blanzawa Posted August 3 Posted August 3 I am servicing the front brakes on my '86 4WD Custom for the first time. Replacing the boots for the caliper guide pins is part of the job. Three of the original pins have a sleeve (example attached) between the pin and boot, while one was missing. The replacement boots did not include this part. I don't see any larger overhaul kits that ID or include the part, either, or it included with the guide pins. Is this something I'm going to need to go to the junkyard for? -- Ben
Eagle_SX4 Posted August 3 Posted August 3 Is this what you are looking for? https://www.rockauto.com/en/catalog/jeep,1986,comanche,2.5l+150cid+l4,1181382,brake+&+wheel+hub,disc+brake+hardware+kit,1736
The86manche Posted August 3 Posted August 3 That doesn't look factory honestly. I don't think ive seen that. Maybe someone put them there. My 86 does not have those.
blanzawa Posted August 6 Author Posted August 6 On 8/2/2026 at 6:49 PM, Eagle_SX4 said: Is this what you are looking for? https://www.rockauto.com/en/catalog/jeep,1986,comanche,2.5l+150cid+l4,1181382,brake+&+wheel+hub,disc+brake+hardware+kit,1736 I bought that kit thinking it would include these sleeves, but it did not. Even though they could not get it, NAPA finally identified it: Mopar 52001701 Sleeve for Bushing Front Brakes I ordered four. They're also available aftermarket. It says they're for a '91-'92 2WD, but they're on my '86 4WD. Someone may have installed different calipers before I bought it.
