blanzawa
    Central WA
blanzawa's Achievements
  1. I bought that kit thinking it would include these sleeves, but it did not. Even though they could not get it, NAPA finally identified it: Mopar 52001701 Sleeve for Bushing Front Brakes I ordered four. They're also available aftermarket. It says they're for a '91-'92 2WD, but they're on my '86 4WD. Someone may have installed different calipers before I bought it.
  2. I am servicing the front brakes on my '86 4WD Custom for the first time. Replacing the boots for the caliper guide pins is part of the job. Three of the original pins have a sleeve (example attached) between the pin and boot, while one was missing. The replacement boots did not include this part. I don't see any larger overhaul kits that ID or include the part, either, or it included with the guide pins. Is this something I'm going to need to go to the junkyard for? -- Ben
  3. I could have been clearer with my original question. What I meant to ask was that if I could access the bleeder, was it still necessary to remove the slave cylinder to manipulate the pushrod and plunger. I now realize it's not necessary. My Haynes manual covered two setups -- internal slave with bleeder and external slave without bleeder. Thanks for pointing out my good fortune. Yes, that's right. The slave did not need to be removed. I opened up the bleeder, got some air out, and did a 20 minute test drive without any more shifting issues. All that's left to fix are a stuck door lock and a window regulator. Hard to believe this thing is 34 years old and in near perfect mechanical condition.
  4. I believe I have some air in the clutch line of my '86 4WD AX5. I've been having trouble with the one bolt on the release cylinder that is easily accessible even after applying PB Blaster. If the other bolt on top is anywhere near as frozen, there's no way I'm getting it off without lowering the transmission. Is there an alternative way to bleed the system without removing the release cylinder? I can get to the bleeder and likely open it.
  5. Thanks a ton. You confirmed my memory of finding them both bolted to the left bolt of the steering column support -- though I had the order wrong. I think a previous owner only had one end of the long rod bolted in so I'll need to scrutinize around the fuse block a bit more for the attachment point.
  6. Hello, I am attempting to put the dashboard back together after replacing the ignition switch in my '86. I know where and how the shorter of the two pictured support rods attaches but I am completely lost on the longer one and I cannot find any helpful diagrams or images. Thanks in advance.
