Pete M
Administrators
    114
Everything posted by Pete M
  1. just measure the diameter of the metal tube. the hoses are very standardized (1/4, 3/8, etc) so it's likely obvious which it is. don't assume that the pressure is the same as the return though. measure each hose's tube. and take note of all the other lengths of rubber hose along the entire path so you can do them all at once. I'd probably plan on repalcing all the clamps too. oh, and Lowes is the best place to find stainless steel hose clamps. waaaaay cheaper than the auto store.
  2. I would replace all of the rubber hoses. including the one inside the tank. you must use hose rated for fuels.
  3. I wouldn't mind replacing all the 30 year old rubber bits anyways. but yeah, if it's got a crack in the metal tube, the new hose won't fix that. things that should be replaced as preventative maintenance on a 30 year old truck: anything made of rubber. (brake lines, fuel lines, coolant hoses)
  4. did you unplug the ground?
  5. take note that the filter has an arrow indicating direction of flow. and you never need to apologize for asking questions. its' what we're all here for.
  6. I can never know for sure since I have to go where my buyers are.
  7. normally I don't like counting my chickens ahead of time, but I'm quite happy I found this little guy. should be here in a few days.
  8. that's a good idea. now that I've got a method for reproducing the racing poster, I bet I can do the same for the dealership posters too. though that's a lot of work fixing all those creases.
  9. there's contact info out there for the Jeep archives!?!?
  10. Pete M
    Tool Talk
    yup, it may cost a lot of pennies, but it's worth all of them.
  11. out doin' truck stuff.
  12. @Backdraft Caleb, if he doesn't reply you might want to start a new thread in Tech where more eyes will see it.
  13. in regards to painting or to the chip in the bead?
  14. what has gone wrong with the current trans?
  15. looks good, just needs some finishing with new tail lenses. bring a small fridge magnet to check for bondo in the usual places.
  16. anyone happen to have a phone number for him?
  17. how exciting! you've been running every day, right?
  18. https://www.youtube.com/watch?v=guKoNCQFAFk somehow there's an age restriction on a Janis Joplin album?
  19. I'm sure youtube has some intro videos on using your new toy.
  20. did you check power at the battery terminals? that will confirm that the meter is set right.
  21. also the steer horns on the front of the limo are just the best.
