still gutted and half-hovering on jackstands. but the glass has all new seals and I've got a ton of new parts waiting to go in once I finally get the cab watertight. it's reeeeeally close to finally getting out of the "fixing" phase and into the "reassembly" phase. I just keep finding problems.
(I couldn't get that leak to reoccur with the hose so we moved the canopy. the rain did the trick and now it's covered again)
if anyone has a dribble of water coming down in the passenger side corner of the floor, this might be your culprit. you must pull the hvac to get at it.
I think this truck suffered from every single possible water leak save for a sunroof (but only because it doesn't have one). the good news is that it's a southern truck and the rust up in that corner is just surface and can be dealt with without welding. there is a patch needed on the floor though.
these are just the ones I found on the pass side
looks like the Bronco Graveyard has some lower gear 44 posi's for $250
https://shop.broncograveyard.com/D44-OE-Spicer-Trac-Lok-392-and-Up-Complete/productinfo/22096/
can't beat nos if you can find it. If I remember right, I believe the auto version will work too by just not plugging that second plug into anything.
https://www.ebay.com/itm/225185170978
ax-15 didn't come into play until mid-89 and was only available behind the 4.0 (in Jeeps at least)
the ax-5 and ax-15 have essentially nothing in common but the manufacturer.
dear spammers:
someone might fall for one for these. no one is going to fall for any of these when they get 20+ a day. especially when they don't have any accounts with any of the "companies" listed.
sorta. it has to do with how a camera saves the orientation of the photo. it's been explained to me and... it's complicated. I've found that if I rotate the image, than rotate it back and resave, it usually uploads properly.
