Wiggilez
Everything posted by Wiggilez
  1. You come back to your comanche and find out that the mysterious puddle of fluid underneath it is not from you, but from the car next to it :)
  2. ah, so not close to any of us rigpigs..
  3. 131 000 KM mean Canadian, where you from?
  4. hello, I was wondering if anyone here know how much vacuum it takes to open the secondaries on the 2.8l carbed. Thanks
  5. I'm just compiling info right now, but like 88whitemance said I have also been on the lookout for a second gen dakotas, because if a find one I might be tempted to swap the trans sooner rather than later.
  6. So my truck currently has an ax-5 trans. When i get around swap in my ax-15 can i keep the ax5 master cylinder or will i need to find one fo an ax-15 also the ax-5 has an external slave and the ax-15 has an internal one. Thank you
  7. there use to be a free demo of one of there early betas, it doesn't have all the features of the new games, but the terrain deformation and basic gameplay elements were all there, and it had modding support too for extra cars and maps.
  8. that's what I did till I got un-lazy enough to put one in. except mine was closer to the 10-o-clock position
  9. I'm pretty sure that a stock 87 YJ got either a 4.2 I6 or a 2.5 I4
  10. just out of curiosity did you measure the before and after shift throws?
  11. So today I had to replace the alternator in my truck, the old one took a dump on my as I was driving through town, thankfully there was a part store about 15-20min walk both ways, but there were a few snags along the way, so I walk to the store to get a new alternator, but then decided that I didn't want to buy one because I was cheap (after having walked all the way to the store) so I walked back to my truck removed the alternator and pull in apart on the side of the road thinking I could fix it, so I opened it up found that there was a loose nut inside, tightened it up and go to go right? WRONG put it back together threw it back in the truck something spanked but I ignored (dumb move). get back in the truck I turn the key it starts a idles fine so I start driving and I hear a bang from under the engine and a cloud of white smoke comes out of my hood,so I pull over pop the hood take a look everything seemed go, and I was a block from the part store, so I said screw it. and drove it over, pull the alternator out again and brought it in for the exchange + cash for a new one, I should of just bought the new one to start with to save myself the trouble, also no pics cause my phone was dead the how day :/
  12. these trucks will fit 31's without lift, you just need to make sure that you're bump-stopped properly, especially in the front, also welcome to the addiction :P
  13. here are a few pictures of my GTS this thing is pretty rusty, might even give my comanche a run for its money on who's got more rust back door (driver) front fender this is the bad side of the car, the other side is also pretty bad, just not as bad as this one. also the other sides door is rust free as are the floor and unibody but, the ABSOLUTE best part about this car are theses :DDDDDDDDDDDDDDD for whatever reason I have always loved pop up headlights ever since I was a kid, and I think that these need to come back into automotive style, I meant if retro can be cool for clothing why not for vehicular appearances as well :)
  14. unless you want the lift in the front to even things out why not put cherokee shackles in the rear when you do your spring overhaul? you're going to have that all apart anyway.
  15. Go to the first post and hit "edit", bottom right corner. Then view the full editor, and you can change the title of the thread from there by typing something new in the box before you hit save. thank you, will do :)
  16. I don't know if it's possible, but I should really change this thread title to something else, like wiggilez's other addiction. anyway. I just bought another corolla today. this one is a 91 but its the GTS model, making it the highest trim level (I think,either this or the SR5 is.) this one has the 4AGE 4 cyl and the C52 trans, which the toyota guys say its the better of the two, the other which my 89 has is the C50. although this car had an all wheel drive option this one is only FWD, actully all-trac GTS's are super rare. anyway, if I can find an all-trac trans out of another gts or even the corolla wagon which the all-trac version are much more common and only fall into the slightly rare catigory, atleast where I live. I might try to fix it up, if not it's performenc parts are going on to the 4door sedan.
  17. You did a tdi swap and didn't tell us :( Jk unfortunately I'm not knowledgeable enough to help you. Hopefully someone who is can help :P
  18. Last update of my trip :) Home safe with the MJ .
  19. Live update #6 Got Dw agian and it knocked the cable lose killing the truck again. But I'm up and running hopefully this will be the last time till i get home
  20. Live update #5 nothing to report, but it's less then 90k till calgary :)
  21. Live update #4 ive made it to reddeer, soim half way there.no other incident thus far.
