jdog
    2
Everything posted by jdog
  1. Id fix that fuse link first if you want it to start
  2. You will have to unbolt that white and black switch, it is attached with the same bolt but on the other side of the column
  3. Yes a cherokee harness will fit, if looks like someone attempted to replace a fusible link. Yes there are empty connectors in the engine bay
  4. Yes and yes, you will have to pull the ignition switch off the side of the column and move the rod
  5. Can we give suggestions?
  6. Yes the key should be in the on position to remove the key cylinder
  7. And And in a perfect shipping world won't have anything happen to them.
  8. Congrats, That a great color scheme
  9. We are in the elite club
  10. Must be pretty hard since Pete doesn't have any
  11. As is eaglescout526 and mini beast
  12. Pete's in the top 1%
  13. It's something to due with the rank system it seems like
  14. She's a keeper, glad to see it home without to much of a issue
  15. Yeah for just a little plastic detent.
  16. It's home it's home is it really really home? This calls for a celebration
  17. So you just swapped a ax15 into your automatic truck but didn't get the manual column? someone tried attempted to remove your comanche from your possession but couldn't figure out your kill switch and all that you can find are auto columns? well here is a lengthy write up ( with pictures of course) of how you can remove the shift lock out from that auto column. (not so fun part, I claim no responsibility if you screw it up, you are doing this at your own risk. I am only showing you a way to remove the interlock and nothing else.) OK Here we go. step one: remove the column from the truck. ( lots of write ups on how to remove the column) step two: remove steering wheel step three: remove the lock plate cover step four: remove the lock plate using the lock plate removal tool Step five: remove the turn signal cam Step?? (takes off shoe) 7: remove ignition cylinder step 8: remove upper bearing( becareful these things break) step 8: remove 3 t-30 torx bolts step 9: remove sleeve, remove turn signal switch and high beam cam step 10: tilt column all the way up and remove square plug using a Philips head screwdriver step 11: remove spring behind plug step 12: remove two plugs?? on side of column step 14: remove tilt assembly step 15: remove shaft step 16: remove 4 bolts and lower collar step 17: remove nut plate step 18: pull up on last collar step 19: remove rods(pull) step 20: remove detent step 21: reassemble reverse order First one i did it took me a couple hours, this one around a hour
  18. 5 more posts and the classifieds will open up for you, how about adding you truck to the registry and starting a build thread
  19. https://www.amazon.com/gp/aw/d/B002YKBEL8/ref=sspa_mw_detail_5?ie=UTF8&psc=1 ?? They are 12 pt, but I've seen them as a 6
