Pete M
Administrators
    114
Everything posted by Pete M
  1. interesting. I wonder if the linkage is just a hint out of alignment.
  2. I will never tell you to stop spreading your ideas on using 2-low.
  3. a posilock would negate needing that switch, yes. or just bypass the CAD and forget the system ever existed.
  4. the best reward for a hard day's work.
  5. I applaud your patience with that bed.
  6. Pete M
    1JTML6317JT136978
    be sure to start build threads for those too!
  7. moved it for ya.
  8. yeah. welcome to MJ ownership.
  9. it only secures the leafs together. and the head should be in the leaf pad (meaning if SOA it should be inverted.) the shock plate has a hole to clear the nut.
  10. also Weird Al, because he's awesome
  11. still one of my favorite albums of all time. I... I don't even know which song to share! so here's the entire concert. you're welcome. Even if you're not into heavy metal, give the first 5 minutes a listen. epic. just epic. such a brilliant mashup of different styles of music.
  12. not a dang thing. it sucks being stuck so far from them.
  13. ah, the slow drag races. they're the best! I once raced a beat-to-snot 80s car full of teenagers with my Liberty (I was hauling 11 exploder 8.8s in a trailer). I slooooowly crept away from them. we all had a good laugh at the next light. this time I added some boost before the green popped and got a good jump on them before entering the freeway.
  14. you'll fill it through the fill hole until it won't take any more. it's situated at that exact spot for that reason. obviously this will need to wait until you've installed it back into the truck.
  15. your t-case should be able to be shifted into hi-range on the fly.
  16. Pete M
    1JTHL6310HT182860
    yup, we need a VIN then go start yourself a build thread and tell us all about the adventure.
  17. what all doesn't work?
  18. that is a gloriously sharp cutoff ya got there.
  19. wow, that got down into your frame even more than most. but as I say, if it's steel, it can be fixed
  20. spray foam sucks it's a modern day "stuffing newspaper in there to hold up the bondo"
