114
Everything posted by Pete M
found some time to found some time to drill new holes and get the new hotness mounted up. and then proceeded to wrench my back pretty good because I tried to push it back into it's spot by myself because I'm an idiot. I'm still not keen on the bling-factor, but the usuable space inside is just plain awesome! I can fit a milk crate or rubbermaid tote inside with ease. that means I can get organized and also separate the heavy items from the fragile ones.
Cherokee vs Comanche Blower Motor
Pete M replied to Cali Cruse's topic in MJ Tech: Modification and Repairs
should. but in any case, it's above the passenger's feet held in by a couple screws needing I think an 8mm socket. -
if you're on a laptop, you should be able to just drag your pics right into the text box.
just make sure it's not the resistor pack or the ground. hate for you to do all that work if it was something simpler. -
I'm sure a lot of us have offhandedly said we'd stab any dope that touched our trucks, he just got more of an opportunity than most.
run power and ground to it. if the ground is insufficient, the 12 volts has no where to go. oh, and corrosion can creep into the rear harness connector right behind the rear tire. if the ground wire connection inside there is kaput, the pump can't ground.
I've always preferred to make my own since I can't stand cheap bandaids (the things I use the most in any kit), regular gloves don't ever fit, and I react to some meds. found a $20 general kit on ebay that seems to have an ok list and comes in a waterproof case. could use more trauma ingredients though. https://www.ebay.com/itm/First-Aid-Kit-Home-Survival-Tools-Box-Emergency-Bag-Waterproof-For-Medic-100-Pcs/253932460670?epid=17016561465&hash=item3b1f8dda7e:g:SNsAAOSwQF1bwk4e:rk:2:pf:0 re-edit: here's a clotting sponge to add in: https://www.ebay.com/itm/QuikClot-1st-Response-Advanced-Clotting-Sponge-Free-Shipping/153201836071?hash=item23ab8a8027:g:WF8AAOSwYNlbsjCI:rk:1:pf:0&LH_BIN=1 I would also add in a couple tiny bottles of super glue (fast drying, aka NOT the gel type) because they are fantastic at gluing sharp edge cuts back together. and personally I like to add in a shot of JD. (not to be taken if you are already bleeding profusely!)
the 03-07 Libertys came with the stronger 29 spline 8.25 (disk brakes and 3.55/3.73.4.10 gears) but is actually a bit wider than the stock MJ axle rather than narrower like the 8.8. the extra width helps match the MJ's wide butt (the rear of an MJ is wider than an XJ, that's why the rear tires look tucked-in). car-part.com can help with your junkyard searches. be sure to search for various years because part numbers can change even though the swap-ability didn't and the website searches only by part number.
thieves are usually not too bright. happy the truck is back home time to install some anti-theft measures!
big hello from Loganville! be sure to fire up a build thread!
lol depends on if your definition of a trar is a car tweaked into a pickup, or a car placed on top of a pickup frame. one is a quaint OEM novelty and experimentation of blended automotive design, the other is routinely ridiculed for its poor execution.
I used a ton of caulk on the engine side.
I added a new ground to the harness right by the pump. 12 volts doesn't mean it can also push the amps through. but also the current crop of chinese fuel pumps can't be trusted so you may need to pull it out for a closer inspection.
that could be how it looked when new. I don't have one to compare. but I'm curious so I'm going to move this over to Tech and see what the others think. I'd hate to see you spend money when it was just a weird casting from the start.
goes right in. just don't forget down the road that any brakes/rotors/etc that you do to this new axle must be for a 98. lots of changes happened over the decades that the dana 30 was used and the individual parts aren't necessarily compatible year to year.
see, what you need is one like mine. it came with a no-more-power-outages-longer-than-a-couple-hours-ever-again guarantee. apparently. I've yet to fire that thing up for anything other than an annual test run. humor aside, I love generators. such an incredible piece-of-mind purchase.
lol. creativity run amuck! love the chariot made from a motorcycle second thought... how well do these things stay cool? I see a lot of extra weight and, um, stuff blocking the radiators.
My "new" 88? (Formerly: Granite State Clean-up - '90 MJ)
Pete M replied to NHMJXJ's topic in Member Projects: Your Comanches
just a fantastic looking truck -
Making XJ buckets work in a MJ
Pete M replied to mfpdm's topic in MJ Tech: DIY Projects and Write-Ups
well, when you do it, shoot a video to share! someone needs to be first. -
holy crap that place was decimated!
I posted your link over on facebook for ya, Steve
it appears to me you have an aftermarket bumper with generic adapters that lowered it down a bit more than normal. pics of the attachment points between the bumper and frame brackets should answer what's going on.
2018 Midwest CC PowWow - Badlands, Attica IN on August 25th
Pete M replied to 89eliminator's topic in The Pub
bump for some good memories -
Best tires for off and on-road?
Pete M replied to ruralandalone's topic in MJ Tech: Modification and Repairs
I'm not kidding. 2 sets! (although admittedly there are some very nice compromise tires out there that can do both jobs) -
yeah, the more I think about it, the more I may need to do this with one of my MJ buckets...
