jdog
    2
Everything posted by jdog
  1. Yeah rent the tool it makes it a lot easier
  2. Are you sure the lights are good? How about the sockets? Bad switch, you say you have power to it but what about out of it
  3. jdog
    Whats in your cab
    First aid kit
  4. jdog
    Whats in your cab
    oh those, i thought they were not chrome, the lug nuts look like ones you can get from a auto parts store
  5. jdog
    Whats in your cab
    thats a bit hard with kids.
  6. Yes cherokee buckets will fit but you will need the floor brackets, either from the bench seat or @krustyballer16 Makes Em
  7. Yeah no bleed screw on the Mc you either have to pull and bench bleed or set up as I Do.
  8. the mc? its essentially the same as bench bleeding, I've got some hard lines that I use to go from the fittings back to the reservoir. then pump the brakes. I've heard on older units not to press the pedal all the way to the floor as the m.c bore will have imperfections built up. if you then press the pedal to the floor it pushes the seals past these and ruins the seals.
  9. this showed up in my feed
  10. I've got a bucket of bolts and nuts if you wanna sand blast them. if not this stuff is great for doing these
  11. did you bleed the master cylinder?
  12. and you stuck thru 2 days of it
  13. In all of the gears? My thought would be either drives shaft related or differential. I'd see if it does it in shifted into first gear. Other question is does it get worse the faster you go
  14. no, you can troubleshoot the front and rear seperate correct yes
  15. jdog
    Whats in your cab
    can you pm me a picture, you have me intrigued as ones that are not chrome
  16. so it turned out to be a combination of things 1st is the fuse box terminal block was broken from the one that feeds it. set up a jumper wire to feed the fuse. 2nd was a bad turn signal switch that wasn't working correctly and screwing with the brake lights 3rd was bad sockets in the front 4th ?? oh yeah and some bulbs. but I give credit to @Jesse J he's doing great at figuring it out and understanding my ramblings.
  17. jdog
    Whats in your cab
    At least he left the key, I Get a lot with no keys. But yeah you should check to verify you can remove it with the tools on hand. Jerky mmmmm
  18. jdog
    Whats in your cab
    I can see that with no doors, my flashlight is always dead
  19. jdog
    Whats in your cab
    Oohhhhh a flip screwdriver, hasn't thought of that
  20. jdog
    Whats in your cab
    Just bring it out here Pete we'll make sure nothing grows on it
  21. what did you end up deciding to do?
  22. Yeah I believe so, which means the bottle wasn't rated for the same pressure as the cap.
  23. I'm not to knowledge about the 2.5s is the tube they run for the egr, and I'm assuming yes, longer then the 4.0? @eaglescout526
  24. Thats a big car for that motor, would love to know the history and see some pictures of it.
