Everything posted by mnkyboy
Mnkyboys 89 Comanche project
mnkyboy replied to mnkyboy's topic in MJ Hardcore Tech: Epic Journeys to Greatness
Haven't updated this in forever. After my last post I swapped the Mean Green starter for a Powermaster starter, the Mean Green was interfering with the inertia ring,the Powermaster doesn't have a nose cone so it fits much better and clears the inertia ring. I played around with the Megasquirt a bit and the truck currently runs and drives but needs a lot more tuning. Due to some big changes in my life, the truck has just been sitting in storage along with most of my tools and shop equipment, which is why there hasn't been any updates in so long. Hopefully this summer i can get to tinkering on it again.- 798 replies
- 2.5l
- supercharged
- (and 7 more)
It was nice to hear it, if only for a moment.- 798 replies
- 2.5l
- supercharged
- (and 7 more)
Spent the day tinkering on the 2.5l, got a vacuum manifold installed, made an auto tensioner for the supercharger, set up the hand throttle for the new TB location, and assembled a bunch of stuff. I was hoping to get it running today, i cranked it over but noticed it had no rpm signal on the laptop, after some troubleshooting I found that I didn't get a couple wires hooked up. I fixed the wiring and cranked it over again, surprisingly it fired right up but then died. While I was messing with it, the starter wasn't sounding great, after it started and died, the starter quit working. I pulled the starter and found the sprag had come apart jamming the starter. I just sent an email off to Mean Green about it, it should be under warranty. It was cool to hear it run even briefly, and it looks to have great oil pressure.- 798 replies
- 2.5l
- supercharged
- (and 7 more)
A little more work over the holidays, I made an adapter to put the 62mm TB onto the M90, it also turns it 30° so I can make an intake fit, the throttle is now working as it should and is running a stock 4.0l cable instead of the over complicated set up I was playing with. I also got the new injectors installed, and went through a bunch of stuff in the tuning software, I can fire the injectors and coil packs from my laptop which means so far the wiring is good.- 798 replies
- 2.5l
- supercharged
- (and 7 more)
I continued working on mocking things up and wiring up the standalone, I did get busy with other stuff and took a break from the truck for a bit so it's not as far along as I hoped to be but it's getting there. The crankshaft sensor was a big hold up, it was on backorder way longer than it was supposed to be and actually just recently showed up,so this weekend I finally got back to tinkering on the project and finished up a lot of the wiring, I also threw together a crank sensor mount.- 798 replies
- 2.5l
- supercharged
- (and 7 more)
Here's after the engine got sat back into the truck and I started laying everything out, I made a tube to hook the output of the M90 to the Laminova W2A intercooler, and put on the LS coil packs. While it was apart installed an aftermarket aluminum radiator and triple fan set up.- 798 replies
- 2.5l
- supercharged
- (and 7 more)
I've been slacking on updates. Here's installing the flywheel and inertia ring,again I had to clearance the new block for the inertia ring just like the last on. I stayed with a Centerforce conversion disc for my AX15 swap but went to a "stage 5" pressure plate that should provide a lot more clamping force than the stock replacement LUK I was running, it's supposed to go with an unsprung race type disc but I'm hoping by retaining the sprung Centerforce disc the clutch is still trail friendly.- 798 replies
- 2.5l
- supercharged
- (and 7 more)
For now. Next I get to tackle the stand alone, I've been waiting a few months for a Hall effect sensor for that.- 798 replies
- 2.5l
- supercharged
- (and 7 more)
Head gasket finally arrived, now I can finish putting the engine together and drop it back into the MJ.- 798 replies
- 2.5l
- supercharged
- (and 7 more)
The more I put together, the more it looks like any old 2.5l. Still waiting on the new headgasket to show up so I can finish bolting everything together and finally set it back in the truck, it was supposed to ship last week so hopefully I will have it any day now.- 798 replies
- 2.5l
- supercharged
- (and 7 more)
Did a valve spring upgrade to Comp Cams 983 springs, the engine is getting pretty close to being ready to drop into the truck. 20220612_082300.mp4- 798 replies
- 2.5l
- supercharged
- (and 7 more)
- 798 replies
- 2.5l
- supercharged
- (and 7 more)
- 798 replies
- 2.5l
- supercharged
- (and 7 more)
Did a little upgrade on the engine, these jets will spray oil on the underside of the pistons to help keep them cool. 20220521_113440.mp4- 798 replies
- 2.5l
- supercharged
- (and 7 more)
We will see, I need to get the engine built and back in the truck before I can start playing with the Microsquirt, you should have a headstart on me. There's a lot of people running them in the boosted 4.0l group, even a few with them on boosted 2.5ls so hopefully getting it figured out isn't too bad.- 798 replies
- 2.5l
- supercharged
- (and 7 more)
I also got a Microsquirt ECM so I can finally tune the thing, should help keep the engine together. The Microsquirt looks to be a lot more straightforward than the Speeduino I picked up so maybe I will actually install this one. I also got an Eaton M90 that I'm mocking up on one of my spare 2.5ls, the little Kenne Bell works pretty hard to make 10psi, the M90 should be able to make more boost with less effort and create less heat. I should also be able to keep it under the hood and out of the rain, the supercharger sticking through the hood is cool looking but not really the best location for something that's out in the elements.- 798 replies
- 2.5l
- supercharged
- (and 7 more)
I considered swapping in a different engine but eventually decided to stick with the 2.5l a bit longer. The last engine was basically a stock 0.060" over rebuild that I tossed a cam in, this time it's getting some upgrades. 2618 forged pistons and 4340 I beam connecting rods bushed for floating pins, they should put up with a little more abuse than the stock stuff.- 798 replies
- 2.5l
- supercharged
- (and 7 more)
The truck was having some pretty serious blowby issues so I tore the engine down to investigate, it wasn't pretty. Surprisingly besides the blowby and a slight tick at idle,it still ran pretty good.- 798 replies
- 2.5l
- supercharged
- (and 7 more)
Definitely not hardcore, but pretty much everything i do to the truck ends up on here, sometimes just to reference part numbers or dates later on.- 798 replies
- 2.5l
- supercharged
- (and 7 more)
US $32.33 34%OFF | for Jeep Cherokee XJ for Renault Jeep Cherokee 1984-2001 Front Hood Bonnet Lift Support Damper Gas Struts [Drilling Required] https://a.aliexpress.com/_mMoRJXW- 798 replies
- 2.5l
- supercharged
- (and 7 more)
A while back I ordered a cheap XJ hood strut kit, finally put it on today. Eventually I want to upgrade to stronger struts but overall it seems to work ok. 20220122_145539.mp4- 798 replies
- 2.5l
- supercharged
- (and 7 more)
I put the mean green starter in last weekend, the truck started but didn't crank as easily as it should have. I decided it was time to upgrade the batteries to something better suited for starting an engine. So the two 6 volts came out and a single group 31 AGM took their place. I also moved the battery from under the spare so now the spare tire sits flat in the bed.- 798 replies
- 2.5l
- supercharged
- (and 7 more)
New starter showed up yesterday, hopefully it holds up better than the cheap ones I've been running. Need to trim the nose a little to clear the inertia ring then toss it on and see if it's worth it's price.- 798 replies
- 2.5l
- supercharged
- (and 7 more)
- 798 replies
- 2.5l
- supercharged
- (and 7 more)
Got everything coated with Raptor liner, now to put everything back together. 20220101_163238.mp4- 798 replies
- 2.5l
- supercharged
- (and 7 more)
