rylee144 Posted April 23, 2019 Share Posted April 23, 2019 My reverse lights don't work and haven't for awhile. When they did work they weren't bright. This is my current bumper. It is the one that came with it and is stamped Johnny Beck Sales Ocean Springs MS. I am thinking about mounting flush fog lights when I fix the reverse lights. Only thing holding me back is cutting holes in the factory bumper. Thoughts? Photos of other rear fog lights would be great. Thanks Link to comment Share on other sites More sharing options...
RustyRodder Posted April 24, 2019 Share Posted April 24, 2019 I like mine. Huh, I thought I had more pictures. Link to comment Share on other sites More sharing options...
JMO413 Posted April 24, 2019 Share Posted April 24, 2019 Mine are mounted under the bed. They were on the roll bar when I got the truck. It makes backing up really nice at my mom's in the country. To Bright for in town though. Link to comment Share on other sites More sharing options...
rylee144 Posted April 24, 2019 Author Share Posted April 24, 2019 I like that idea. Wouldn't have to cut my bumper. Link to comment Share on other sites More sharing options...
rylee144 Posted April 24, 2019 Author Share Posted April 24, 2019 Looks like my spare tire would prevent that mount though Link to comment Share on other sites More sharing options...
fiatslug87 Posted April 24, 2019 Share Posted April 24, 2019 BTW that is not a factory bumper. Link to comment Share on other sites More sharing options...
rylee144 Posted April 24, 2019 Author Share Posted April 24, 2019 Makes sense with the car lot name stamped in it. Link to comment Share on other sites More sharing options...
JMO413 Posted April 24, 2019 Share Posted April 24, 2019 58 minutes ago, rylee144 said: Looks like my spare tire would prevent that mount though You are correct I did remove the spare tire carrier. It was locked up. I welded a flat bar across the x in the frame to mount them. Link to comment Share on other sites More sharing options...
gogmorgo Posted April 24, 2019 Share Posted April 24, 2019 Yup. Not the factory bumper. It's an old Fey/Westin bumper. Still being repopped under various brand names. It's a universal-fit 1/4-ton bumper. If Johnny Beck is still around they might get a kick out of seeing it. Some people collect old dealer memorabilia like that too... but there aren't too many who would place much value in that bumper, I don't believe. Link to comment Share on other sites More sharing options...
Jeep Driver Posted April 24, 2019 Share Posted April 24, 2019 This is why I'm going to create hide-a-way back up lights. Link to comment Share on other sites More sharing options...
Eagle Posted April 24, 2019 Share Posted April 24, 2019 2 hours ago, rylee144 said: Only thing holding me back is cutting holes in the factory bumper. Thoughts? You can stop holding back, because that's not a factory bumper. Link to comment Share on other sites More sharing options...
rylee144 Posted April 24, 2019 Author Share Posted April 24, 2019 Lol I've learned. Thanks Eagle Link to comment Share on other sites More sharing options...
Eagle Posted April 24, 2019 Share Posted April 24, 2019 Ya know, looking again at your photo -- your factory backup lights look almost like they've been painted over. They should be clear, and in photos they should appear either as white or as silver (depending on the lighting). Have you tried cleaning them up to see if they can be brighter? By the way, you could also check the bulbs to see if they're the correct bulbs. They should be #1156. Link to comment Share on other sites More sharing options...
MJXJjeepguy Posted April 24, 2019 Share Posted April 24, 2019 I have same fog light for rear on my XJ those are very bright, very useful while offroading and when u need backing up. Link to comment Share on other sites More sharing options...
Pete M Posted April 24, 2019 Share Posted April 24, 2019 chances are those backup lenses are just super fogged up. do you have power going to the reverse bulbs? power coming into and out of the switch? those should probably still function so people know you're backing up in a parking lot. and I would totally put those into that bumper as aux lights. Link to comment Share on other sites More sharing options...
rylee144 Posted April 24, 2019 Author Share Posted April 24, 2019 I'll check the bulbs today. Recommendations on plastic cleaner that won't hurt our lights? Also do our taillights come apart to clean the inside? Link to comment Share on other sites More sharing options...
gogmorgo Posted April 24, 2019 Share Posted April 24, 2019 Some members have separated the lens from the back portion by carefully heating them to break the glue. Or you can just pull the bulb holders out and run water through them. Link to comment Share on other sites More sharing options...
Pete M Posted April 24, 2019 Share Posted April 24, 2019 I'd wager you could use heat to bend the head of an old toothbrush and use as a little scrubber. heck, you could even use toothpaste as a mild abrasive to polish the inside. this message is ADA approved Link to comment Share on other sites More sharing options...
rokinn Posted April 24, 2019 Share Posted April 24, 2019 There appears to me to be an oxidized surface layer over the entire tail light. There are a variety of products that will clean that up. Did it to mine and it cleaned up pretty well. The tooth brush with the same product is a good idea also. I also used LED replacement bulbs and they are quite bright now. Not like rear fogs but plenty bright for my uses. These are no longer available but I'm sure you can find alternatives. https://www.amazon.com/gp/product/B00ED35ALY/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1 Link to comment Share on other sites More sharing options...
Keyav8r Posted April 27, 2019 Share Posted April 27, 2019 I took a set of taillights apart by heating the backs with a heat gun. You have to be careful as the black plastic backs will distort if you get them too hot (don’t ask how I know). Someone had a post about heating them in an oven but don’t remember who it was. Once you have them apart you can clean them well, even polish the inside of the back-up lens. It’s not easy too do as it is not a smooth surface. I sprayed the inside of the backs with some “chrome” paint to improve reflectivity. You can polish the outside of the lens with plastic polish (others have used very fine sandpaper prior to polishing) to get rid of the oxidation then spray it with a clear coat to keep it from oxidizing again. There should be several posts on refurbishing taillights. And, switching to LED bulbs would help. Link to comment Share on other sites More sharing options...
Jeep Driver Posted April 28, 2019 Share Posted April 28, 2019 This is not what I have planned but I cannot believe more people are not more creative. But you get the idea. These aren't bad though. Link to comment Share on other sites More sharing options...
Knucklehead97 Posted April 28, 2019 Share Posted April 28, 2019 You checked your TRANS fuse? Mine blows often (looking into why) and whenever it does, I don't have backup lights. Link to comment Share on other sites More sharing options...
rylee144 Posted April 28, 2019 Author Share Posted April 28, 2019 I have not but will, thanks Link to comment Share on other sites More sharing options...
