One more question, does the fuel pump motor run with the fuel pump relay installed? With KEY ON fuel pump will run for 2-3 seconds only and during CRANK fuel pump motor will run all the time.
That confusing since jumper wire is acting like a relay would. So with relay in, truck will START and RUN when fuel is added to TB, but will START and not RUN when fuel is added to TB using the jumper wire.
Without any proof, yet, I think the charcoal canister not only captures fuel vapors and purges them through the air box, but it also vents the fuel tank to atmosphere since fuel tank filler cap is not vented.
Connector in photo is C102. Should be C102_6 is for Fog Lamp relay, if equipped and should be Splice_H. Between the two (2) electrical manuals "Should be" might become a popular phrase for me.
The LH Door Jamb Switch (DJS) is a dual switch to ground. Test each side of the DJS for a path to ground when door is OPEN. Push pin in and out looking for make/break on your meter.
Upper right hand of screen. Click on Username. Click on Account Settings. Find and click on Signature. Add vehicle information here (YR, ENG, TRANS, etc, etc) and save. This helps everyone. This information will be available every time you post.
Internally you would need, lower gauge wires, in order to handle the increase in current flow. This would apply to everything; Armature, Commutator, Brushes, Field Coil. If you want a bigger burger (12vdc to 24vdc), you need more beef.
Fusible links can survive better in a under hood environment (weather wise). If you choose fuses (extra connections), make sure they're well protected. My 0.02¢
Couple of weeks is a good stretch. How much coolant did you need to add?
When engine is up to normal operating temperature, check/watch for air bubbles in the overflow tank.
