rokinn
Everything posted by rokinn
  1. Congratulations. You may want to pick your route with care if you plan on leaving in the near future. I70 is closed through Glenwood Canyon for the foreseeable future as is Hw 139 north of Loma near Grand Junction as is Hw 14 west of Ft Collins, all due to wild fires. Smoke in northern CO area is pretty bad. Current visibility is 2 miles. Two hurricanes due to hit the gulf coast mid week and move up through the Mississippi and Ohio valleys. I would expect a fair bit of flooding in that area. What's your destination?
  2. Comes up for me. 2 Comanches for $1600. $1300 for red one, tranny in bed. $300 for white one, has no engine or trans. Bed supposedly good.
  3. No guarantees the shop will know how to do it. Best to know the options yourself before hand and then ask them what they will do or what you want them to do. Turn on the air conditioner and look in the engine bay. The fan should come on. If it doesn't then something is wrong. You can run wires from the battery to the plug in for the fan on the drivers side to see if the fan runs. Just unplug the wiring and run wires from the battery to that plug. One from the neg post and one from the pos post. Black should be the ground wire. That will run your fan. If you don't want to do it let your shop do it. It could also be a bad relay in the circuit. The one for the fan is on the drivers side on the fender panel. The Macsradiator link I sent you can convert it to an open system. You just need to supply an overflow bottle to the system. If you go that route check back for options on bottles. I think your system isn't purged properly. If they didn't put a dealer thermostat in they should have drilled a hole in it to allow air to pass through. Find someone who knows what they are doing on how to purge the air. You don't need to go putting another radiator in it. Closed systems work fine when set up properly. BTW I put a 2 row radiator in mine. Some of the 3 row radiators had issues with durability as my first radiator replacement did. The Macs bottle is just about the same price as another radiator but the labor is rather less. If you go with another new open radiator you can use the current pressure bottle as the overflow bottle. Search my posts on how to do it.
  4. That's the whole shebang for the spare tire holder. Mine works fine. If you don't have the handle that operates the cable through the tube (it also operates the jack) you need to find something to take it's place. You might want to make sure the jack operates smoothly. I cleaned and lubed mine and used a drill to drive it up and down a few times. Does your electric fan come on when the engine gets overheated? How are you going about switching to an open cooling system?
  5. I bought one of these from NAPA a couple of years ago. I don't remember paying this much then but we know how that goes. https://www.napaonline.com/en/p/CRB226422
  6. Vented doesn't seem to me like the right part given we have a closed system. Give the hose a shot, it can only help.
  7. The top end Fram is supposedly decent but it's doubtful the shop put one of those on. You can pick up a Napa Gold one (what I would do) when you get the volvo cap there. I suggest taking your truck to a car wash and cleaning out the engine bay. The closer the better so your engine isn't too hot or let it cool for a bit before. Use the spray that comes out of the nozzle without pulling the trigger for the top side. The bottom you can use the full pressure. It will be a lot easier to track your oil leaks that way. I do this periodically with no problems. The one on the drivers side looks to be dripping off of the power steering hose. You can try tightening the hoses, or it could be coming from the cap. Just keep it full. The other side could be the oil pressure sender, the distributor, iirc there is a seal for the oil filter housing, or it could be the rear main seal as well. Or all of the above, as it was with mine. Leave the rear main for last. Could be a leak coming from the oil filler cap also. They all tend to migrate to the back. The oil leaks don't appear to be huge however so can wait also so I wouldn't worry. Check your oil level regularly when on the road. Take some power steering fluid with you also. Good to have another Comanche owner check things out with you. If you come through Loveland, CO give a holler.
  8. Have to admit I was disappointed with the loss of the completely off function in the S10 lights. When doing things to the interior with the doors open I would like to be able to turn them off. If you come up with something I would like to know also. As it is I can pop the cover and pop loose one end of the bulb but that's a pain.
  9. Post some pics of your engine compartment so we know what you're dealing with. http://macsradiatorshop.com/surge-overflow-tanks/replacment-jeep-radiator-fill-tanks-382.html http://macsradiatorshop.com/surge-overflow-tanks/replacment-jeep-radiator-fill-tanks.html The easiest thing is to swap out the current cap on the plastic tank with a volvo cap. If the air is purged properly from the system, which I would hope to assume is the case since you had a shop do the radiator replacement, then you should be good to go as far as the cooling system is concerned with this cap. https://www.napaonline.com/en/p/BK_7031396 You've done just about everything on the front suspension except the control arms and the steering damper. The cure is a nice addition but takes a bit of sanding on it to adapt to the Comanche. It goes on the drag link. The steering damper may have a wallowed out hole on the axle side. Worth checking. I had a thick hardened steel washer welded on the forward side of the bracket and it tightened it up plenty sufficiently. It's also possible to have a new bracket welded on also. Stock steering boxes are innately squirrely in my opinion. Just the way it is.
  10. Not sure from the photo if you're just looking for the exterior wipe or the interior also. I just bought this for drivers side exterior. Perfect fit just like original. It's also $5 cheaper now than when I bought it a few weeks ago. https://www.amazon.com/gp/product/B00QJAX95I/ref=ppx_yo_dt_b_asin_title_o04_s00?ie=UTF8&psc=1 For passenger side this.... https://www.amazon.com/gp/product/B00QJAX95I/ref=ppx_yo_dt_b_asin_title_o04_s00?ie=UTF8&psc=1 Beats the heck out of the cracked ones I had.
  11. rokinn
    Overland MJs
    A two gallon pump up pesticide sprayer (or two if you have the room) (new of course) works great for showering, doing dishes, or just hand washing. Left in the sun it will solar heat. Not quite as hot as say a solar shower or roof top system as shown above but certainly plenty adequate. I usually bring a solar shower along to supplement hot water. Dispose of any used water like dish water in a hole away from any stream or lake. Using compostable bags for the bucket toilet is a good thing environmentally. If you have the room, a bucket of sawdust is good for odors as well as the composting function or dried leaves from the surrounding environment will work also. Neither of these are a necessity though. I've always used down bags for lightness and compressability as well as warmth. Just don't get them wet. They need airing for a bit after sleeping in them for the night to get rid of accumulated body moisture. Coin tissues or compressed towels come in handy and are very compact. Add water and they expand to a 10" x 10" semi reusable towel.
  12. Depends on what one means by brutal. I spent a good many years living in Oregon (west of the Cascades). The rain and clouds a majority of the winter were too much for me. The humidity and cold, though admittedly not much temperature wise comparatively speaking, made me feel cold to the bone. The grey is tedious to the point that even natives get sick of it. It also has pretty high property taxes. No sales tax though.
  13. https://boulder.craigslist.org/pts/d/lafayette-wildernest-adventure-camper/7166776801.html Not sure if this works on SWB or not. Poster says it's 60 x 76.
  14. You might try a citrus cleaner on it next. I've gotten oil type stains out even after they have been through the dryer. They have spray type for clothes, another for BBQ grills, or just hand cleaner for mechanics. Enzymatic cleaners and odor removal for pets also. Nature's Miracle for example.
  15. Might want to check this on your steering column shaft for tightness.
  16. I use Meguiars Ultra-Cut Compound #105 to polish out turntable dust covers (by hand). It works quickly and looks like new except if there are deep gouges, but even those are much less noticeable. Works great on clear coat too. https://www.amazon.com/Meguiars-Mirror-Glaze-Ultra-Cut-Compound/dp/B001O7PNW8
  17. I would love to see an electronics thread. I'm definitely a novice but my winter time hobby is rehabilitating vintage audio electronics. I've done a number of turntables now and I currently have a Norwegian Tandberg preamp that I recapped and put in my system just for the phono stage. I got shelves of amps, preamps, receivers, turntables, and speakers in the cue. Hankering to fix a 200 watt rotel amp that has one rail that keeps blowing fuses when it has signal going through it.
  18. Posting has been deleted.
  19. I took a quick look at the sizing chart for the bike just now. It seems right for your inseam but small for your height. I had a road bike that was on the smallish side for me and it wasn't comfortable after riding for awhile. My mountain bike is just ever so slightly on the large size and is comfortable riding but having to come off it and straddle the cross bar is always just a bit concerning. I think it depends on what kind of riding you plan on doing. Smaller side for rough terrain riding. Larger for flat and road riding.
  20. Back on the ranch we used to haul wheel tractors and D4 Cats on a regular basis. Always used chain and lever binder cranked straight down from corner point to the bed with heavy wire from the lever handle to the chain so it wouldn't pop loose. Safest way in my opinion. Nylon degrades with time and exposure to UV. Was on a construction job years ago and we needed to stand up a pretty tall wall. Contractor hitched a pretty thin nylon rope to the top and used a vehicle to lever it up while we lifted and pushed. We stood it up but later that day I grabbed the rope which was mine and found it had pulverized into nothing but powder. Always a little leary of synthetic ropes and straps since. then.
  21. A lot of things to consider for this type of trip with a relatively unknown vehicle and not a great deal of time to do what might need to be done especially if you're doing it yourself. You might consider a pre-purchase type of evaluation from a reputable shop to help prioritize what you want to do and in what order. Cooling system is a biggy. Hoses, see if the water pump is weeping. If you're going to do the radiator then definitely the pump, hoses, dealer thermostat. I would do a 91 thermostat housing with a 3/8ths npt brass plug in the hole for the temp switch. Makes bleeding the air much easier. Make sure it cools properly before heading out. Front end and existing wobble would be another job to tackle before as well. Make sure the tie rods ends are solid. Look for rust along the edges of the lower ball joint seals. If the truck has had good servicing the uppers will likely be in reasonably good condition. New tires would be highly recommended and an alignment. Check the shocks. Make sure the steering damper is tight on both ends, axle side hole is prone to wallowing out. Wheel bearings checked/packed or replaced. Check the U joints on the drive shaft for play as already stated. Let us know how things progress. Good luck.
  22. If it were me I'd take Eagle's advice and seal up the transfer case and drive it home on the front axle. You're going to need to put a new U joint on the rear of the shaft no matter what. Since you already had it towed, if it was done on insurance then the next tow is likely on your dime. The miles ?? may make the cost prohibitive. You can then do what ever you're going to do at your leisure in your own space.
  23. My assessment as well ^ Also, why everything needs to be globalized into derogatory polemics about this or that group doesn't seem to further peaceful coexistence IMHO. They're all just opinions after all and not worth the paper they're written on, so to speak.
  24. I get offers pretty regularly. Most recently on Mother's day from the florist delivering flowers. She wanted to buy it for her daughter who wants an old truck. I get thumbs up from other drivers when I'm driving down the road.
