2
Everything posted by jdog
Looks like they went to a open cooling system, but just don't have a overflow bottle. As for the battery my guess is they tried cleaning up the wiring and engine bay. I'd be a bit suspicious on the wiring, the wiring wasn't great to begin with and now who knows where stuff was put.
What plugs? Also what is the fuel pressure, you say pump is working correctly but you don't say the numbers. Are there any numbers on the injectors and where did you get them?
What injectors and what plugs?
What all was done? Last night did it run on its own or require starting fluid?
Have you done cruiser54.com tips 1-5 only other thing I have to add to check is your map sensor
Build: 12/5/86 Body: TL61 Selling Dealer: CARRIAGE BUICK-GMC-JEEP-EAGLE Oxnard, CA *X8 Cloth Low-Back Bucket Seats -Y1 DESCRIPTION NOT AVAILABLE APA Monotone Paint CAC Low Back Bucket Seats CGW Next Generation Front Air Bags** CKA Carpets - Floor and Cargo Area CUF Full Length Floor Console DDJ DESCRIPTION NOT AVAILABLE ERB 4.0L I6 MPI Engine GAC Tinted Glass Windows GTZ Manual Remote Mirrors HCC Do Not Use - See HCA JAY DO NOT USE - See JP, KA classes JFH Tachometer JGB Digital Clock KD8 STRIPE/BADGE/MOLDING/DELETE LAP Shift Indicator Warning Lamp LMA Halogen Headlamps MDA Front License Plate Bracket NAE California Emissions NMB Standard Duty Engine Cooling PX6 DESCRIPTION NOT AVAILABLE QX6 DESCRIPTION NOT AVAILABLE SBA Power Steering SCG Leather Wrapped Steering Wheel TBG Compact Spare Tire TBL Inside Mounted Spare Tire WMC Open
Build: 7/21/88 Body: jm62 Selling Dealer: SMITH CHRYSLER PLYMOUTH JEEP EAGLE Richmond, CA *X1 DESCRIPTION NOT AVAILABLE -SA Charcoal ADL Skid Plate Group AGJ Driver Assistance Group APA Monotone Paint BCQ Maintenance Free Battery CBA Straight Back Bench Seat CGX RR Head Restraints Outboard Seating CKA Carpets - Floor and Cargo Area DDQ 5-Speed Manual Transmission ERB 4.0L I6 MPI Engine GAC Tinted Glass Windows GEC Front Left Side Sliding Window GFD Rear Sliding Window GSC Right Black Mirror HAA Air Conditioning JAY DO NOT USE - See JP, KA classes JGB Digital Clock JHA Var Intermittent Windshield Wipers JJA Cigar Lighter K60 STRIPE/BADGE/MOLDING LAP Shift Indicator Warning Lamp LMA Halogen Headlamps MBJ Black Bumper MDA Front License Plate Bracket NAE California Emissions NFA Fuel Tank NHQ Transmission Heater NMB Standard Duty Engine Cooling PE4 Colorado Red QE4 Colorado Red RAF AM/FM Cassette Radio SBA Power Steering SCE Steering Wheel SUA Tilt Steering Column TBB Full Size Spare Tire WJD 15X7.0 Styled Steel Wheels 3LY DESCRIPTION NOT AVAILABLE
Build Date: 1/18/89 Body: TL61 Selling Dealer: FREMONT JEEP Fremont, CA *B1 DESCRIPTION NOT AVAILABLE -SA Charcoal CBAP Straight Back Bench Seat DBBC All Manual Transmissions DCK DESCRIPTION NOT AVAILABLE EAAC All Engines EAFC 2.5L I4 MPI Engine EPD DESCRIPTION NOT AVAILABLE GRVP Left Manual Mirror MDAP Front License Plate Bracket NAE California Emissions PA2 DESCRIPTION NOT AVAILABLE RAAC All Radio Equipped Vehicles RCAP SBA Power Steering TAAC All Tires TNCA P195/65R15 BSW AS Touring Tires YGBA 1 Additional Gallons of Gas YGGA 9 Additional Gallons of Gas Z01P Rear Spring Group I Z57P Left Front Spring Group Vii Z76P Right Front Spring Group VI 5ALA DT-Vehicle Family APAS Monotone Paint BAQS 115 Amp Alternator BCXS Maint. Free Battery BGAS Power Front Disc/Rear Drum Brakes BJAS DESCRIPTION NOT AVAILABLE BKPS 10x2.5 Rear Drum Brakes CKJS Black Vinyl Floor Covering CSRS Passenger Assist Handles CUMS Mini Floor Console DMDS 3.55 Rear Axle Ratio DRJS Dana 35 Rear Axle GACS Tinted Glass Windows GBBS Tinted Windshield Glass GCBS Front Door Tinted Glass GEHS Fixed Door Vent Glass GNAS Rear View Day/Night Mirror GUAS Open HCDS Do Not Use - See HCA JAAS Instrument Panel JAZS DO NOT USE - See JP, KA classes JBFS Instrument Panel Black Bezel JCAS 85 MPH Primary Speedometer JKBS KDAS STRIPE/BADGE/MOLDING/COLOR K3ZS STRIPE/BADGE/MOLDING/COLOR LAFS Seat Belt Alert-Driver Seat only LBCS Glove Box Lamp LCJS Overhead Ambient Surround Lighting LMAS Halogen Headlamps MB1S Black Front Bumper MFFS Black Grille MHBS 35 Tire Body Color Fender Flares MMCS Rear Door Solid Window Insert MMGS Belt Moldings MMJS Molded-In-Color Fender Flares NBAS Underground Calibration NBKS EVAP Control System NDAS Catalytic Converter NF2S 18 Gallon Fuel Tank QA2S DESCRIPTION NOT AVAILABLE RACS Open SCBS Steering Whl SFAS Standard Duty Front Shock Absorbers SGAS Standard Duty Rear Shock Absorbers TADS TBCS Compact Spare Tire TBMS Tire Carrier Winch WJKS 15X6.0 Styled Steel Wheels WMCS Open XBSS Pickup Box XFAS -35F Protection Anti-Freeze YAAS Build To U.S. Mkt. Specifications Z1AS GVW/Payload Rating 1AAS U.S. Dealer Retail 173S Zone 73-San Francisco 4AFS
Auto vs. Manual Column Differences
jdog replied to CaptainPatchy's topic in MJ Tech: Modification and Repairs
I do not, and I didn't take any pictures, I do have another auto column I can do for some pictures/write up but it wouldn't be till a weekend or two -
Yes, that's what I'm running in mine, I disassemble the column and removed the park interlock but I Bet you could tie it up, just didn't want it to come loose and I'm stuck with a truck that won't shut off. -
Ah yeah realized I was way behind on that response, helps if I read page two
How did the brakes go?
What are your plans for it? A good clean interior and exterior always seems nice
Please post the Vin and we can get you a build sheet
Tire size with the Peugeot 2BF18 / AKA BA10
jdog replied to irieco's topic in MJ Tech: Modification and Repairs
What rims are you going to run -
Yeah guess so, brains not awake yet.
Do you have spark? And do you know if there's fuel
Does it crank? V6 or 4 cylinder
235/75/15 if you don't wanna re-gear/ change the 35. anything over that and you'll be stuck in the slow lane -
Build: 11/23/88 Body: jl61 Selling Dealer: NORTHWEST CHRYSLER JEEP DODGE BEAVERTON, OR *X2 DESCRIPTION NOT AVAILABLE -SA Charcoal CBAP Straight Back Bench Seat DBBC All Manual Transmissions DDX 5-Speed HD Manual Transmission EAAC All Engines EAFC ERB 4.0L I6 MPI Engine GRVP Left Manual Mirror MDAP Front License Plate Bracket PE4 Colorado Red RAAC All Radio Equipped Vehicles RCAP SBAA Power Steering TAAC All Tires TNCA P195/65R15 BSW AS Touring Tires YEA No Optional Sales Codes YGBA 1 Additional Gallons of Gas YGGA 9 Additional Gallons of Gas Z01P Rear Spring Group I Z65P Left Front Group XIV Z84P Right Front Spring Group XIII 5ALA DT-Vehicle Family APAS Monotone Paint BAQS 115 Amp Alternator BCXS Battery BGAS Power Front Disc/Rear Drum Brakes BJAS DESCRIPTION NOT AVAILABLE BKPS 10x2.5 Rear Drum Brakes CKJS Black Vinyl Floor Covering CSRS Passenger Assist Handles CUMS Mini Floor Console DHNS Command-Trac Part Time 4WD System DJHS 230MM Front Axle DMMS 3.07 Rear Axle Ratio DRJS Dana 35 Rear Axle GACS Tinted Glass Windows GBBS Tinted Windshield Glass GCBS Front Door Tinted Glass GEHS Fixed Door Vent Glass GNAS Rear View Day/Night Mirror GUAS Open HCDS Do Not Use - See HCA JAAS Instrument Panel JAZS DO NOT USE - See JP, KA classes JBFS Instrument Panel Black Bezel JCAS 85 MPH Primary Speedometer JKBS KDAS STRIPE/BADGE/MOLDING/COLOR K3ZS STRIPE/BADGE/MOLDING/COLOR LAFS Seat Belt Alert-Driver Seat only LAPS Shift Indicator Warning Lamp LBCS Glove Box Lamp LCJS Overhead Ambient Surround Lighting LMAS Halogen Headlamps MB1S Black Front Bumper MFFS Black Grille MHBS 35 Tire Body Color Fender Flares MMCS Rear Door Solid Window Insert MMGS Belt Moldings MMJS Molded-In-Color Fender Flares NAAS Federal Emissions NBAS Underground Calibration NBKS EVAP Control System NDAS Catalytic Converter NF2S 18 Gallon Fuel Tank QE4S Colorado Red RACS Open SCBS Steering Whl SFAS Standard Duty Front Shock Absorbers SGAS Standard Duty Rear Shock Absorbers TBCS Compact Spare Tire TBMS Tire Carrier Winch WJKS 15X6.0 Styled Steel Wheels WMCS Open XBSS Pickup Box XFAS -35F Protection Anti-Freeze YAAS Build To U.S. Mkt. Specifications Z5AS GVW/Payload Rating 1AAS U.S. Dealer Retail 172S Zone 72-Portland
Congrats to you, enjoy the retirement
I as well can cut keys if needed,
I need help finding a cps sensor
jdog replied to Virden's topic in MJ Tech: Modification and Repairs
ecu is engine computer and it should be right next to the air box on the drivers side of the vehicle towards the front
