Was '99 the first year of the 0331 cylinder head?
Not a major drawback, but something to keep in mind.
Some late '99's had the 0331 head and coil pack ignition (distributorless). I've only seen one in the flesh. Most have a distributor and the 0630 head.
  • 10 months later...
Good find! 98-99 XJs are for sure argued as the best of the best.
My advice, ditch those LED headlights and get a Rampage H4 conversion kit.  Night and day difference.  I will never use my set of those LEDs again.
From my own personal experience making 2 round trip coast to coast to coast trips.  Truck-Lites are excellent in the Comanche.  Low beam cut off is sharp, lighting pattern is excellent.  High beam pattern is also excellent.  Lighting distance is also excellent on the wide open interstates of the west.
I actually like the Truck Lites better than the factory stock European E-code halogen headlights I have on my  Passat TDI.  Primarily because of the finite life time of the halogen bulbs.  To be fair, I run extra bright halogen lamps with a light relay kit in the Passat.  These halogen bulbs are 30% brighter but only about half the life span because the filaments run hotter.
Have no experience with JW Speaker headlights and their pricing "seems" higher than Truck-Lite.
3 hours ago, Jeep Driver said:
JW Speaker.
Yes, I hear they are a bit better than the Trucklites. I went with a wiring harness and Cibies, w/H4 bulbs. Part of the decision was that I run in wintertime.
       Back to the '99. I think the '99 can be better than the '98 XJ. I do have a '98 XJ. I think some of the '99 came with a distributor and the latter intake. OP didn't mention trans type.
On ‎8‎/‎21‎/‎2017 at 3:29 AM, ComancheKid45 said:
Arguably the best run of the XJ, updated intake, new body style and still distributer ignition. I like mine but I personally prefer the look of the 96- body style.
What he said
Agree. I replaced my Hella E-code lamps with Truck-Lites and kept the relay harness. I felt the high beam penetration on the E-codes was a bit better than the Truck-Lites but the Truck-Lites had better coverage on the low beams. Plus the LEDs drew about 1/8 the amperage, so it's a good swap IMO.
Don.
Still plan to put the e-codes in the 86 Comanche and a relay harness.  Then try a direct comparison between the 91 with Truck-Lites and the 86 with e-codes.  Just not likely this summer.
9 minutes ago, johnj92131 said:
Don.
That would be a good comparision side-to-side.  :L:
4 hours ago, johnj92131 said:
Don.
I have Autopal on the MJ, they are no comparison to the Hella ecodes that are on the XJ.
I like the Hella.
I'm going with the JW Speaker for the MJ.
I loved my 99 XJ and would be driving it today if some bonehead hadn't wrecked it on me. Never had a lick of trouble.
