Pete M Posted January 14, 2021 Share Posted January 14, 2021 I see there's a lot of variety of cheap kits out there. wondering what works well and what woesn't. I mean doesn't. Link to comment Share on other sites More sharing options...
89 MJ Posted January 14, 2021 Share Posted January 14, 2021 I don't remember the name of ours off of the top of my head. I really like the idea of this thread though Pete, do you think we should create a couple of threads for similar tools? (torque wrenches, battery impacts, sawzalls, etc.) Link to comment Share on other sites More sharing options...
eaglescout526 Posted January 14, 2021 Share Posted January 14, 2021 My hands. Never had to use a puller since my wheel comes off easily but not easily to where I need a puller. Link to comment Share on other sites More sharing options...
89 MJ Posted January 14, 2021 Share Posted January 14, 2021 4 minutes ago, eaglescout526 said: My hands. Never had to use a puller since my wheel comes off easily but not easily to where I need a puller. That's a little concerning TBH. If you have another steering wheel, you may want to try that on your column. From my understanding, the wheel is supposed to go on a little hard and not come off easily. Link to comment Share on other sites More sharing options...
schardein Posted January 14, 2021 Share Posted January 14, 2021 I can get a pic of mine later. You aren't going to get a steering wheel off a junkyard vehicle without a puller. At least I've never had it happen. If a steering wheel has been off and on multiple times, it might get loose enough to come off by hand. I had a Chevy like that. Not an issue, splines were still good and the nut held it on. If the nut has been on and off multiple times, a little loctite might be a good idea. Most FSMs will say replace the nut every time, like a pinion nut. Link to comment Share on other sites More sharing options...
eaglescout526 Posted January 14, 2021 Share Posted January 14, 2021 10 minutes ago, 89 MJ said: That's a little concerning TBH. If you have another steering wheel, you may want to try that on your column. From my understanding, the wheel is supposed to go on a little hard and not come off easily. Ive never had any good luck with getting the wheel on tightly. Way back if you remember my thread about the steering wheel nut sizes, my threads were jacked up on the column and so the nut never went on tightly and I thought that because the nut and threads were messed up were causing that issue. So I got a tap and dye set to rethread the threads on the column to an actual Jeep steering wheel nut and it went on tightly and the steering wheel is on there but it still can be removed by hand with some force. As long as the nut holds the steering wheel in place and doesn’t wobble it around like it did with the old nut, I say it’s good. Link to comment Share on other sites More sharing options...
87MJTIM Posted January 14, 2021 Share Posted January 14, 2021 I picked one up at Sears years ago. Probably labeled Craftsman, but most likely just a repackaged Chinasium. I use it maybe once every two years. It works for what I need. Link to comment Share on other sites More sharing options...
derf Posted January 14, 2021 Share Posted January 14, 2021 I have a couple of the generic pullers you get at your favorite auto parts store. Works with harmonic balancers too. Same with the lock plate removal tool. Just the one in the tool aisle of the parts store. Link to comment Share on other sites More sharing options...
AZJeff Posted January 14, 2021 Share Posted January 14, 2021 My first one was a K-D brand that I got at a NAPA. The second one that I got and hacked up to make a custom puller for a Ford 4.6L is some Chinese junk from O’reillys. Link to comment Share on other sites More sharing options...
Pete M Posted January 14, 2021 Author Share Posted January 14, 2021 1 hour ago, 89 MJ said: I don't remember the name of ours off of the top of my head. I really like the idea of this thread though Pete, do you think we should create a couple of threads for similar tools? (torque wrenches, battery impacts, sawzalls, etc.) don't see why not. maybe you could start a new one each week. Link to comment Share on other sites More sharing options...
89 MJ Posted January 14, 2021 Share Posted January 14, 2021 3 minutes ago, Pete M said: don't see why not. maybe you could start a new one each week. Sounds like a plan to me! Link to comment Share on other sites More sharing options...
Ωhm Posted January 14, 2021 Share Posted January 14, 2021 Been a long time and don't think I could ever find the two that I had. But the best one of the two was the one that someone made in metal shop (high school). Somewhat involved but kind of a simple project, if you got access to the machine tools on hand. Link to comment Share on other sites More sharing options...
Minuit Posted January 14, 2021 Share Posted January 14, 2021 https://www.amazon.com/OTC-7927A-Steering-Remover-Compressor/dp/B000XSCEMQ/ref=sr_1_3?dchild=1&keywords=otc+steering+column&qid=1610653982&s=automotive&sr=1-3 This one does everything on the Saginaw columns including pulling the pivot pins. Doesn't fall apart on you like the cheap ones either. HIGHLY recommended. One of my favorite "special" tools since it makes it so damn easy. Link to comment Share on other sites More sharing options...
derf Posted January 14, 2021 Share Posted January 14, 2021 I have the standalone pivot pin tool that they put in that kit. If I didn't have any of the tools I'd probably get that whole kit. Link to comment Share on other sites More sharing options...
JMO413 Posted January 14, 2021 Share Posted January 14, 2021 Cheap one from? It's in the cheap plastic red case. It was cheap and it works. LOL Link to comment Share on other sites More sharing options...
Dzimm Posted January 15, 2021 Share Posted January 15, 2021 2 hours ago, JMO413 said: Cheap one from? It's in the cheap plastic red case. It was cheap and it works. LOL Yup this one. Got mine from Amazon. Link to comment Share on other sites More sharing options...
