Pete M
Administrators
    114
Everything posted by Pete M
  1. um, you can't have both a slip yoke eliminator and a slip yoke. I assume you have a slip yoke? pictures?
  2. and I, for one, can't thank you enough :bowdown: Brett! at least once a week someone asks me about shirts.
  3. you can't add a CV shaft without a SYE. they go hand in hand. :thumbsup:
  4. surprisingly few people seem to have done that. or at least very few who are here. this is a random MJ I found on the net. clearly not what you're thinking of.
  5. yup. but an SYE is out a bit more than it really should and still a great (albeit expensive cine you're on the hook for the kit plus a new driveshaft) upgrade. going SOA pulls the driveshaft out about an inch and in some cases this can cause problems in certain circumstances (especially if there is a lot of wear and slop at the yoke). since yours is a street queen, you should be fine. :thumbsup: in either case, a slightly longer driveshaft should return everything to normal. One caveat, U-joints don't like crazy changes in their operating angles. you can get vibrations from that alone.
  6. 18 gal is the shortbed tank. engine size is irrelevant. :thumbsup:
  7. in its heyday, my 88 had 5 1/4s components in the doors, tweeters above them, 6x9s in little boxes in the back, and an 8 inch woofer in a small box. all were high quality speakers fed from amps. I eventually did away with the 6x9s, as they added very little to the music. that let me run the fronts and woofer off of a single amp. for whatever reason, that little truck put out some of the best quality sound (loud or soft) I'd ever heard in a vehicle. :dunno: I everything over to my dakota and the sound just wasn't the same. :( weird. Go Comanches!
  8. Pete M
    merry christmas
    Merry Christmas!!
  9. I altered your title to help advertise the need. :thumbsup: If it's reasonable rust free, then it's likely worth the money. but it all depends on how much of a project you're looking for. wiring issues aren't fun.
  10. yup, its been done. :D but with some metal fabbin' effort for sure. now if i could just find that stupid photo.... :hmm:
  11. autozone will check your starter motor for free. :thumbsup: do keep an eye on where the shims went for re-installation.
  12. Pete M
    Pull a Part?
    yup, if you guys want to bring air tools, a CO2 tank is the way to go. :thumbsup: also, black and decker makes a cordless sawzall. I think it's in their 18 volt series.
  13. the proper length control arms should put the tire back in the center of the wheelwell automatically. :thumbsup: unless you get adjustable, which require some measuring.
  14. I'm just glad you asked. :D much better than buying a pair and finding out the hard way. :yes:
  15. Pete M
    Pull a Part?
    what brand/voltage is your cordless drill?
  16. oh there are plenty of differences. a cherokee donor would be preferable depending on how much you need from the donor. does the MJ have the complete wire harness?
  17. Pete M
    Pull a Part?
    says the man that lives outside the rustbelt... :yes:
  18. how much of the engine do you intend to use? what's wrong with the current engine?
  19. Pete M
    Pull a Part?
    cordless sawzalls aren't that much money. and the best blades I've ever used are the gold-toothed Lenox brand I find at Lowes. well worth the investment. :thumbsup:
  20. Pete M
    Pull a Part?
    cordless sawzalls are miracle workers. :D
  21. if it's not the ballast resistor itself, it sounds like that circuit might have a break in it.
  22. what axles/gears are you using?
  23. you'll never get 5" out of an AAL. so your choices are SOA or full replacement leaf pack. :thumbsup: what size tires are you looking to run?
  24. neat! :cheers:
  25. very nice Brent! :yes:
