87 COMANCHE PIONEER
Everything posted by 87 COMANCHE PIONEER
Wife's MJ
87 COMANCHE PIONEER replied to reson46's topic in MJ Hardcore Tech: Epic Journeys to Greatness
Sounds like you're going about it the best way. Making sure the 5.3 is in prime condition for the swap. I'm in the middle of putting a 5.3 in a 1997 Nissan hardbody, then it'll get a SAS swap. Hopefully after that I'll move onto the Comanche.- 897 replies
- dana 44/8.8
- arb lockers
- (and 3 more)
Wife's MJ
- 897 replies
- dana 44/8.8
- arb lockers
- (and 3 more)
Wife's MJ
Updates? Just read the whole thread and wow was it a lot to take in. Definitely got some ideas for my comanche.- 897 replies
- dana 44/8.8
- arb lockers
- (and 3 more)
'88 Eliminator... Feb. 2009 - Nov. 2026
87 COMANCHE PIONEER replied to neohic's topic in Member Projects: Your Comanches
Super nice build. The current look is just jaw dropping. -
My 9 Year Build So Far.......
87 COMANCHE PIONEER replied to jpnjim's topic in Member Projects: Your Comanches
Why swap to the wj knuckles? -
Just started reading your build and you did some great work. I lifted mine and stuck the 8.8 under and rolled it outside the past two years and am now getting ready to start back up and you've given me a lot to think about doing. Props on tge build. Can't wait to see the 4.7. Might have to do with the 4.0 h.o I have.
Hi everyone, I am currently in the process of tying all my loose ends up on my build and have no clue what to paint with. I cannot decide between spray paint or automotive paint. I can do both, that's not the issue, my issue lies where spray paint would be much simpler going on and to fix scratches and such. On the other hand automotive paint doesn't scratch as easy. I am lost anyone have any goes or woes on either?
88 Speaker Size and location?
87 COMANCHE PIONEER replied to Luvtohunt's topic in MJ Tech: Modification and Repairs
what size is in the dash -
More 8.8 brake questions
87 COMANCHE PIONEER replied to 87 COMANCHE PIONEER's topic in MJ Tech: Modification and Repairs
I see what you guys are saying, I'll install the axle and see how the brakes work and if the pedal feels good and she brakes good, I'll leave it be. If she decides not to cooperate then bye bye load sensing valve. I won't be hauling anything anyway. She's a daily driver and weekend warrior. -
I really appreciate all the responses guys. I am running 33's and that's my maximum tire size. So, if I remove the load sensing valve it might would brake better? :???: -
I know many people take the o-ring out of the prop valve, but would deleting the prop valve gain the same braking? I just got an exploder rear and springs with 3.73 and limited slip for 100$ and plan on stripping it and putting all new brackets on with 4.56 front and rear with al locker in the dana 30. I would like to delete the prop valve, but if it doesn't brake better i don't really see the need to, when i can take the o-ring out. Also, i plan on keeping the MJ MC and booster.
What kind of wheels?
Beat Not Built...
87 COMANCHE PIONEER replied to KCsurfer420's topic in Member Projects: Your Comanches
On your bronken output shaft, is that cardan joint the same as on the front drive shaft? -
89 Southern Mj: First Jeep
87 COMANCHE PIONEER replied to xjustinx's topic in Member Projects: Your Comanches
Perfect and I love your truck, great inspiration for mine. -
What does the reverse/cargo light look like from the rear? By the way, love the truck; building mine almost the same way. Drive shaft is being a pain though. :headpop: -
1990 Rebirth ('97 Conversion)
87 COMANCHE PIONEER replied to Rymanrph's topic in Member Projects: Your Comanches
My bad, how about new pedal pads, or the b pillar lights if they have them. -
87 Red Comanche So Far.
87 COMANCHE PIONEER replied to 87shortbed comanche's topic in Member Projects: Your Comanches
*have you already sold it? -
comanche of doom
87 COMANCHE PIONEER replied to The_Devils_own's topic in Member Projects: Your Comanches
What kind of brush guard is that? Love the truck. -
My Longbed Manche Build-Up in Florida
87 COMANCHE PIONEER replied to hermes542's topic in Member Projects: Your Comanches
Want to get rid of the brush guard?
