13
Figured as much. A lot of stuff from the 80's and 90's Jeeps seems to be lost with time.
Could be a Chrysler, could be an AMC screw up. I see those two recalls too. Wonder what the brake booster is about. Shame that the global recall guide actually doesnt have any of the old AMC recalls and early Chrysler ones on file.
1JTBL6511GT000763 This VIN is weird. Not in the sense in we can't retrieve its build info but more like date and service date. So this VIN shows a build date of 5/14/87. Yet it bears a GT which is 1986. Ok, could be a special order MJ that was waiting on a piece or two. It comes equipped with the 2.1L Renault. Could've been waiting on the engine if there was a shortage. Or the cargo lamp or the AX5 with bell house it was equipped with, who knows? here's where the conflict happens: How was it built in May but in service in March? Really strange. Que X-files.
stamped VIN on the frame
eaglescout526 replied to Claude's topic in MJ Tech: Modification and Repairs
Keep in mind we’re talking about a truck that was built in the 80’s that really never conformed to any of Europe’s automotive standards. Try searching for a possible location on an XJ frame as those sold very well in Europe and can give you a general idea if AMC and Chrysler did stamp the full VIN on our trucks. -
What does your VIN plate say about the paint code?
Bench Seat--Seatbelt Replacement Dilemma
eaglescout526 replied to Comanchakazie's topic in MJ Tech: Modification and Repairs
What I would do is search for Bendix, 80's Ford or 80's GM belts. Bendix actually made most of the American automotive seat belts. I learned that Ford used the same belt company as denoted by the later star burst on the buckle button and GM used them commonly. Luckily you don't have the AMC button belts otherwise you would have hell of a time finding those. Also glad to see another AZ member. -
*ZZ TRIM STYLE ZZ - PLASTIC BUCKET SEAT -ZZ ADA LIGHT PACKAGE AGR AJY Popular Equipment Package BAC 75 AMP ALTERNATOR BCQ Battery - 750 Amp Maintenance Free CGX Head Restraints-Outboard Seating, RR CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ DDQ Transmission - 5-Speed Manual DMN 4.10 Axle Ratio EFB ENGINE - 2.8L GM 6CYL GAC ALL WINDOWS - TINTED GLASS GSC MIRROR - RIGHT BLACK HAA AIR CONDITIONING - FRONT HCC HEATER W/UPR LEVEL VENTIL - TYPE II JAY Instrument Cluster w/Tach JGB Clock - Digital JHA WINDSHIELD WIPERS - DELUXE JJA CIGAR LIGHTER - FRT COMP LBB COURTESY LAMPS (BELOW PANEL) LMA HALOGEN HEADLAMPS LPE EXTERIOR CARGO LIGHT MBJ Bumper - Front, Black MDA FRT LICENSE PLATE ATTACH REQUIRED NAA ESA W/CATALYST (EXC CALIF SYSTEM) NFA TANK - 20 GAL FUEL NMB ENGINE COOLING - STANDARD DUTY RAB Radio - AM/FM SBA POWER STEERING SCE STRG WHL - EURO/SPORT TYPE Build date 8/19/85 Body code JM62
Well, I should've done this a while ago but I bought another NOS coolant cap for the 2.5L and decided to research the stampings on the under side. Well if you search up 48-400 cap under the Al Gore youll find the cap in many colors and materials. Thought id share this little discovery for when the cap supply runs low.
I don't know much about Europe's automotive registration but this is an 80's truck we are talking about. Our across the pond members have had issues registering because of tail lights but back then the MJ tail lights didn't require the amber turn signal over there like they require it now. Just blame the U.S. for the red tail lamps. -
*D1 TRIM STYLE D1 - CLOTH BENCH -YY 169 Zone 69-Phoenix 1AA U.S. Dealer Retail 4HB Special Scheduling Condition II 5AL Low Series Tracking APA Monotone Paint BAY 105 Amp Alternator BCY BATTERY, 58-475 CC BGA Power Front Disc/Rear Drum Brakes BJA STD DUTY FRT DISC BRAKES BKP 10x2.5 Rear Drum Brakes CBA Straight Back Bench Seat CKA Carpets - Floor and Cargo Area CSR Passenger Assist Handles DGB All 4-Speed Automatic Transmissions DGS 4-Speed Automatic AW4 Transmission DHA Lock-Up Torque Converter DHT Shift-on-the-Fly,P/Time T/Case DMD 3.55 Rear Axle Ratio DRJ 175MM Rear Axle EAA All Engines EAF ALL FUEL INJECTED ENGINES-GAS ERB ENGINE - 4.0L I6 MPI GAS GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEH Fixed Door Vent Glass GNA Rear View Day/Night Mirror GRV Left Manual Mirror GUA Open HAA Air Conditioning JAA Instrument Panel JAZ DO NOT USE - See JP, KA classes JBF Instrument Panel Black Bezel JCA 85 MPH Primary Speedometer JKB K3Z STRIPE/BADGE/MOLDING/COLOR KDD LAF Seat Belt Alert-Driver Seat only LBC Glove Box Lamp LCJ DOME/READING LAMP B-PILLAR LMA Halogen Headlamps MB1 Black Front Bumper MDA Front License Plate Bracket MFF Black Grille MHB Bright Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMJ DRIP TROUGH MLDG - TYPE I NAA Federal Emissions NBA LIGHT DUTY CYCLE NBK EVAP Control System NDA Catalytic Converter NF2 18.5 Gallon Fuel Tank PY3 QY3 RAA All Radio Equipped Vehicles RAC AM MTR Radio RCA SBA Power Steering SCB Steering Whl SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers TAA All Tires TAD HIGHWAY TREAD TBB Full Size Spare Tire TBM Tire Carrier Winch TNC P195/65R15 BSW AS Touring Tires WJK 15X6.0 Styled Steel Wheels WMC Bright Wheel Trim Rings XBS Pickup Box XFA -35F Protection Anti-Freeze YAA Build To U.S. Mkt. Specifications YGB 1 Additional Gallons of Gas YGG 9 Additional Gallons of Gas Z01 Rear Spring Group I Z1A GVW/Payload Rating Z59 Left Front Spring Group Ix Z78 Right Front Spring Group VIII Build date 3/10/89 Body code TL61
Well most, if not all MJ's and XJ's were built here and then exported to Europa. So AMC|Jeep and Chrysler still followed the U.S. automotive regulations when it came to building cars. Never understood why Europe is so finicky about car registrations. -
Do you not have a plate on the fire wall or the radiator support? -
I may be color blind but are you sure? The second clean picture looks like a good match. Either way your plastic parts could also be faded too but who knows.
Lol, when working in parts long enough, you truly get to see Chryslers questionable expense choices aside from a $100k SUV.
Chrysler? Maximize profit? Lol.
'90 Eliminator (Puddy)
eaglescout526 replied to Jtslick89's topic in Member Projects: Your Comanches
Looking good! Maybe its the camera but why do the lights look brighter in the second photo? -
I just talked with @CoastChief about your issue and he told me what you found. Once you get good at dropping the trans under 40 min it gets old. Pretty much all slave cylinders are junk right out of the box. Biggest problem with them is the U-clips that hold the metal hoses to the slave. If those arent replaced with something better or pushed down more securely, the pressure from the clutch master and lines will cause one of those internal slave lines to fail. Check the bell house and see if theres a mass amount of brake fluid dripping right there. I had been in your spot once where I lost all fluid and the u-clip popped out and popped the hose out of place. Also check the lines too for a failure from the master to the union fitting for the slave cylinder.
Lol, I still need to replace the passenger side bracket, but after the whole bolt ordeal with the drivers side, I am very hesitant to replace it lol.
- 656 replies
- 2.5litre hurricane
- pioneer
(and 2 more)
Tagged with:
1500'S have coil suspensions for the rear.
Ill be expecting another little dump sometime next week and hopefully another order to be placed at the same time.
Yes, this is a build sheet/date and body code that is to your VIN. I work at a dealer and can get access to that info. Fiatslug has all the parts books to easily decode your VIN's trim and package level. No problem!
VIN Registry List: July 2026 Update
eaglescout526 replied to fiatslug87's topic in Comanche Registry (VIN decoding)
Yes, I shouldn't have anymore things to do when I get home from work for a while.
