Andyfrye Posted August 26 Posted August 26 Had several parts show up today. I have an edelbrock head and 97+ doors that I'll be installing on the truck over winter. I'm hoping to have this truck on the road and my DD by Springish. Also, my brother works at a local shop, and I'll have them pull the original motor to be replaced with the stroker motor over winter. Hopefully that will save time.
Andyfrye Posted August 26 Posted August 26 On 8/13/2026 at 5:40 PM, 89 MJ said: Glad to see this update! Thank you! I had quite a bit going on. Unfortunately, the Comanche sat for a few years.
Andyfrye Posted September 21 Posted September 21 Finally mounted the Rubicon dana 44 front axle and moved the truck. I'll be working on my brakes next weekend. Several parts started showing up as well. Hopefully I'll have more time over winter to install everything. The negative: It rained this weekend. I knew there was a leak around the door seals, but it appears that the rear window seal has cracked. I'm hoping there isn't a lot of rust at the roof, but I can see heavy corrosion where the headliner Velcro's at the rear window.
Andyfrye Posted November 11 Posted November 11 I've started pulling the motor and hope to pull the block during my Thanksgiving vacation.
