13
I have all the parts books from 84-88 but nothing newer. The electronic catalog has everything from 84-now. Some parts still show up like really old battery numbers.
Well I come to yall with some bizarre info on part numbers, if you care or not. Recently I have come across an issue when looking up parts, I am seeing more and more Jeep parts from the 80's (not sure about other Chrysler cars) come up as "Part number not found" in both the catalog and in parts inquiry. So if you ask me or any of the other dealer guys to look up a part and it comes back as part number not found, its Chrysler doing something weird. Speculation is merging with PSA, others is that its Chrysler purging old numbers(not sure why they would do this) but I figured I would inform you guys about this debacle that I've been noticing.
MS-1700 is the original AMC tool used to read and get codes. There was an adapter that specifically read the 2.5L ECU that plugged into the MS-1700.
Could be bad right out of the box. The entire horn system relies on grounding out at the column shaft. I would check the relay and try testing the wiring for shorts or open circuits.
What does the relay look like? Some of those OEM style aftermarket ones ive had go bad on one blow of the horn. Ive found that the Napa replacement and ones that can be nabbed from a junkyard tend to work better. I wonder what the true issue is if everything has shiny new parts.
Be warry. These TJ unlimiteds as bone stock are going up on value.
Caden's 1987 Comanche Chief
eaglescout526 replied to Muncher's topic in Member Projects: Your Comanches
That could explain why the doors don't say "COMANCHE CHEIF" On them. -
Could be a swap 10 slot would narrow it between a 86-87 unless swapped, same with the name plates and yes Laredos were 87-92.
Are you sure your truck is a 91? It has a lot of indicators that would make it an 86.
Exhaust to air box hose.
eaglescout526 replied to eaglescout526's topic in MJ Tech: Modification and Repairs
Yeah i went and looked at my spare manifold and saw the same thing. I’ll just leave the hose alone and not think much about it. ‘‘Twas a part I never really looked at till the hose ripped. -
Socal and I have been going back and forth on this. So far I’m probably wrong and my hand was playing tricks on me as I stuck my hand by the hose to see if I could feel anything and I thought I did but I probably didn’t. I have a spare manifold I’m going to look at tomorrow and see. I'm probably thinking about how older cars recycle the fumes from the valve cover to the air intake. -
Sounds good! Appreciate the input and idea! -
Did you have to use any clamps to help hold the hose on or no? -
Yes that hose. I don’t think the vac system for my pre heater works but nonetheless it’s still putting out fumes rather than recycle back into the intake. -
Alright everyone. At the drive in and noticed a rich smell to charge up the battery for the next film. Poked under the hood and found that my exhaust to air box hose is ripped right at the exhaust pipe. Have any of y’all run into this issue and what did you do to fix/replace? Side note, if anyone has a spare one PM me.
Any of the door seals, improperly sealed windshield or something around the fresh air door for the HVAC -
Actually if everything is still intact and operates as it should, it should all work via the signal stalk.
Nope, not kidding. Kinda took up as the knowledgeable one for factory cruise.
Small yellow one is my favorite. Cruise control.
Thats your air box for the AC and heater core. The lower dash panel you took off should have the trans computer if you have an auto. Otherwise the ECU is on the drivers side under the dash above the gas pedal.(in your case its still attached to the dash)
*X4 -H9 3LY AGJ Driver Assistance Group APA MONOTONE PAINT PACKAGE CBA BENCH SEAT - STRAIGHT BK CGX Head Restraints-Outboard Seating, RR CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ DDJ 5SPD MANUAL TRANS A881 (JA-41) ERB ENGINE - 4.0L I6 MPI GAS GAC ALL WINDOWS - TINTED GLASS GFD SLIDING RR WINDOW GSC MIRROR - RIGHT BLACK JAY Instrument Cluster w/Tach JGB Clock - Digital JHA WINDSHIELD WIPERS - DELUXE JJA CIGAR LIGHTER - FRT COMP K60 BODY SIDE MOLDINGS - VINYL LAP FUEL ECONOMY SHIFT INDICATOR LIGHT LMA HALOGEN HEADLAMPS MBJ Bumper - Front, Black NAA ESA W/CATALYST (EXC CALIF SYSTEM) PX6 CLASSIC BLACK CLR CT PRIMARY PAINT - FX6 QX6 CLASSIC BLACK C CT SECONDARY PAINT - FX6 RAF Radio - AM/FM Cassette SBA POWER STEERING SCE STRG WHL - EURO/SPORT TYPE SUA TILT STEERING COLUMN TBG SPARE TIRE - COMPACT WJD WHEELS - 15 X 7.0 STYLED STEEL Build date 7/14/87 Body code TM61
Windows won't go down all the way.
eaglescout526 replied to Muncher's topic in MJ Tech: Modification and Repairs
If it wasnt such a task to take my door cards off I could show you. But it should be somewhere around there. -
It should be connected some where on the regulator. -
Yep. That’s where it lays.
