Possibly very dumb house electrical question
mjeff87
Full disclosure, I'm a full on AC voltage nope-er.  I can do simple things (hang a light fixture, change an outlet) but thats about it.  The light switch in our main bathroom squeaks when you flip it on.  It bugs me to no end.  Works just fine except for the highly annoying sound of something that seems like its desperately crying out for a shot of some kind of lube.  Would I end up burning my house down and killing a bus load of kindergarten nuns if I gave the flipper thingy a TINY shot of silicone spray (or whatever else)?  I could just replace the whole thing with a new one, but the cheap side of me hasn't fully accepted that option just yet. :laugh:
19 minutes ago, derf said:
You're going to have to swap out the main panel and rewire the whole house.
Dude, no bull$#!& I called a plumber to see how much it would cost to drop in a gas line for a stove and he came back with his estimate and said I had to replumb the whole house. Now mind you I just had the place inspected and it was only built in 96.
I just smiled and said no.
a bunch of @#$%in charlatans
18 hours ago, Manche757 said:
The sound you are hearing is not arcing?  A frying noise?  Lights don't flicker briefly?   If yes to any of those, check for a loose wire to the switch or a loose wire nut in the box.  The lube will cost you more than a new switch.
No, it's the plastic switch itself.  If I gently push the switch to the left while flipping it up it's silent.  Also doesn't make any squeak when you switch it off.  Like I said it works just fine other than the annoying squeak it makes flipping it on.
I'm off to Home Despot after work today, they have that spray in stock (or so their website says, anyway.....).
It's right by the wire nuts and stuff, bottom/floor shelf.
