fiatslug87 Posted April 28, 2025 Author Posted April 28, 2025 2 hours ago, 89 MJ said: You’re running out of amenities to add . I enjoy seeing updates on this thread. It sure would look great hooked up behind the white truck too, like the pic in your sig. Appreciate that. Maybe I’ll have to set up a “glamour shot” since we can’t take the MJ camping due to space considerations for the dogs.
89 MJ Posted April 28, 2025 Posted April 28, 2025 That is one of the struggles of the MJ. Little cabs aren’t friendly for many bodies.
fiatslug87 Posted May 2, 2025 Author Posted May 2, 2025 Drilled a series of 5/16” holes, one inch apart, in the sleeping platform support poles to receive locking quick release pins and added adjustable feet for fine adjustment. Originally they had hose clamps but they would always move when load was applied.
fiatslug87 Posted June 17, 2025 Author Posted June 17, 2025 One thing missing from our setup is shade over the cooking area so I got an ARB 8’ x 8’ awning. To mount it I attached 1 1/2” zinc plated perforated tubing to both sides of the bed front (spaced out with some flat bar to clear the bed lip) that 1 1/4” perforated tubing will slide into. Slots had to be cut in the backs of the 1 1/4” tubing to clear the bolt heads holding the 1 1/2” tubing, nutserts were added for threaded knobs to keep things in place, height adjustment and storage. At the top of the 1 1/4” tubing I attached Ironman 4x4 awing quick connects to make installing/ removing of the awning easy. The plan is to carry the awning on the FJ Cruiser’s roof rack and assemble at the campsite. The propane box had to be moved forward about 1 1/4” so the opened lid could clear the 1 1/2” tubing which then required a hitch extension for the FJ Cruiser’s rear door to fully open without hitting the box. I used my 20 ton press with a 2” ballbearing to pinch the extender and hitch together at the hitch pin hole so it wouldn’t rattle.
89 MJ Posted June 17, 2025 Posted June 17, 2025 59 minutes ago, fiatslug87 said: The plan is to carry the awning on the FJ Cruiser’s roof rack and assemble at the campsite. I was going to ask about this. It looked a little wide. Should be super nice for keeping things shaded and dry.
fiatslug87 Posted June 17, 2025 Author Posted June 17, 2025 12 minutes ago, 89 MJ said: I was going to ask about this. It looked a little wide. Technically it is of legal width for road use, limit is 102” and it is 101.5” but I wouldn’t be comfortable.
89 MJ Posted June 17, 2025 Posted June 17, 2025 46 minutes ago, fiatslug87 said: Technically it is of legal width for road use, limit is 102” and it is 101.5” but I wouldn’t be comfortable. Oh wow, that’s close! I wouldn’t be comfortable with that either. Plus it just sounds like a reason to get stopped frequently.
fiatslug87 Posted July 1, 2025 Author Posted July 1, 2025 Change of plan, instead of carrying the awning on the FJ I decided to keep it on the trailer. It only weighs 43lbs but it’s long and takes a little back and forth to get it into position on the FJ. All I had to do was attach a modified dual hitch extender to the hitch end plate (using existing holes ) and use the supports that are used for the front with a few modifications. Now it’s very easy to load/unload, we’ll see how stable it is and modify from there.
fiatslug87 Posted August 31, 2025 Author Posted August 31, 2025 Went camping last week to try out the new gear, it's great going during the week after schools start, no one else in the campground. Storage of the awning on the side worked really well, no vibrations and very sturdy. The awning has an integrated LED strip that can be white, amber (reduced insect attraction), or both. It requires a 12v power supply so I got a small AGM battery, put it into a Harbor Freight plastic 50mm ammo box and added a 12v cigarette lighter adapter, hardly drained the battery at all over the entire week.
fiatslug87 Posted February 4 Author Posted February 4 First camping of 2026 and with the new pup at New Hogan Lake in Calaveras County, CA. Perfect weather, 68° highs and 45° lows.
fiatslug87 Posted June 5 Author Posted June 5 It’s about time to get it a personalized plate. Any of these? You guys have any suggestions?
fiatslug87 Posted June 8 Author Posted June 8 44 minutes ago, Gjeep said: What about JP LIFE Already taken
