13
89 Comanche 4.0, Crank No Start
eaglescout526 replied to CognizantPotato's topic in MJ Tech: Modification and Repairs
What I do is members usually contact me, ask me if a part is available and if yes, what I do is give them a estimated price of what it will cost me to purchase(depending on where I get the part from) and either you have me get the part or you don't. Right now I can order some CPS's from vintage and they will cost me around $50. Let me know. -
Windows won't go down all the way.
eaglescout526 replied to Muncher's topic in MJ Tech: Modification and Repairs
I discovered this as I'm sure others did and its probably been mentioned but if you look down in the door you will see a hose. That hose holds the snake when the window is rolled down. Spray in there and roll it up and down a few times to help lube the track up -
60 OEM CPS left. -
I think you're right.
That MJ looks very familiar. Almost like ive seen it in person.
Well it was during AMC so anything I possible with them to save a quick buck. Wouldn't surprise me if a non painted column was cheaper to have and put in the low end models than the higher ends with a painted column.
I don't drink often but this week has been hell thanks to Chrysler. Been considering having something when I get home.
Welcome!
TCU is a dull silver and has Asin on a red label with an AMC part number.
ECU or TCU? Either way theres nothing behind the glove box. The TCU is behind the lower dash panel BELOW the glovebox and the ECU is up above the gas pedal.
4x4 shifter will not go back
Hahahahahahahaha! -
Chunk has a black tilt column. Not sure if the PO ever swapped it but I doubt he did. Probably would’ve been too much for him to do.
*Q7 Cloth Low-Back Bucket Seats -SA CHARCOAL 163 Zone 63-Dallas 1AA U.S. Dealer Retail 3V5 Customer Preferred Discount 4HA Special Scheduling Condition I ADA Light Group ALR APA Monotone Paint ARM Radio AM/FM Cassette BAF Alternator BCD 500 Amp Maintenance Free Battery BGA Power Front Disc/Rear Drum Brakes CAC Low Back Bucket Seats CDB Reclining Front Seats CKA Carpets - Floor and Cargo Area CUF Full Length Floor Console DBB All Manual Transmissions DDQ 5-Speed Manual Transmission DMM 3.07 Rear Axle Ratio DRJ 175MM Rear Axle ERH 4.0L I6 Power Tech Engine GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEH Fixed Door Vent Glass GFD Rear Sliding Window GNC Sun Visors w/Illum Vanity Mirrors GRZ Left Remote Mirror GSZ Right Remote Control Mirror GTZ Manual Remote Mirrors HAA Air Conditioning JAY DO NOT USE - See JP, KA classes JCA 85 MPH Primary Speedometer JGB Digital Clock JHA Var Intermittent Windshield Wipers JJA Cigar Lighter K27 Do Not Use K2B STRIPE/BADGE/MOLDING/COLOR K3W STRIPE/BADGE/MOLDING/COLOR KLT KWD LAJ Headlamps On Warning Chimes LAP Shift Indicator Warning Lamp LBB Courtesy Lamps LBC Glove Box Lamp LBD Ash Tray Lamp LBE IP LED Ambient Light Pipe LDA Underhood Lamp LHD Headlamp Off Time Delay LMA Halogen Headlamps LNJ Front Fog Lamps MB1 Black Front Bumper MBJ Black Front Bumper MCA MDA Front License Plate Bracket MFK Body Color Grille MHA Black Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMK Lower Grille Surround-Painted Silver NAA Federal Emissions NBK EVAP Control System NF2 18.5 Gallon Fuel Tank PW7 Bright White Clear Coat QW7 Bright White Clear Coat RAA All Radio Equipped Vehicles RAF AM/FM Cassette Radio RCD 4 Speakers SBA Power Steering SCG Leather Wrapped Steering Wheel SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers SUA Tilt Steering Column TBC Compact Spare Tire TBM Tire Carrier Winch TRM Tires TZA Goodyear Brand Tires WJH 15X7 Aluminum Wheels WLZ All Aluminum Wheels XBS Pickup Box YAA Build To U.S. Mkt. Specifications YGE 5 Additional Gallons of Gas Z01 Rear Spring Group I Z1A GVW/Payload Rating Z58 Left Front Spring Group Viii Z78 Right Front Spring Group VIII Build date 3/18/91 Body code TL61
The forest service bought XJs I know that much.
*ZZ TRIM STYLE ZZ - PLASTIC BUCKET SEAT -ZZ CGX Head Restraints-Outboard Seating, RR CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ DCK 4SPD MANUAL TRANS - AISIN SEIKI EPD ENGINE - 2.5L I4 TBI GAS GSC MIRROR - RIGHT BLACK HCC HEATER W/UPR LEVEL VENTIL - TYPE II LMA HALOGEN HEADLAMPS MDA FRT LICENSE PLATE ATTACH REQUIRED NAA ESA W/CATALYST (EXC CALIF SYSTEM) SBA POWER STEERING Build date 10/30/85 Body code JL62 Is it a part out?
I have no clue, i just ran the VIN. I can rerun to confirm if yall would like.
Pete if you can’t find it I can get the NOS one for ya.
Whats crazy is its a $62 part at list. But yet an ordinary lug wrench is $20 list(for the MJ's).
Supposedly theres one of these left as NOS. Course its at a dealer whos parts is closed. I should call them again and see if theyre open yet.
*E1 Cloth Bench Seat -SA Charcoal 151 Zone 51-Chicago 1AA U.S. Dealer Retail 5KN Metro Cars of Detroit ALN Body Color Bumper Group APA Monotone Paint ARL 300 Premium Group BAY 105 Amp Alternator BCY 475 AMP BATTERY BGA Power Front Disc/Rear Drum Brakes CBA Straight Back Bench Seat CKA Carpets - Floor and Cargo Area CSR Passenger Assist Handles DGB All 4-Speed Automatic Transmissions DGS 4-Speed Automatic AW4 Transmission DHT Shift-on-the-Fly,P/Time T/Case DMD 3.55 Rear Axle Ratio DRJ 175MM Rear Axle EAA All Engines EAF ALL FUEL INJECTED ENGINES-GAS ERB ENGINE - 4.0L I6 MPI GAS GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEC Front Left Side Sliding Window GFD Rear Sliding Window GNA Rear View Day/Night Mirror GRZ Left Remote Mirror GSZ Right Remote Control Mirror GTZ Manual Remote Mirrors HAA Air Conditioning JAZ DO NOT USE - See JP, KA classes JCA 85 MPH Primary Speedometer JHA Var Intermittent Windshield Wipers JJA Cigar Lighter K2X STRIPE/BADGE/MOLDING/COLOR K3R STRIPE/BADGE/MOLDING/COLOR KKE LBC Glove Box Lamp LCJ DOME/READING LAMP B-PILLAR LMA Halogen Headlamps MB1 Black Front Bumper MBJ Black Front Bumper MDA Front License Plate Bracket MFG Body Color Headlamp Bezels MHA Black Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMK Lower Grille Surround-Painted Silver NAA Federal Emissions NBK EVAP Control System NF2 18.5 Gallon Fuel Tank PE4 COLORADO RED CC PRI PNT - HE4 QE4 COLORADO RED CC SEC PNT - HE4 RAA All Radio Equipped Vehicles RAF AM/FM Cassette Radio RCD 4 Speakers SBA Power Steering SCE Wrap Steering Wheel SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers SUA Tilt Steering Column TAA All Tires TBC Compact Spare Tire TBM Tire Carrier Winch TMW All Terrain Tires WJD 15X7.0 Styled Steel Wheels WLY All Steel Wheels XBS Pickup Box YAA Build To U.S. Mkt. Specifications YEP Manuf Statement of Origin YGE 5 Additional Gallons of Gas Z01 Rear Spring Group I Z1A GVW/Payload Rating Z59 Left Front Spring Group Ix Z78 Right Front Spring Group VIII Build date 8/27/89 Body code TL61
