn't see me sitting in the cab, I'll have to snap a pic of what I see in the seat in the rear view and turning my head. But overall well made plastic, helps keep the sun off your back and helps cool and protect the interior.
  2. Ah, good ole snotsdale. @Pirate_Staz, is out there. He's selling his MJ soon but will hopefully have an MJ again.
  3. I will usually toss Mopar packaging but I keep a lot of the AMC boxes and packages especially the blue and white ones are really neat pieces.
  4. Been a few weeks so here’s an update and an opinion. Opinion: the ZJ box was a damn good upgrade. My thoughts after a couple weeks. I’ve noticed less groaning from the steering but occasionally I’ll get a load pop and steering will go wonky. Probably something needs to be adjusted somewhere, not sure where though as the steering will pop on fast turns from time to time so it’s not easy to catch. But once it does this it will return to normal after a bit of driving and turning. Update. It’s been way too damn hot to do anything. No T-bird, no bumper, no nothin. I did add that rear window louvre and by golly that was hell of an upgrade. Significantly helps with cooling of the cab in these rough temps. Also since it’s been so damn hot the glue is failing on the headliner now but I’ll fix that and add insulation to the roof one day maybe soon like winter. Anyways here’s a pic of the louvre at night: I’ll have to get a good day pic. Really weird to drive with a dark cab.
  5. *Q7 Cloth Low-Back Bucket Seats -SA CHARCOAL 172 Zone 72-Portland 1AA U.S. Dealer Retail 3V5 Customer Preferred Discount 4HC Special Scheduling Condition III ADA Light Group ALR APA Monotone Paint ARM Radio AM/FM Cassette BAF 130 Amp Alternator BCX Dual 700 Amp Maint. Free Batteries BGA Power Front Disc/Rear Drum Brakes CAC Bucket Seats CDB Reclining Front Seats CKA Carpets - Floor and Cargo Area CUF Full Length Floor Console DBB All Manual Transmissions DDQ 5-Speed Manual Transmission DMM 3.07 Rear Axle Ratio DRJ 175MM Rear Axle ERH 4.0L I6 Power Tech Engine GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEH Fixed Door Vent Glass GFD Rear Sliding Window GNC Sun Visors w/Illum Vanity Mirrors GRZ Left Remote Mirror GSZ Right Remote Control Mirror GTZ Manual Remote Mirrors HCD Do Not Use - See HCA JAY DO NOT USE - See JP, KA classes JCA 85 MPH Primary Speedometer JGB Digital Clock JHA Var Intermittent Windshield Wipers JJA Cigar Lighter K27 Do Not Use K2B STRIPE/BADGE/MOLDING/COLOR K3R STRIPE/BADGE/MOLDING/COLOR KLT KWD LAJ Headlamps On Warning Chimes LAP Shift Indicator Warning Lamp LBB Courtesy Lamps LBC Glove Box Lamp LBD Ash Tray Lamp LBE IP LED Ambient Light Pipe LDA Underhood Lamp LHD Headlamp Off Time Delay LMA Halogen Headlamps LNJ Front Fog Lamps MB1 Black Front Bumper MBJ Black Front Bumper MCA Front bumper pads MDA Front License Plate Bracket MFK Body Color Grille MHA Black Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMK Lower Grille Surround-Painted Silver NAA Federal Emissions NBK EVAP Control System NF2 18.5 Gallon Fuel Tank PE4 COLORADO RED CC PRI PNT - HE4 QE4 COLORADO RED CC SEC PNT - HE4 RAA All Radio Equipped Vehicles RAF AM/FM Cassette Radio RCD 4 Speakers SBA Power Steering SCG Leather Wrapped Steering Wheel SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers SUA Tilt Steering Column TBC Compact Spare Tire TBM Tire Carrier Winch TRM P225/75R16 BSW On/Off Road Tires TZA Goodyear Brand Tires WJH 15X7 Aluminum Wheels WLZ All Aluminum Wheels XBS Pickup Box YAA Build To U.S. Mkt. Specifications YGE 5 Additional Gallons of Gas Z01 Rear Spring Group I Z1A GVW/Payload Rating Z58 Left Front Spring Group Viii Z78 Right Front Spring Group VIII Build date 9/18/90 Body code TL61 This truck looks familiar.
  6. Theres a noid light kit you can get at your auto store to test the wiring and ECU. The injector is Ωhm tested with a voltmeter. If you remove the throttle body bonnet it will reveal the injector, there are two screws holding the injector retainer in place, remove those and the injector will pull straight out. CAUTION. When reinstalling the injector, do not overtighten the screws, they can break and are not replaceable.
  7. Phoenix huh? Awesome. Looks good and I’d like to see it in person sometime.
  8. A Herse?
  9. I believe the OP is referring to the outside door moldings and not the actual weather strips and pieces.
  10. This will be a fun one. We had another member, @SoCalManche, his wouldnt fire at all on its own without gas. Did rigorous testing on sensors, wires, ECU and the fuel pump circuit to confirm everything and it turned out to be a bad injector. One of the things we did to quickly confirm that there was fuel actually getting to the throttle body was to remove the injector and see if fuel would dump into the bowl or not. There is am Ωhm test that can be done on the injector and I think if its over 10Ωhms, its bad but sometimes a bad injector will still show good like in SoCals case.
  11. You say 89 2.5L, it would be Throttle Body Injection. Have you confirmed that the injector is pulsing along with its circuit? Has the fuel pump been heard during priming sequence and has the pump been replaced or checked?
  12. Junkyard. Theres a few pieces laying around at dealers but not enough to do a complete new set like you would want to do.
  13. Pfff what a dork. I thought the pics looked too green and gloomy for AZ. Lol.
  14. What did he do? Use the same pics you sent him? Lol. Ill go give him some crap.
  15. Honestly it would be one thing if the radio was an early CD radio from the 80's that was a rare factory option. But this is just an AMC radio that can easily sell for $100+. Not $10k.
  16. https://phoenix.craigslist.org/wvl/pts/d/scottsdale-jeep-comanche-tow-mirrors/7175621756.html In Snotsdale, not mine.
  17. Absolutely a well preserved SporTruck. Congrats and I look forward to helping you out more.
  18. https://www.ebay.com/itm/AMC-RX-135XJ-Factory-Stock-AM-FM-Cassette-Player-Radio-1986-1987-Jeep-Cherokee/264833708655?hash=item3da951b26f:g:LugAAOSwK1dfOU42 Pfffffff.. I thought the $950 one was bad.
  19. The OP talked about it being a street MJ when he got it with the plastic body moldings and such from Archer Bros. Don’t know where 54 was said though.
  20. Let me know if you want me to try to find anything NOS. Too bad it’s not an I6 because I have a dealer AC add on kit for those 79-83 Jeeps.
  21. No problem. I can find out specs if you’d like, I have a book that will help me with that.
  22. Anything over 5% humidity is killer here.
  23. How long have you been living the triple digit life?
  24. I will gladly give up the bumper I have now for that new one!
