The rear axle came back from our local welding shop. Should have some free time this coming weekend to bolt it under the rear.
Reading info on gearing an axle. the local driveline guru is about 30min from my house. They’ve said the axle has to be under the truck. May work on brakes and install factory LS carrier for a bit. I may be able to install the front axle by Feb. If so, I’d be able to gear front and rear. 🤔
  • Replies 200
On 5/9/2019 at 9:21 AM, Fryedaddy said:
I made it to page 2 of your build and I saw this! Just beautiful. My CJ8 looks almost identical 648F5663-8616-4624-A23E-5BF08C7E3491.jpeg.26054ec17f6318591f38000120b513de.jpeg
I will be reading this build-up all the way through, so I can comment on the progress. Sorry, just have a soft spot for the Scramblers and MJ’s.
I loved that scrambler! It had an early 80’s bronco engine, tranny, transfer case and axles.
  • 4 weeks later...
16 hours ago, Pete M said:
things are really coming together!  but are you sure it'll fit out the garage?   :D
LOL, it fits but wouldn't if I put 35's or 36's on it. Still haven't decided what size tires but I'm leaning towards 36" or 37" due to the 4.88 gearing I've bought.
I'll drive it locally for the most part so 35" tires wouldn't be too bad for the off-roading.
  • 4 weeks later...
@Swampy sounds like Moab 2021 is coming together. May have 3-4 Jeeps....I’m the only Comanche but they are all cool peeps. Planning May at this point. still working on your manche?
Tacked all the brackets on the wagoneer  axle the sent it to my local welder. When I was installing the long arm kit and the adjustable track bar I realized I hadn’t measured the track bar mount at the axle. The only mount I didn’t measure🤪.  It was 3/16” too narrow. I cut the front plate off, cut a new one out of 1/4” steel I had laying around and rewelded to the face of the bracket. Fits nice and is mounted solid. The axle doesn’t have weight on it but I plan on installing the axle shafts and knuckles next weekend. Hope it’s on the road within a month. My final issues is an emergency break and rear brakes lines along with the break booster.
Hey man it looks like it's really coming together! There's a group of mj people that meet up in moab once a year in september. It's called the moab mj takeover. Theres more info on the all things jeep comanche facebook page if you're interested.
Thank you! With the corona virus issues, it may push our date back? If so, I’ll make sure to work around that.
