Pete M
Administrators
    114
Everything posted by Pete M
  1. still broken. still can't find someone local that knows how to fix everything.
  2. please see CC rule # 1.
  3. snazzy! :drool:
  4. interesting thought. My sister's grand marquis has them. You'd have to tap into the wires where they are solid on, not blinking (in the steering column?). and I'd use a relay to power the new lights rather than hope the old wring can take the increased amps.
  5. there are links out in the internet for the old shop manuals in pdf form. that should cover the rebuild. :thumbsup:
  6. did someone sell an XJ? :brows:
  7. sounds like a good plan to me. :thumbsup: don't forget that lifting the front end changes your toe-in.
  8. easiest way is to give me the photo's address and I'll handle the rest. :thumbsup:
  9. the AX-5 will bolt up fine, but the 242 will need to be the older (and rarer) 21 spline variety or converted to be that from the later 23 spline.
  10. please post in the classifieds if the truck is for sale
  11. viewtopic.php?f=37&t=15899
  12. any idea of how much it would cost to ship it across the pond?
  13. might just need a sway bar and more caster. that assumes that nothing is actually broken.
  14. wheel bolt pattern is helpful too. :thumbsup:
  15. what are they out of?
  16. yup, sounds like 4 loosened themselves into oblivion and the 5th was snapped off. I'm assuming you tighten them properly (star pattern), then drive around the block a couple times, then re-torque?
  17. sounds like you need a D-60. :thumbsup: shouldn't be all that hard to find one with 4.10s.
  18. try car-part.com yet? and there are pullaparts in nashville and knoxville if you're at all close to them. a head there is only 37 bucks. exhaust manifold is 18.
  19. only some people say stock arms are good past 2". I am not one of them. and please don't redrill the track bar hole. that is insanely hack. :no: stock trucks can and do come down with DW. it just becomes more prevalent when lifted because all the geometry of the suspension changes.
  20. 3" on stock length arms?
  21. what else have you replaced to combat the DW?
  22. I've purchased whole trucks for that. :ack: try car-part.com or pullapart.com (to see if there's one by you)
  23. there are comanches in europe already. I don't remember seeing any yellow lights out back in any photos. :dunno:
  24. good to know! but sounds a bit scary to me.
