Luvtohunt
Luvtohunt's Achievements
Comanche Fan
Comanche Fan (3/11)
  1. Its a 1988 Comanche 4.0L 6 cyl, 4x4 just over 103,000 miles, I know I've changed the oxygen sensor but no others have been changed to my knowledge.
  2. The fuel pump is probably not suspect then? Thank you for the replies
  3. My MJ has had a hard time starting lately, where it will start or just keep turning over and never fire. I was also driving it today and it suddenly died, but the radio was still on. So i was wondering is it the fuel pump or is it something else going out on it? Thank you
  4. Tail lights went out tonight, didn't know it until I was pulled over. Cop was a great guy, didn't write me up and followed me to a truck stop to park it for the night, it is going into the shop tomorrow, as I can't figure it out. Hope it isn't too expensive, but, regardless, can't drive it until its fixed.
  5. Think I will try to order the smart switch, is that enough description, or does anyone know if there is a specific part number? Thanks again for the help.
  6. Thanks, tried rotating the headlight knob, didn't help, but thanks for the idea. This is so frustrating, if I turn my left turn signal, both turn signals turn on, if I turn the right one on, no problem. Not having dash lights is a real pain.... Any additional ideas would be appreciated.
  7. I will try that, its weird, it has been working fine for thirty thousand miles, then last night out of the blue it quite.
  8. checked that ground out behind the drivers side tailight, that was secured good and solid. Any other ideas on what could be causing this? Thanks again.
  9. so if I understand correctly, I just take the tail light assembly out of the drivers side, and I should see a wire attached to the bed? Thanks again for your help.
  10. Sorry for my ignorance, is it just a wire that is screwed to the frame or body?
  11. Do you know where the ground is? Thanks for the information.
  12. Was driving my 88 Comanche tonight, the dash lights went out, and only come on now when the brakes are applied. Anyone have a clue what is going on? Any help would be appreciated. Thank you
  13. My tailpipe is rusted out bad, the exhaust system from the muffler forward is in good shape, what would happen if I just cut the rusted tail pipe off and did not replace it right away? Am planning on getting it replaced in about six weeks, just don't have the money right now. Would it cause any serious issues if I just cut it off for the time? Thank you.
  14. Sorry for my ignorance, but what is CAD, and how do you know if its engaged? Thank you.
