jdog
    2
Everything posted by jdog
  1. https://www.homedepot.com/p/Klein-Tools-Glow-Fish-Tape-20-Foot-50550/314609744
  2. Right connector is for the low wash level one on the left looks like the cps
  3. jdog
    Gas prices
    3.72 for midgrade
  4. carb or fi? I do not think it would be a plugged cat as you state you can run down the hiway with no issues. when it "dog outs" is it that you are giving gas and it is slowing down or is it bogging as if its almost going to die
  5. Just a guess here but bad sockets
  6. @cruiser54 Might know
  7. That's sad, looks solid
  8. Sounds like the clutch is on its way out, or the slave cylinder
  9. They should say on the base, also 1156 have one element, 57 has two
  10. What normal bulbs are you installing?
  11. Ok reverse lights check for a trans fuse in the fuse box, for the top bulbs I would be checking to see if you have a good ground
  12. if not put the old bulbs in and report back, I'm suspecting you got some bad LEDs
  13. all ive come out with is its a heat issue Hows your ignition switch(the one half way down the column? how are the fuse links?
  14. what happens if you install the old bulbs?
  15. we are in the jeep capitol is seems like
  16. when it dies, check for spark and see if theres pressure on the pressure gauge. Welcome @eaglescout526
  17. what leds did you buy?
  18. Do you mean the blinker bulb vs the brake bulb nope you said you replaced the flasher, did you replace both or just one, if just one swap it with the other flasher in there. or see if your hazards work at all
  19. switch the flasher pods
  20. Steak and potatoes for me Evap cooler or central ac
  21. jdog
    School test
    Yeah
