jdog
    2
Everything posted by jdog
  1. jdog
    1J7FT36E5KL496871
    body: TM61 Build: 12/15/88 Selling Dealer: CLOVERLEAF CHRYSLER DODGE JEEP Decatur, AL *X1 DESCRIPTION NOT AVAILABLE -YY DESCRIPTION NOT AVAILABLE ALM CBAP Straight Back Bench Seat DBBC All Manual Transmissions DDQ 5-Speed Manual Transmission EAAC All Engines EAFC 2.5L I4 MPI Engine EPD DESCRIPTION NOT AVAILABLE GRZP Left Remote Mirror GSZP Right Remote Control Mirror GTZA Manual Remote Mirrors JHAA Var Intermittent Windshield Wipers MDA Front License Plate Bracket PE4 Colorado Red RAAC All Radio Equipped Vehicles RABA AM/FM Radio RCDP 4 Speakers TAAC All Tires TPFA P205/75R15 BSW All Season Tires YGBA 1 Additional Gallons of Gas YGGA 9 Additional Gallons of Gas Z01P Rear Spring Group I Z56P Left Front Spring Group Vi Z76P Right Front Spring Group VI 5AMA 5KMA AMES Department Stores APAS Monotone Paint BAQS 115 Amp Alternator BCXS Maint. Free Battery BGAS Power Front Disc/Rear Drum Brakes BJAS DESCRIPTION NOT AVAILABLE BKPS 10x2.5 Rear Drum Brakes CKAS Carpets - Floor and Cargo Area CSRS Passenger Assist Handles CUMS Mini Floor Console DMFS 4.10 Rear Axle Ratio DRJS Dana 35 Rear Axle GACS Tinted Glass Windows GBBS Tinted Windshield Glass GCBS Front Door Tinted Glass GEHS Fixed Door Vent Glass GNAS Rear View Day/Night Mirror HCDS Do Not Use - See HCA JAAS Instrument Panel JAZS DO NOT USE - See JP, KA classes JBDS Instrument Panel Satin Silver Bezel JCAS 85 MPH Primary Speedometer JJAS Cigar Lighter JKBS MOPAR Hood Lock KKFS DESCRIPTION NOT AVAILABLE K2XS STRIPE/BADGE/MOLDING/COLOR K3RS STRIPE/BADGE/MOLDING/COLOR LAFS Seat Belt Alert-Driver Seat only LAPS Shift Indicator Warning Lamp LBCS Glove Box Lamp LCJS Ambient Lighting LMAS Halogen Headlamps MBJS Black Bumper MB1S Black Bumper MFGS Body Color Headlamp Bezels MHAS Black Windshield Moldings MMCS Rear Door Solid Window Insert MMGS Belt Moldings MMKS Lower Grille Surround-Painted Silver NAAS Federal Emissions NBAS Underground Calibration NBKS EVAP Control System NDAS Catalytic Converter NF2S 18 Gallon Fuel Tank QE4S Colorado Red SBAS Power Steering SCES Steering Wheel SFAS Standard Duty Front Shock Absorbers SGAS Standard Duty Rear Shock Absorbers TBCS Compact Spare Tire TBMS Tire Carrier Winch WJDS 15X7.0 Styled Steel Wheels XBSS Pickup Box XFAS -35F Protection Anti-Freeze YAAS Build To U.S. Mkt. Specifications Z1AS GVW/Payload Rating 1AAS U.S. Dealer Retail 161S Zone 61-Atlanta
  2. Sounds like either a lazy landlord or tenant trying to keep it going without having the rent go up
  3. Yep, sounds like the shop didn't want to deal with it, or care to even make an effort to figure out where the leak was and how healthy the engine is. Do cruisers valve cover mod, change the gasket and wash the engine
  4. And should be built correctly if the machine shop is competent.
  5. Could be worse
  6. jdog
    CC Handles
    You know there's a newer version of this right?
  7. Numbers? Also if they say it has blowby did they do a leak down test to say which cylinder is causing this? How did the come to the conclusion that it has blow by? Have you used this shop before, not saying they aren't good just trying to get some facts. But if your set on their diag. It all depends on the plans of the truck and time frame
  8. Have you done a compression check yet? No sense in rebuilding a good motor if it's just simple things wrong.
  9. Gotta remember theirs a lot of stuff that needs to be grounded and the engine itself is only grounded thru those wires. I'd also be inspecting the dipstick tube and ground cable
  10. Some of the 2.5 had it, ps was an option iirc
  11. Price and location per forum rules lol, only other thing I would think would be a approx route or state where your headed
  12. Unless the wire is broken and would vibrate while driving
  13. Is the clutch pedal hitting any wires? Or moving any harness under the dash?
  14. I wish you luck on your search.
  15. Check all the grounds, check the one at the dipstivk and if you haven't already done it get a ground wire from the block to the firewall. I suspect your clutch is acting as a ground.
  16. Should have rigged up a power wheels driveline to it. Motorized wheel barrow But looks a lot better then some of the wheel barrows if seen lately
  17. Put me on the list
  18. Did you get a chance to check your hoses
  19. Yeah I figured it'd be a solid plate or something not sure why
