jdog
    2
Everything posted by jdog
  1. As I stated above you will have to put everything in, including the wiring. It troubles me that the professional help as you state didn't have you verify that the distributor was actually good or the coil or the fuse links. But as stated above good luck. I answered you original question above. If you decide to change your mind and figure the problem just let us know we will be glad to assist with the nessecary procedures
  2. Should have used vice grips
  3. Auto parts stores, it's just a standard relay
  4. https://youtu.be/JA644rSZX1A
  5. Vin: 1JTHS6417HT069795 Body: TL61 Build: December 5, 1986 Selling Dealer: BUD MULCAHY'S JEEP INC Des Moines, IA *A6-Vinyl Trimmed Bucket Seats -Y1-DESCRIPTION NOT AVAILABLE APA-Monotone Paint CBA-Straight Back Bench Seat CGX-RR Head Restraints Outboard Seating DCB-Open EPD-DESCRIPTION NOT AVAILABLE HCC-Do Not Use - See HCA JJA-Cigar Lighter KD8-STRIPE/BADGE/MOLDING/DELETE LAP-Shift Indicator Warning Lamp LMA-Halogen Headlamps MBJ-Black Front Bumper MDA-Front License Plate Bracket NAA-Federal Emissions PE4-Colorado Red QE4-Colorado Red SBA-Power Steering TBG-Compact Spare Tire WMC-Open
  6. harbor freight sells tarps
  7. what gets me is this " Front Clip Conversion done few years ago to a 2001" yeah sure the front end was done, what about the interior.
  8. I would say bad rubber hose or bad left side caliper or guide pins, just because the left side is grabbing doesn't mean it's working correctly
  9. He's at it again same story https://denver.craigslist.org/cto/d/aurora-rare-low-mileage-jeep-cherokee/7323704892.html
  10. Flat rate is what caused this.
  11. How did you keep the anti sieze from getting on everything?
  12. Got a picture? I bet it wasn't sabotage but a locked up gear, reading your other post id be checking if it was actually spinning, but since it sounds like you just want to swap you will have to swap both engine and dash harness, will have to set up something for the rear plug going to the rear of the vehicle and if you swap clusters your fuel gauge will read reverse
  13. You didn't state you were going to change the wiring as well, it will work but will require some rewiring. But you should figure out why the original doesn't run
  14. It also depends on if the po had a bunch of Keys on their ring or just the ones for the truck. Ps door keys should be separate key then the ignition
  15. Always enjoy a good long bed, welcome
  16. I'm questioning why it looks like it's in 4lo
  17. No worries about the coolant, it gets filled at the radiator
  18. Here's hoping you have better luck then I do with oops
