mnkyboy
Moderators
Everything posted by mnkyboy
  1. I built my own. mine are designed similar to the RRO brackets and made from 1/4" plate. The RE and RC brackets are pretty similar, between the two I would buy the RC brackets and just make a brace for them that fits the MJ and extends back to the crossmember.
  2. You could swap cabs but it would be a major project.
  3. They are just cheap steel 15x8 wagon wheels that I stripped and painted.
  4. I had a neighbor that went through a 4.0l and a D44, the original BA10 just keeps on going.
  5. I wouldn't go out of my way to swap out a good working one, but if it ever went out I wouldn't put another one in.
  6. I love my old scout II but it is lacking in the axle dept, ive got a drum brake LP D30 and a D44 hooked to a V8 and a 4spd. Luckily I don't plan to wheel it so it's fine with wimpy axles, I would like to upgrade the front to a D44 someday but for the disc brakes more then a strength upgrade.
  7. I've seen people straighten out D30s then put in an internal sleeve kit,its a cheap option that seems to work ok. Beyond that I would just build a different housing.
  8. I have a buddy who just did Explorer leafs on an soa MJ, he reported a gain of about 1.25" over stock MJ leafs.Exactly what I was hoping to hear ... Which sets the stage for the eventual gear swap from the XJ to MJ down the road. THANKS Keep in mind thats 1.25" over soa with a stock spring, you would need around 7" up front to sit level.
  9. I believe he said the leafs are a little thicker. My brother has been considering trying a set on his MJ,he is hoping they live a little longer then the stock springs.
  10. I have a buddy who just did Explorer leafs on an soa MJ, he reported a gain of about 1.25" over stock MJ leafs.
  11. At what RPM are these figures? From the charts ive seen the 318 is going to peak its torque curve before the 4.0l is really doing anything.
  12. That is the set up in the pic, its all currently coming off for a custom 3 link. The RC parts on the truck have worked well on that particular build.
  13. There are not many lift brands that I haven't messed with or driven on. I've driven RE long and short arm rigs and neither really perform any better then the equivalent lift from another company. Currently I have about 8 Jeeps sitting at the shop with varying suspension set ups,4 of them are MJs and different Jeeps are coming through all the time.
  14. Here is RC short arms and coils, if your head and shoulders ahead of this your flex must be amazing.
  15. The Behemoth is now mocked up on the 231, hopefully I can get some time and put it on the back of the AX15 so I can see how its all going to sit. I am already expecting to rework the floor a bit.
  16. 2.8l V6 yes,4.0l I6 no.
  17. I don't think its gonna suprise anyone without some work. 4.0l HO with an auto in a full size truck with 3.08 gears would be a dog.
  18. I did many rattle can jobs when I was a teenager, some looked ok but never really held up very well long term. If you have an aircompressor you can get a cheap paint gun and have a better more durable paint job for less then a case of spray paint. equipment paints are extremely cheap and are better then most spray paints, for a little more you could even get into a inexpensive single stage automotive paint.
  19. All that comes to mind is, anemic.
  20. 5" soa and 33s with minimal trimming and stock flares. 6.5" soa on 33s with lots of trimming and cutout flares in the front.
  21. Get on the 4bangerJP Facebook page and send Jeff a message, he will add you to the forum.
  22. No you can't swap bearings, if you look at your axle tubes they are flaired for the bearings. The c clip 35s are not so they are completely different where the bearings go.
  23. I linked 203 hardener which is for synthetic or alkyd,200 hardener is for acrylics. Ive used both hardeners in Rustoleum and both have worked though.
  24. Here is a decent and inexpensive one that I've had good luck with,most paint shops carry it. http://www.advantagerefinishproducts.com/hardeners/203-synthetic-enamel-hi-gloss-hardener
  25. It brightens the color a bit adds some shine and makes the finish more durable. Makes it look like a more expensive automotive enamel.
