Man. Yall know I've been fighting issues with my MJ for a while. Ya'll ever get so discouraged and borderline fed up with it and start toying with the idea of selling it? Have any of you been down this road before and know if it's a good idea or regrettable one? Because that's where I'm currently at. Discouraged and pondering the idea of "the little red wagon" getting a new home
  • Replies 80
I know the feeling. I purchased my longbed in april of 22 and I have driven it all of about 3 miles since. I put about 4 months straight of work into it and it's still not ready for prime time. I did:
  • grounds
  • 1/2 of cruiser54 tips
  • welded in new floor
  • new vinyl floor and liner
  • brake booster + master upgrade
  • new brake lines
  • new front brake calipers and rear drum cylinders
  • new distributor, adjusted the rotor
  • cleaned all the plugs and checked gaps
  • removed, cleaned and filed valve cover
  • cleaned top of head
  • cleaned out throttle body and sensor
  • replaced vacuum lines
  • replaced and siliconed firewall plugs
  • new rims and tires
  • flushed coolant
  • new water pump
  • new antenna install
  • new coolant tank
  • full gauge cluster mod
  • new belt tensioner pulley
  • horn replacement
  • ignition coil cleaning
  • oil change
  • o2 sensor replacement
  • parking brake cable replacement
  • cylinder compression test
  • new thermostat
  • wilwood prop valve install
  • cleaned up the light sockets all around
  • swapped brake pedal and brake light harness
  • seat bracket welding
  • fuel filter
I'm sure I missed a bunch. My comanche needs a new exhaust manifold to pass inspection and I'm really dreading that upcoming job. It's also in the 10s-20s most afternoons so I really am pushing it off until spring.
Sometimes it helps to take some time and revisit the problem later. That's what I do. I search around on comancheclub for folks wiser than I, and their repair methods and techniques.
My current to-to list:
  • Exhaust manifold
  • fix gauge cluster PRUNDL indicator
  • entire front suspension. everything.
  • entire rear suspension. everything.
  • differential inspection, fluid change
  • install rear spare tire
  • radio + speakers
  • new door seals. Using adhesive foam as a temp fix.
  • complete vehicle paint. paint flaking and peeling everywhere
  • pray to the jeep gods and try to find an affordable original LWB Rollbar
Project fatigue sucks. Only way I've figured out a way to stave it off it is having a car that I don't have/want to work on that I need to depend on, just a simple driver. That way I can chip away on the project in spare time. If you got a long list of "to do's" get's to be tough because you just want to enjoy it. Only project I've regretted selling was my old K5, needed some little things but had so much done and I didn't drive it much. Decided to sell it to help buy a house still kick myself. I will say the feeling of accomplishing and enjoying a project is an awesome feeling.
Yeah well my Monte Carlo is in the shop for a whole cooling overhaul. The truck runs good. It runs so so good. My discouragement is my radiator as you may have seen/know. I have now sprung yet another leak in the radiator I have. I have a brand new one sitting at the house but waiting to get my car done first. So now as we speak I'm driving my truck with it leaking even more. I'm nearing the point of posting it up for sale along with all the goodies that comes with it like spare parts, documentation of purchase, part receipts and service records since I've had it and has no rust. I've dumped over $800 in radiators alone. I'm just trying to figure out my situation and have a truck that doesn't leak. All my truck needs is a non leaky rad and new exhaust. That is all it needs. I'm going to try the one I have now when I have it installed. It's such a good truck but it is just causing me stress and making me not want to work on it with how many times my radiator has went bad
If it were always fun and easy, everyone would be doing it. That truck has sentimental value to you. I say keep it. It’s soooo close to being a good, drivable truck.
True. Very true. It just seems as soon as I fix a problem another rears it's ugly head. Yea it does have major sentimental value to me but....it's just getting to the point to where it feels like your losing a uphill battle. But I'll try out a handful of stuff to try and get it straightened out for the long run. So for now I'll have the radiator put I'm. Park it and rarely drive it. My Chevy has a 3.8 and it's been a fantastic car. So in the meantime I'll push aside the selling thought. I'm thankful for it and thankful I was able to get my hands on it. Thankful I'm here too. Hopefully this radiator I'm going to have put in is the charm I need
You’ll never get a truck like the one you have now ever again, it’ll always either need more work, not be what you want, or be even more money.
I have buddies that sold their cars and trucks that they liked over an issue they kept having, and then they regret it and always say how they wish the never did.
Just take a break before you make a decision you’ll regret, and if you decide to, then just make sure it’s the right decision.
Seems your radiator is your biggest problem. Radiator shouldn’t be a big problem to overcome.
What kind of radiator do you have?
Was it new or rebuilt.
I have had good luck with Spectre radiators from the parts store. It’s chinese so not ideal but l never had trouble with the ones I’ve had.
2 maybe 3
1 hour ago, Smokeyyank said:
Quote
Thats a good term I've been dealing with myself, but not with my Jeep. My 70 Torino GT restomod is SO close to being done but I'm totally burned out on it; havent touched it in at least a year. The Jeep is my alternate project to keep me distracted and having something else to do.
I also had the same lack of motivation last fall with trail running. I completely lost interest in running for a several months and completely stopped, then suddenly poof I find myself signing up for races and now I'm back it. No idea what that was about, other than taking a break.
I’ve also never had issues with Spectre radiators.
But one way to avoid the burnout is to do your own work. If you have to pay someone else every time something goes wrong, it’s just an extra gut punch you don’t need. Especially something as simple as a radiator. When I did mine on my first MJ, back when I was still sorta guessing at what  I was doing, it was so easy that I spent a few years wondering what I could possibly have screwed up, because it just seemed to go together too well. But it’s been ten years and still nothing’s gone wrong with that rad install. It’s just bolts and a few hoses. And given yours has been out a couple times recently, you won’t even be fighting with old stuck on hoses or seized fasteners.
Yeah there’s a learning curve. Yeah it’s nerve wracking when you’re not confident in your abilities and you don’t want to screw up your baby, but take your time, make sure you’re not rushing things, if you’re unsure about anything stop and ask questions, and honestly Google is your friend. Even as a professional I Google things all the time. No shame. Pick a weekend. Invite a friend over, doesn’t even need to be someone super mechanically inclined, just someone who’s there for moral support. And just do it. Start small and eventually you’ll be rebuilding engines with the best of them.
Same here re the Spectre rads.   I put one in both my MJ & XJ about a year and a half ago and so far no issues.   I got them from Rock Auto.
100% agree. Even if it's the simplest things. I can't imagine paying someone to swap out a radiator. I spent yesterday putting the trailer hitch on my MJ all by myself, and it was nice to be outside wrenching, if it took me longer because I was by myself.
Alright so the radiator I got off rockauto is the all silver one. The black one I have got from napa and have now waiting to be installed. Now the all aluminum one I have bought 2 of. Both failed. This is why I'm so frustrated. I also have no tools. That may be a shock but I legitimately don't. But the aluminum ones are the ones leaking on me. Those are the only ones I've tried granted. See since my plastic reservoir cracked and split on me 3 times in a row on different ones I am so skeptical of plastic hence my logic of buying all aluminum. Do you guys run the ones like I got from Napa? I do know if I sell the truck I will never ever in my lifetime find another or get it back. I'm just stuck right now
Well the thing of it is my truck is a open system. I have a Mac tank and catch tank he installed. I've had 0 issues from it. The guy that has been working on it is @dasbulliwagenand is a mechanic at the chevy dealership I go to. He works on it there. He's done lots of work to my truck but the radiator is the only thing giving me issues
If you don’t have any tools, I’d seriously start investing in at least a basic mechanics tool set. Should be able to handle a large amount of jobs on an MJ, including replacing the radiator.
Can’t speak to the quality of the radiators, odd that you’re getting so many issues (plastic tanks cracking, leaking from all aluminum).
I'll look into some tools soon. What would be some possible causes of the radiator leaking on me? It's not coming from the hoses. It's coming from the radiator itself. Poor quality? Something else? Because my system is open meaning I think the pressure is able to exit via a tube on the top of the catch tank when it cools off (please correct me if I'm wrong). My engine isn't overheating and runs fine. I also can't just keep going through radiators like underwear either
How's this? So the Mac tank holds my coolant. My coolant gets spit up into the plastic tank as a holder. And it has a clear hose at the top that can puke out coolant if for whatever reason it gets that full
I've felt this many times, I almost took a ball peen hammer to it out of frustration ( this was a long time ago, and I was much younger). I would recommend what others have said and take a break from working on it, the fatigue and frustration you are feeling is completely normal.
Well the top of my engine is leaking oil. It does leak. So. Wait. Hang on. So where do I get another tank like the oem one? I have mine but it's cracked from being old and usage. Rockauto ones are absolute crap. I now am so clueless and I just...I don't know what to do now. Now I'm nervous to drive it
The knock off aluminum rads fail.....a lot. There's a reason the mishimotos are stupid expensive, but still not 100%. Open conversion is easy should be a write up in DIY section. As for a new pressure bottle.
I believe you can use the Volvo one. Add replace mine years ago and I'm pretty sure that's what I did.
Also echo what others have said about getting your own tools. Harbor frieght is great for decent and cheap tools. You don't need to have a full on tool box but a couple hundred bucks there sets uou up nicely. Good simple hands tools work wonders.
21 minutes ago, Classy Comanche said:
What do I need for a true open set up? Now I'm super super lost on what I need since I thought I had open system this entire time. Man I feel so dumb now
Honestly, don’t need much, and it’d be simpler than what you have now. Here’s one of the writeups:
Understanding how systems work is 3/4 of the battle.  You're going to have to spend a lot of time understanding an visualizing the animal you are dealing with.  You tube videos will give you a visual.  Others will give you a how to in terms of how to repair.  I don't know where you are on the curve of all of this and your talents but drive ability is the first thing if you want any sense of payback and pleasure for all of your efforts.  All the other is just (don't she look good).  Focus on learning how understand the issues and how to deal with them in your vision and the time line expectations.  Time and experience go a long way.  The alternative is to sell it if it is too overwhelming.  Something like this a little later in life may well be a different story.  Challenges are great is you can handle them, overwhelm not so much.  It ain't t the be all end and end all by any stretch.   Comanche addicts may likely disagree.  Unfortunately I have the addiction as well, but it ain't the first addiction I've had to deal with in life.  Good luck!
OK I read the write-up. Maaaan it sounds so complicated yet so simple...the part numbers....didn't exactly line up. But I got a hit on a radiator potentially which I have posted below. I am worried about it hitting something or not being able to go in correctly. So. To my understanding of my....deal. is that I need a radiator that has a cap on it. My Monte carlo has one. Get a pressure cap that has a heat gage on it that tells temp (Absolute lifesaver since I got dummy clusters) and get a overflow tank which I already have as seen hooked to my Mac tank. Now. The hoses. Is there anything that needs to be re-arranged when doing this? I'm getting a sense of hope back here and not feeling like running it into a ditch being hopeless and uninterested. So far everything is clear and like I sort of understand how this stuff works. I essentially am blowing out my own radiator.....wasting my hard earned money. Its just the hoses and bottle I'm unsure on...I've wasted my money so far. I want to ensure this indeed will work
I also watched a bleeping jeep video on how to do the conversion. The part where you cut the heater control valve. When it comes to stuff like that I get nervous. However I will say even with the heat off I will occasionally hear a small squeak sound like something moving on my passenger side inside my dash and I can feel heat like blow through very gently.
