jbain Posted October 31, 2013 Author Share Posted October 31, 2013 Good luck Bob... WV is starting to open up Off Road parks..... expecially in the southern part of the state where you start seeing rocks...... and appreciate the complement whitemanche..... those RC pics fool me all he time...... Link to comment Share on other sites More sharing options...
jbain Posted November 12, 2013 Author Share Posted November 12, 2013 I was able to fix my gauge problem on Sunday along with my 12v adapter and I rewired the CB. On Monday I spent about 6 hours building a template and cutting lexan to fit my back window. I was luck enough not to crack it and even got the holes drilled without any damage. I still need to remove the window to tint, seal it up, and cover the split between the bars...... The hard part was getting the window around the bars.... since the bars go through at an angle it wasn't just as easy as using a holesaw. That's one of the reason's I decided to make the cut in the center of the bars. Link to comment Share on other sites More sharing options...
AirborneDeth Posted November 12, 2013 Share Posted November 12, 2013 Hell, I am having a hard time just fixing my headlight problem! lol Very nice build you have here. The Lexan was a very good idea. Most people would have just said F it. Link to comment Share on other sites More sharing options...
buffalob Posted November 12, 2013 Share Posted November 12, 2013 This is really taking shape man...loving it. was wondering how you were going to deal with the rear window. Your solution is well thought out and well executed. I tip my hat to you sir. Bob Link to comment Share on other sites More sharing options...
earl*t Posted November 12, 2013 Share Posted November 12, 2013 Standing ovation! :clapping: Very clean execution. I know from experience how easily that material can be damaged. Link to comment Share on other sites More sharing options...
jbain Posted November 13, 2013 Author Share Posted November 13, 2013 Thanks guy's...... I've spent alot of hours trying to figure out how to make this work....... hoping to finish it up this weekend. Link to comment Share on other sites More sharing options...
TMW Posted November 13, 2013 Share Posted November 13, 2013 very nice....lots of good ideas for my mj...and thank you for serving our country Link to comment Share on other sites More sharing options...
jbain Posted November 14, 2013 Author Share Posted November 14, 2013 Appreciate it TMW..... let me know if you have any questions.... I'll be glad to help any way I can. Was able to work a little yesterday and I did some modifications..... I originally drilled a mounting point every 9 inches but decided that wasn't going to be enough so I marked and drilled for every 3. Then I cut out a 2 inch wide piece of lexan and cut it to cover the split between the bars..... then I drilled more holes. My intention now is to paint the inside of the seam covers with gloss black as well as the outside 2 inch rim of the the glass. I decided against the tint because of how I have to bend the lexan to get it in between the bars. All in all I had to source 72 stainless nuts and bolts to mount the window. The worse part is the drilling.... each of the 72 holes had to be drilled 4 times with increasingly larger bits as not to "Catch" too much material and break, chip or crack it. I also got around to splitting my Headliner and reinstalling it..... had to do quite a bit of trimming and I'm still not sure how I'm going to cover the seam but I think it looks better than the bear roof...... Link to comment Share on other sites More sharing options...
Bornindesert Posted November 14, 2013 Share Posted November 14, 2013 Shaping up nicely, the lexan gives the truck a "Baja 500" Pro Comp Stock look. Hey, maybe I missed it in an earlier posting but did you go with new aftermarket bucket seats? If you did, what brand, I'm deciding on what to do with my next project. Link to comment Share on other sites More sharing options...
jbain Posted November 14, 2013 Author Share Posted November 14, 2013 Thanks man.... if you look back on the post you'll see how I mounted the seats.... they are from an 04 Grand Cherokee..... I really like them but they do sit a little higher than my worn out bench...... Link to comment Share on other sites More sharing options...
Bornindesert Posted November 14, 2013 Share Posted November 14, 2013 Oh yes, remember now...you used a 97+ Cherokee donor and modified the floor with the donor section. That was a good approach and might be the direction I go witih mine. So, the Grand Cherokee seats just look really nice...I thought they had the electric controls on the side, might be able to lower them if they have the up/down feature. Link to comment Share on other sites More sharing options...
jbain Posted November 14, 2013 Author Share Posted November 14, 2013 The lower mounts are also from an XJ so they are manual.... I just unbolted the WJ lower mount and bolted in the XJ one..... I'm going to replace the seat controls on the side with a light..... this way I can hit a toggle switch and light up my entry / door jam area. Link to comment Share on other sites More sharing options...
jbain Posted November 18, 2013 Author Share Posted November 18, 2013 Had a buddy set up my new front gears after detonating them last month at IVY....... I was also able to finished up my back window, I urethaned the plexiglass into the opening then I cut the lip off the original rubber molding and using that to frame the window...... I'm really happy with the way it turned out. Link to comment Share on other sites More sharing options...
SW86 Posted November 18, 2013 Share Posted November 18, 2013 Nice work Link to comment Share on other sites More sharing options...
GHayduke Posted November 18, 2013 Share Posted November 18, 2013 Might I suggest some serious tail light protection.... they look very exposed for a trail rig! Link to comment Share on other sites More sharing options...
SW86 Posted November 18, 2013 Share Posted November 18, 2013 Might I suggest some serious tail light protection.... they look very exposed for a trail rig! i can vouch for that. ive busted several and my current set both are cracked but still in one piece. with the supply running out, i think i might go LEDs when my back up sets are gone too Link to comment Share on other sites More sharing options...
jbain Posted November 19, 2013 Author Share Posted November 19, 2013 It's true I have gotten lucky, if you look right above the drivers side light you'll see a dent from backing into a rock..... I still have the line from where I Bobbed the bed so I'm going to just bend up some 16 guage steel weld the opening flush grind it all flat and hang an Oval LED in the back. I'm thinking of loosing the tailgate and building one that holds my tire and swings open...... I thought it might be cool to integrate the tail lights into that..... kinda recess them some to keep them out of harms way. Link to comment Share on other sites More sharing options...
jbain Posted November 22, 2013 Author Share Posted November 22, 2013 I was able to get the new front axle in yesterday and took it for a test drive..... sure is alot quieter and smoother with gears that aren't missing any teeth. Now all I have to do is install the front locker and diff skid and I should be ready to go....... I also mounted the Army container My buddy gave me into the bed..... after some sanding and a quick coat of paint all I had to do was cut a hole and a few slots and the spare Driveshaft and Axles slid right in. I also mounted up the new spare rim and was able to get back in the truck and strapped down..... here are a few pics....... I also found a pic on our website that my buddy just uploaded that I thought I'd include..... for anyone in the vicinity of Southern West Virginia you should come and check out IVY..... Link to comment Share on other sites More sharing options...
mvusse Posted November 22, 2013 Share Posted November 22, 2013 For anyone wanting to head out there, note that the Hatfield & McCoy trail system of which Ivy is part requires helmets by all riders, even in Jeeps. Never been there myself, but have been told this by a frequent visitor. Link to comment Share on other sites More sharing options...
jbain Posted November 22, 2013 Author Share Posted November 22, 2013 mvusse is correct and helmets are required for all riders... if you look you can see my son and My helmets hanging from the roll bar. It's also important to note that on all Double Black trails "Roll over Protection" is also required...... Link to comment Share on other sites More sharing options...
HOrnbrod Posted November 22, 2013 Share Posted November 22, 2013 Looks like you are about maxed out height-wise by the garage door, si? Link to comment Share on other sites More sharing options...
jbain Posted November 25, 2013 Author Share Posted November 25, 2013 I'm hoping to move up to 38's next year...... If I can make it happen it's gonna require smaller tires to roll it in and out...... Link to comment Share on other sites More sharing options...
88whitemanche Posted November 25, 2013 Share Posted November 25, 2013 Monster truck status!!!!! Whoo!!!!!! Lol Link to comment Share on other sites More sharing options...
jbain Posted November 27, 2013 Author Share Posted November 27, 2013 38's are probably as big as I would ever consider going on my MJ just because I want to keep it street legal.... or at least streetable..... Mods will include plating the entire frame, upgrading the front axle to a HP dana 44 and of course talking the wife into 1800.00 dollars worth of tires..... but for now I just want to enjoy driving and wheeling it and not get caught up in the "whats my next mod" game that tends to always be going on in my head.... Link to comment Share on other sites More sharing options...
dscowell Posted November 27, 2013 Share Posted November 27, 2013 Why HP D44 why not just use a D60? Link to comment Share on other sites More sharing options...
