Everything posted by rokinn
"The Cure" from RuffStuff.............
rokinn replied to HOrnbrod's topic in MJ Tech: Modification and Repairs
I've done the ZJ V8 TRE upgrade but still have stock drag link. It looks like you bought the stock Cure p/n 2008 but linked to R1768 which is for the ZJ V8 TRE. I have the half inch pin on the TRE. Do you know which one I would need. I'm assuming it's the R1768. thx -
No lifts or larger tires are planned or desired. Right now I'm looking for more secure traction on mountainous dirt semi-steep and bumpy or rutted roads but good highway performance with possibly weight in the bed or towing of no more than 2500 lbs, preferably less. Right now I'm running 215/75/15 and like the way they handle. A gear ratio that will perform those functions as well as mountain highways. I don't mind shifting down but the 3.07 reaches the point of being kind of gutless on mountain highways. A 4wd conversion may happen but most likely not, at least in the near term.
Guess I didn't make that clear enough. 90 lwb 2wd ax15 I6. 3.07 D35
I picked up a D44 (3.07) from the JY from an 88 SWB 2wd MT w/280K on odometer. $100 plus tax and $25 core charge. I have a 90 LWB 2wd AX15 D35. Both are I6. The D44 is LSD. Pinion seal is clearly leaking and ever the slightest of end play in the pinion shaft. Backlash between pinion and ring gear is minimal and wear on both gears doesn't look too bad. Spider gears to side gears are pretty loose with a lot of visible wear with wobble on the spider to cross shaft (aka trashed). One axle tube seal is leaking. I'm looking for some advise on a reasonable course to take with this axle. Keeping in mind I'm hoping to keep this MJ build to a cost less than what it takes to put a kid through college. Axle seals and bearings are a given. Pinion seal also. I'll have to have a look at the pinion bearings but I'm not terribly hopeful. I'm considering the difference between rebuilding the carrier gears and trak loc or just going to a true trac. I would also prefer a 3.55 gear ratio but like I said, somewhere south of a college education. Thoughts please. Also will I be able to reuse my drive shaft? I know there is a difference in length but I've read where there is not enough to worry about. I've looked at disc brake upgrade but seems difficult for this axle. I've also seen where one can swap in a later model brake booster and keep the same Master. Thanks for opinions and corrections.
Thanks Hypoid, it's become a regular swarm of them down there it seems. Not sure if I will make this one as much as I would like to. Still recovering from a nasty bug. I appreciate the heads up. SOMEBODY got lucky and beat me out of a D-44! It was good to meet you, nice looking truck! We have a running thread for junkyard prospecting in the Colorado Chapter of NAXJA: http://naxja.org/forum/showthread.php?t=1090400&page=11 Thanks Man, nice meeting you too. Your timing couldn't have been more perfect showing up when you did. Helping me get that beast out of the JY and into my truck. I owe ya. Thanks for the link. I'll check it out. See Ya down the road. Cheers.
Thanks, I am considering going that route.
comanche overheating at highway speeds
rokinn replied to Newton's topic in MJ Tech: Modification and Repairs
Apparently CC will alter words it thinks are offensive (cook valve). Change the second O to a C and you have what I'm talking about. Might petcock? -
I had overheating issues as well with my 90 I6. I drilled a small hole in the top side of the thermostat. I've seen where they say do both top and bottom. It also needs to have the air bled properly. I installed a later model thermostat housing with the hole for the temp sensor. I installed a bleed valve into that hole (C#*@ valve???) You can do a search. If you don't find anything let me know and I will see what I can find for you. Mine is a bit different than the one on CC site. Solved my overheating issues except when I'm sitting in traffic. I'll probably do the electric fan upgrade at some point. -
And you know the difference between XJ and MJ bucket seat brackets. :) Maybe, someday, we will bump into each other and make the world a little smaller... Yes, perhaps! That would be good. Maybe CC members need a secret hand shake so we know who one another is beyond photos of jeeps and silhouettes. :cheers:
I have the tail lights and the tail gate that you can see are no longer there. I also have the emergency brake mechanism. I've been getting parts for VW's and Subaru's at this yard for a long time as well. This is my first effort at Jeeps.
The new door is $40.
Thanks hornbrod. I'm on my way to the JY today to pick up a ZJ sway bar. I can look there for a door also. I will also check with Yella.
I don't know if it is OEM or not, haven't looked at it yet. Not exactly sure how to tell either. Any suggestions on a supplier for w/stripping and door lock gasket?
I've had the panel off in the past and the hardware seems in good shape but I'm not looking forward to the r&r regardless. JY door I think it will be. Thanks.
I need to replace the drivers side door on my 90 as the bottom seam is rusted beyond repair. I have a line on a new door that has never been on a vehicle. No glass, etc. is installed in it. How difficult is it to R&R the components from mine to the new door. It will also need to be painted. Right now it's primed with a pin stripe already on it. Go figure. Or should I just wait till I find a door from a donor vehicle that doesn't need all the work. thanks
Renix MJ + 5 MPH wind or inline = can't hold 70 MPH
rokinn replied to 895XJ's topic in MJ Tech: Modification and Repairs
I just did the Volvo injector upgrade yesterday on my 90 renix. Took it for a short spin (less than a mile) afterward and was very duly impressed with the change in performance. Of course I'm running 215/75/15 on a 3.07 but happy with result non the less. -
Dana 35 to lsd conversion questions
rokinn replied to rokinn's topic in MJ Tech: Modification and Repairs
I'm running 215/75/15 AT's. A quick follow up if I may? Do any of these require the bracket welding for the spring over to under I seem to recollect reading about? Thanks again, I appreciate the help. Ron -
Thanks Pete, I've been thinking D44 lsd but saw this ad on clist and thought it might be a decent interim solution if not too difficult and not just a plain bad idea. I may or may not ever get around to doing a 4X4 conversion (gotta do it myself funds wise and I'm just plain getting old). Are 3.55 gears good? I won't be doing any heavy 4 wheeling. Might be pulling a light camper trailer. What are the best vehicle sources of D44? thx -
Meant 3.07 if I recall correctly. -
I have a 90 long bed 2wd with a dana 35 rear diff (9.07) and have a line on a lsd carrier with gears & bearings. Wanting some input as to work necessary for this conversion. Straight carrier swap? Will professional adjustment to gears be necessary? Thanks for any input. Does $225 seem like a fair price & what mileage is reasonable? Not sure of condition but wanted some idea about pros and cons etc. thx
WJ control arm swap axle twisted...help
I managed to get the axle turned using a combination of a come-a-long and a long pry bar wedged into the bracket that sits forward and to the top of the axle tube and a floor jack on the end of the bar. It worked pretty well for the drivers side. On the passenger side that approach didn't work due to the track bar mount etc. Used the come-a-long and the bar in the ball joint bracket and torqued on it. Also used the spring press as well as disconnecting the sway bar from the frame. Of course someone had stuck a #2 grade bolt (had a 2 on it anyway) in one of the bushing bracket holes which immediately broke off. Had to drill it out and tap it to the tune of several hours. Anyway the conversion is done. It's not a job for the faint of heart. Took me the better part of six days to do. It was a pita every step of the way. I am however impressed with the improved handling. The old control arms were total crap. No more shimmy and shakes. Thanks for the input. Will post some details about what's been done soon. I appreciate this site. Also didn't know it would be this much work when I bought this thing. rrm -
Thanks, much appreciated. -
First time posting to this site but I've researched a lot of info and appreciate all the tips I've picked up. So...I have the wj lca's installed but had the axle twist when doing the first upper. I've tried jacking as well as a come-a-long with no movement. Need half an inch or so to line up. Do I need to loosen any bolts or remove the spring, or disconnect the sway bar, etc. Any tips would be helpful. yes it's the proverbial pita. thx
