13
What Pete said. Modern VINs I can look up and I can see VIN specific stuff but the older stuff just has what the older parts catalogs show in terms of all parts. We would need a factory sheet to see. I don't think it was until sometime in the 90's where Chrysler started having VIN specific stuff to their catalog as a thing.
Ack, what a terrible exterior/interior combo. *E1 Cloth Bench Seat -Q8 155 Zone 55-Milwaukee 1AA U.S. Dealer Retail 5AM Largo Tracking 5KM AMES Department Stores ADA Light Group ADB Protection Group ADH Heavy Duty Electrical Group AHL Heavy Duty Insulation Group ALM Longhorn Southfork Package APA Monotone Paint BA1 100 AMP ALTERNATOR BCY BATTERY, 58-475 CC BGA Power Front Disc/Rear Drum Brakes BJA STD DUTY FRT DISC BRAKES BKP 10x2.5 Rear Drum Brakes CBA Straight Back Bench Seat CKA Carpets - Floor and Cargo Area CLA Front Floor Mats CSR Passenger Assist Handles DGB All 4-Speed Automatic Transmissions DGS 4-Speed Automatic AW4 Transmission DHA Lock-Up Torque Converter DHT Elec,Shift-on-the-Fly,P/Time T/Case DMD 3.55 Rear Axle Ratio DRJ 175MM Rear Axle EAA All Engines EAF ALL FUEL INJECTED ENGINES-GAS ERB ENGINE - 4.0L I6 MPI GAS GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEC Front Left Side Sliding Window GFD Rear Sliding Window GNA Rear View Day/Night Mirror GNB Driver Side Illuminated Sun Visor GRC Entire Fleet Key Alike (FREQ 7) GSC Right Black Mirror GTC Manual Mirrors HAA Air Conditioning HGA Hood Insulation JAA Instrument Panel JAZ DO NOT USE - See JP, KA classes JBD BEZEL-I/PANEL CLUSTER - BRIGHT JCA 85 MPH Primary Speedometer JHA Var Intermittent Windshield Wipers JJA Cigar Lighter JKB MOPAR Hood Lock K2X STRIPE/BADGE/MOLDING/COLOR K3W STRIPE/BADGE/MOLDING/COLOR KKE LAF Seat Belt Alert-Driver Seat only LAJ Headlamps On Warning Chimes LBB Courtesy Lamps LBC Glove Box Lamp LBD Ash Tray Lamp LBE IP LED Ambient Light Pipe LCJ DOME/READING LAMP B-PILLAR LDH U/Hood, Removable/Rechargeable Lamp LHD Headlamp Off Time Delay LMA Halogen Headlamps LPE Cargo Lamp MB1 Black Front Bumper MBJ Black Powder Coated Front Bumper MCA Rear Body Color Applique MDA Front License Plate Bracket MFG Body Color Headlamp Bezels MHA Black Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMK Lower Grille Surround-Painted Silver MMP MOLDING - DOOR EDGE GUARDS NAA Federal Emissions NBA LIGHT DUTY CYCLE NBK EVAP Control System NDA Catalytic Converter NF2 18.5 Gallon Fuel Tank NHM Speed Control PWB PEARL WHITE PRIMARY PAINT - HWB QWB PEARL WHITE SECONDARY PAINT - HWB RAA All Radio Equipped Vehicles RAB AM/FM Radio RCD 4 Speakers SBA Power Rack and Pinion Steering SCE Alcantara Wrap Steering Wheel SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers SUA Tilt Steering Column TAA All Tires TBC Compact Spare Tire TBM Tire Carrier Winch TMW P265/60r18 BSW A/S All Terrain Tires WJM 15X7.0 Chrome Wheels XBS Pickup Box XFA -35F Protection Anti-Freeze YAA Build To U.S. Mkt. Specifications YGG 9 Additional Gallons of Gas Z01 Rear Spring Group I Z1A GVW/Payload Rating Z59 Left Front Spring Group Ix Z78 Right Front Spring Group VIII Build date 8/28/88 Body code TM61
*X1 -H9 3LX AGJ Driver Assistance Group APA MONOTONE PAINT PACKAGE CBA BENCH SEAT - STRAIGHT BK CGX Head Restraints-Outboard Seating, RR CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ DGS TRANSMISSION-4SPD. AUTO,AISIN WARNER ERB ENGINE - 4.0L I6 MPI GAS GAC ALL WINDOWS - TINTED GLASS GFD SLIDING RR WINDOW GSC MIRROR - RIGHT BLACK JHA WINDSHIELD WIPERS - DELUXE JJA CIGAR LIGHTER - FRT COMP K60 BODY SIDE MOLDINGS - VINYL LMA HALOGEN HEADLAMPS MBJ Bumper - Front, Black MDA FRT LICENSE PLATE ATTACH REQUIRED NAA ESA W/CATALYST (EXC CALIF SYSTEM) PYC Amped QYC Amp'd RAB Radio - AM/FM SBA POWER STEERING SCE STRG WHL - EURO/SPORT TYPE TBG SPARE TIRE - COMPACT WJN 15" Aluminum Wheels Build date 3/3/88 Body code TM62
*A6 Seats - Vinyl High Back Bucket -Y1 3LQ APA MONOTONE PAINT PACKAGE CBA BENCH SEAT - STRAIGHT BK CGX Head Restraints-Outboard Seating, RR CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ DDQ Transmission - 5-Speed Manual EPD ENGINE - 2.5L I4 TBI GAS GAC ALL WINDOWS - TINTED GLASS GFD SLIDING RR WINDOW GPB DUAL - O/S MIRR PKG - LOW MOUNT - CHROME HCC HEATER W/UPR LEVEL VENTIL - TYPE II JHA WINDSHIELD WIPERS - DELUXE JJA CIGAR LIGHTER - FRT COMP LAP FUEL ECONOMY SHIFT INDICATOR LIGHT LMA HALOGEN HEADLAMPS MBJ Bumper - Front, Black MDA FRT LICENSE PLATE ATTACH REQUIRED NAA ESA W/CATALYST (EXC CALIF SYSTEM) PE4 Colorado Red QE4 Colorado Red RCA MONAURAL SPEAKER SYSTEM SBA POWER STEERING TBG SPARE TIRE - COMPACT WJD WHEELS - 15 X 7.0 STYLED STEEL Build date 8/26/86 Body code JL62 Black interior and a 2.5L with Colorado Red. My kind of MJ.
Stock height (or close to) leaf springs.
eaglescout526 replied to Psveritas's topic in MJ Tech: Modification and Repairs
General springs makes new factory height standard and metric ton leafs. -
I want to believe.
Huh was just about to go look at my VIN and see whats different and whats the same but Pete beat me to it. Well there you have it, the version that I have is probably out of date. I wonder when Chrysler updates these lists. Maybe every 10 years?
Indeed you have Pete. Ive got lots more irrelevant PDFs I can share from starparts. Actually in my sig is the same exact sales code link.
Ok that makes much more sense.
Wow! I'm surprised this popped up in the general search. I thought only dealer guys could access that through starparts and I'm wrong.
What? The temp sender is at the rear of the head top side. There's two styles a sender and a sensor. Sensor is for the gauge which you need and it uses the same plug as the sender did. Should be a really easy swap to do but youll lose coolant. Did you buy the coolant temp sensor for the ECU that goes into the side of the manifold?
Engine compression question
eaglescout526 replied to ruralandalone's topic in MJ Tech: Modification and Repairs
I can break out my 2.5L engine rebuild book that can help decipher the date code on the block. Otherwise as far as these engines go and being made out of cast iron, some of them including my 84 XJ are going strong and well above 300k without a rebuild and 4.0's are doing the same. AMC made some really well built and stout engines that will keep going when properly maintained for years and miles. -
120 is healthy for the 2.5L . Do you suspect something is wrong with your engine? -
Always saddens me to see how people treat the top of the line Jeeps.
Cruise control question
eaglescout526 replied to Piilgrim82's topic in MJ Tech: Modification and Repairs
Oh yeah it will be, Just Dr. Cruise gives your system prognosis as a "special case". -
Lol. Yet we still can't quite get yours to work as it should despite every dang test I can think of. -
If youre ready for this and want cruise to work, we are about to dive into a whole world of fun! -
Now that the photo has been loaded, yes thats entirely for cruise control and is needed to operate. -
So your brake switch should have two sets of prongs. One for the main harness and one for cruise control. I think the pink wire is for the cruise control side, as long as you still have the old Renix set up. As Dzimm said about the photo thing, if you are using iphone, how are you uploading your pictures? Usually i don't have an issue when I'm actually looking at CC under Safari. -
*X1 -SA Charcoal ADE COLD WEATHER GROUP AGJ Driver Assistance Group APA MONOTONE PAINT PACKAGE BCQ Battery - 750 Amp Maintenance Free CBA BENCH SEAT - STRAIGHT BK CGX Head Restraints-Outboard Seating, RR CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ DDJ 5SPD MANUAL TRANS A881 (JA-41) ERB ENGINE - 4.0L I6 MPI GAS GAC ALL WINDOWS - TINTED GLASS GFD SLIDING RR WINDOW GSC MIRROR - RIGHT BLACK JDA SPEEDOMETER - 140 KILO PRIMARY JFH TACHOMETER - MECH JGB Clock - Digital JHA WINDSHIELD WIPERS - DELUXE JJA CIGAR LIGHTER - FRT COMP K60 BODY SIDE MOLDINGS - VINYL KQJ LAP FUEL ECONOMY SHIFT INDICATOR LIGHT LMA HALOGEN HEADLAMPS MBJ Bumper - Front, Black MDA FRT LICENSE PLATE ATTACH REQUIRED NAG NFA TANK - 23 GAL PE4 Colorado Red QE4 Colorado Red RAB Radio - AM/FM SBA POWER STEERING SCE STRG WHL - EURO/SPORT TYPE TBB CONVENTIONAL SPARE TIRE WJD WHEELS - 15 X 7.0 STYLED STEEL Build date 2//9/88 Body code TM62 Canadian MJ.
So are you getting any fuel from the pump?
89 Pioneer Short bed Daily Driver build.
eaglescout526 replied to Rob S's topic in Member Projects: Your Comanches
That's a good candidate to preserve. But to each is their own.
