Drilled a series of 5/16” holes, one inch apart, in the sleeping platform support poles to receive locking quick release pins and added adjustable feet for fine adjustment. Originally they had hose clamps but they would always move when load was applied.
  • Replies 175
Posted Images
One thing missing from our setup is shade over the cooking area so I got an ARB 8’ x 8’ awning. To mount it I attached 1 1/2” zinc plated perforated tubing to both sides of the bed front (spaced out with some flat bar to clear the bed lip) that 1 1/4” perforated tubing will slide into. Slots had to be cut in the backs of the 1 1/4” tubing to clear the bolt heads holding the 1 1/2” tubing, nutserts were added for threaded knobs to keep things in place, height adjustment and storage. At the top of the 1 1/4” tubing I attached Ironman 4x4 awing quick connects to make installing/ removing of the awning easy. The plan is to carry the awning on the FJ Cruiser’s roof rack and assemble at the campsite. The propane box had to be moved forward about 1 1/4” so the opened lid could clear the 1 1/2” tubing which then required a hitch extension for the FJ Cruiser’s rear door to fully open without hitting the box. I used my 20 ton press with a 2” ballbearing to pinch the extender and hitch together at the hitch pin hole so it wouldn’t rattle.
I was going to ask about this. It looked a little wide. Should be super nice for keeping things shaded and dry.
Technically it is of legal width for road use, limit is 102” and it is 101.5” but I wouldn’t be comfortable.
Oh wow, that’s close! I wouldn’t be comfortable with that either. Plus it just sounds like a reason to get stopped frequently.
Change of plan, instead of carrying the awning on the FJ I decided to keep it on the trailer. It only weighs 43lbs but it’s long and takes a little back and forth to get it into position on the FJ. All I had to do was attach a modified dual hitch extender to the hitch end plate (using existing holes :banana:) and use the supports that are used for the front with a few modifications. Now it’s very easy to load/unload, we’ll see how stable it is and modify from there.IMG_5330.jpeg.394e00f01dc18638bbad3811692810bf.jpeg
Went camping last week to try out the new gear, it's great going during the week after schools start, no one else in the campground. Storage of the awning on the side worked really well, no vibrations and very sturdy. The awning has an integrated LED strip that can be white, amber (reduced insect attraction), or both. It requires a 12v power supply so I got a small AGM battery, put it into a Harbor Freight plastic 50mm ammo box and added a 12v cigarette lighter adapter, hardly drained the battery at all over the entire week.
  • 5 months later...
First camping of 2026 and with the new pup at New Hogan Lake in Calaveras County, CA. Perfect weather, 68° highs and 45° lows.
  • 4 months later...
Well in the F’ed up mind of someone at the California DMV “HAF JEEP” is considered “derogatory or offensive”. :nuts: So I’m passing on a personalized plate, DMV doesn’t need my money anyway.
Made some lower shock mounts for the camper and installed Monroe 555003 shocks. Probably not the best design but for a camper that gets used maybe a half dozen times a year I think they’re sufficient, especially with using materials just laying around.
  • 4 weeks later...
Out camping this week. The shocks seem to have decreased the amount of roll, however this is empirical from viewing it in the side view mirrors. The dirtbags are tuckered out.
