Rymanrph Posted November 11, 2013 Author Share Posted November 11, 2013 I installed the new master and booster and I still have the same problem. Firm pedal with the truck off, but as soon as I turn it on, there is very little resistance. Its possible that I still have air trapped in the system somewhere or it could be something entirely different. The brakes work sorta so I may just have to drive it gingerly somewhere to have a vacuum put on the system to make sure its been bled correctly, but if that's not it then I'm a little stumped. Link to comment Share on other sites More sharing options...
AirborneDeth Posted November 11, 2013 Share Posted November 11, 2013 Did you bench bleed the master cylinder before installing it? Link to comment Share on other sites More sharing options...
Rymanrph Posted November 11, 2013 Author Share Posted November 11, 2013 Did you bench bleed the master cylinder before installing it? I did. Its possible that I didn't get all the air out, but I kept compressing the cylinder until I couldn't see any more bubbles and then I did it several more times. Link to comment Share on other sites More sharing options...
GHayduke Posted November 11, 2013 Share Posted November 11, 2013 I use a power bleeder when doing brakes now as it's easier to get air bubbles flushed out. I did a rear brake conversion on my Scrambler to GM metric brakes with calipers mounted toward the front, putting the brake lines entering the opposite side they originally did. Took a while to realize the lines/caliper trap air and I have to remove the calipers, put a rotor thick block of wood in them, and turn them upside down (really right side up) to get the air bled out! It took us running through a gallon of fluid to realize that.... (I now have a gallon jug of old brake fluid labeled 'Paint Remover'! :brows: ) on my 98' conversion the pedal is hard when off & moderate when engine is on, but the brakes are strong. You would be good the pull you rear drums and do a visual on the brake cyliders, I found I had one seal partially popped out on a side. Any small leak can cause havoc. Are you running the rear axle weight sensitive proportioning valve? I removed mine. Link to comment Share on other sites More sharing options...
Rymanrph Posted November 11, 2013 Author Share Posted November 11, 2013 One of the first vehicle maintenance projects I ever tackled was replacing a seized caliper on my '91 YJ. I had the same issue trying to bleed the calipers mounted upside down. I haven't inspected the rear wheel cylinders because I ran out of time, but its not a bad idea. I still have the rear prop valve. Link to comment Share on other sites More sharing options...
Rymanrph Posted November 16, 2013 Author Share Posted November 16, 2013 I got a chance to inspect the rear wheel cylinders today and they seem fine. The brakes were way out of adjustment (which is odd since I just adjusted them when I swapped axles last summer. After adjusting them, the pedal isn't much better if at all, so I'm just going to see if I can find someone near by that can pressure bleed the system. Link to comment Share on other sites More sharing options...
TMW Posted November 17, 2013 Share Posted November 17, 2013 very impressed with this build...mine is going down a very similar path. 68 cuda notchs...very sweet....pics please..... Link to comment Share on other sites More sharing options...
rudycoop Posted November 17, 2013 Share Posted November 17, 2013 I really like your steering wheel. How difficult was it to do the stitching? Link to comment Share on other sites More sharing options...
Rymanrph Posted November 17, 2013 Author Share Posted November 17, 2013 very impressed with this build...mine is going down a very similar path. 68 cuda notchs...very sweet....pics please..... I have a build thread on the A body forums here, but I occasionally will upload some pictures in our other ongoing projects thread here as well. I really like your steering wheel. How difficult was it to do the stitching? There are a bunch of ways you can do it and I will say overall it wasn't too bad, but I think it would be difficult to do well by yourself if you've never done it before. I was glad to have a helping hand to stretch the leather and hold things tight while I threaded. Link to comment Share on other sites More sharing options...
rudycoop Posted November 18, 2013 Share Posted November 18, 2013 I really like your steering wheel. How difficult was it to do the stitching? There are a bunch of ways you can do it and I will say overall it wasn't too bad, but I think it would be difficult to do well by yourself if you've never done it before. I was glad to have a helping hand to stretch the leather and hold things tight while I threaded. It just looks so damn nice. I am considering it. No comparison to the original. Link to comment Share on other sites More sharing options...
Rymanrph Posted January 17, 2014 Author Share Posted January 17, 2014 I've got about a $70 credit at 4 Wheel Parts, but I have no idea what to spend it on. Any suggestions? Link to comment Share on other sites More sharing options...
87 COMANCHE PIONEER Posted February 22, 2014 Share Posted February 22, 2014 I've got about a $70 credit at 4 Wheel Parts, but I have no idea what to spend it on. Any suggestions? Link to comment Share on other sites More sharing options...
87 COMANCHE PIONEER Posted February 22, 2014 Share Posted February 22, 2014 My bad, how about new pedal pads, or the b pillar lights if they have them. Link to comment Share on other sites More sharing options...
Rymanrph Posted February 22, 2014 Author Share Posted February 22, 2014 My bad, how about new pedal pads, or the b pillar lights if they have them. Ha, I actually recently bought a new brake pedal pad. I looked high and low for one that actually fit like the original. I ended up having to buy one from the dealer. I have the euramtec b pillar lights (I've had them for several years). Although one of them no longer works as an entry light; I was disappointed that it broke so quickly. It still works as a map light so I haven't bothered changing it. I ended up buying a Viair air down kit and a fire extinguisher for my Barracuda. Link to comment Share on other sites More sharing options...
Rymanrph Posted February 24, 2014 Author Share Posted February 24, 2014 Not Comanche related, but Its that time of year again. I bought another TJ to fix up and sell. I got it for cheap, but the 32rh needs rebuilding, the paint is rough and it needs tires. I couldn't pass it up for the price though. Its a '99 and only has 140k miles. The PO installed a new radiator, exhaust manifold, head gasket, battery and valve cover gasket. I'm hoping for a quick and profitable flip. Link to comment Share on other sites More sharing options...
Rymanrph Posted April 26, 2014 Author Share Posted April 26, 2014 I haven't done anything to the MJ recently except driving it quite a bit. My last tank got me 14.5 mpg which is pretty good for me. I did wash it today and I got the TJ finished and ready to sell as soon as the title gets here. Link to comment Share on other sites More sharing options...
Rymanrph Posted August 24, 2014 Author Share Posted August 24, 2014 I got the Comanche back out on the trails today. PFCLeist invited me out to Uwharrie and we had an adventurous day. I got a video of Sean, but I'll let him decide if he wants to me to share it. Wish I had gotten some more and better pictures, but we had a fun time. Link to comment Share on other sites More sharing options...
AeroNautical Posted August 24, 2014 Share Posted August 24, 2014 Indeed an interesting and adventurous day. Post em up if you want, I'll just take the heat for it, haha. I'll have a thorough explanation in the post following the videos. Link to comment Share on other sites More sharing options...
Rymanrph Posted August 24, 2014 Author Share Posted August 24, 2014 Link to comment Share on other sites More sharing options...
SW86 Posted August 24, 2014 Share Posted August 24, 2014 Man forgot all about this one. You need to get that thing out and stretch its legs more :) Link to comment Share on other sites More sharing options...
onlyinajeep726 Posted August 24, 2014 Share Posted August 24, 2014 That's awesome guys! Hate that I couldn't make it. Oh well, they'll be other trips I suppose. Link to comment Share on other sites More sharing options...
stoffi Posted September 17, 2014 Share Posted September 17, 2014 Amazing build! I really wanna do this to my Comanche as well, but I gotta find a place to do it. Congratulations to you Sir! Simply stunning! Link to comment Share on other sites More sharing options...
Rymanrph Posted December 20, 2014 Author Share Posted December 20, 2014 Today I celebrated my fifth year of Comanche ownership. Its made quite the transformation over the years, but I've enjoyed every stage of it. While I've done mostly everything I wanted to do to it, I still have several ideas in mind for the next five years. Link to comment Share on other sites More sharing options...
Lowly Posted December 20, 2014 Share Posted December 20, 2014 Couple of questions, did you have any issues with the Bushwacker flares since you have had them? Did you do anything to midgate them vibrating? Or are they fine? I just installed mine and wondered if I needed to do anything to prevent them from vibrating so I don't lose the nut. Also where did you get the emblems for the doors? I had to take my emblems off from the fenders and really liked the one's you had on your doors. Where did you get them? Or are they the ones from the fenders? Link to comment Share on other sites More sharing options...
88whitemanche Posted December 20, 2014 Share Posted December 20, 2014 Couple of questions, did you have any issues with the Bushwacker flares since you have had them? Did you do anything to midgate them vibrating? Or are they fine? I just installed mine and wondered if I needed to do anything to prevent them from vibrating so I don't lose the nut. Also where did you get the emblems for the doors? I had to take my emblems off from the fenders and really liked the one's you had on your doors. Where did you get them? Or are they the ones from the fenders?He got the stickers from jeepstickers.com Link to comment Share on other sites More sharing options...
