fasheeryfo Posted April 24, 2009 Share Posted April 24, 2009 continued spraying PB blaster on the rear diff. cover Link to comment Share on other sites More sharing options...
JeepcoMJ Posted April 24, 2009 Author Share Posted April 24, 2009 remounted the front bumper, discovered that repairing the frame cracks didn't stop the popping. then discovered that the popping is actually two different things: 1....only one bolt holding the column to the firewall. so it twists and the steering shaft pops. 2....the steering box is probably fubar'd. I just don't feel like adapting my pump right now to put the AGR box in. grabbed my plasma cutter back from my grandpa so I can put a hole in the passenger coil bucket for the bumpstops. wired my CB straight to the battery pulled the dash bezel out so I can put my external CB speaker where the cigarette lighter is. gonna relocate the cig. lighter to the knee board and add a second one in today, then call it good. Link to comment Share on other sites More sharing options...
Darren Posted April 24, 2009 Share Posted April 24, 2009 I thought about it for a little while while I was driving. Link to comment Share on other sites More sharing options...
BPB Posted April 24, 2009 Share Posted April 24, 2009 still haven't looked at it yet today. although i get my heims in today :banana: :banana: :banana: :banana: Link to comment Share on other sites More sharing options...
Darren Posted April 24, 2009 Share Posted April 24, 2009 That's great Ben. I'm so happy for you. Link to comment Share on other sites More sharing options...
mvusse Posted April 24, 2009 Share Posted April 24, 2009 Used to tow my trailer to the dumpster at work to unload a load of remodelling garbage. About to change axle oil. Link to comment Share on other sites More sharing options...
JeepcoMJ Posted April 24, 2009 Author Share Posted April 24, 2009 removed shock boots, cleaned interior, began acquiring what I'll need for painting it, and put the sway bar back on with a couple new pins for the RC disconnects. but now I'm thinking of grabbing hardware to pop my 4.5" JKS quiker discos on it...need to mod them to fit. Link to comment Share on other sites More sharing options...
CWLONGSHOT Posted April 25, 2009 Share Posted April 25, 2009 I picked up a couple sheets of steel for the frame rebuild!!! CW Link to comment Share on other sites More sharing options...
jpdocdave Posted April 25, 2009 Share Posted April 25, 2009 finally put in a temp sender so the gauge cluster swapped from an idiot cluster has a working temp gauge now :clapping: Link to comment Share on other sites More sharing options...
BPB Posted April 25, 2009 Share Posted April 25, 2009 I walked by go blazers jeep going into his house. Then I looked at it while I puffed on a cancer stick. Then I walked by it on my way back to my car. Link to comment Share on other sites More sharing options...
Geonovast Posted April 25, 2009 Share Posted April 25, 2009 yesterday I swapped beds on the 89 and my 2.5 91. Today I get to haul said 89 like 35 miles with my 2wd 4.0 and not-very-tready tires in this pouring rain. Link to comment Share on other sites More sharing options...
mvusse Posted April 25, 2009 Share Posted April 25, 2009 What pouring rain? We are in the middle of a heat wave with 85 degrees and perfectly blue sky here in Ohio. Average high for this time of year is ~60. Link to comment Share on other sites More sharing options...
BPB Posted April 25, 2009 Share Posted April 25, 2009 Darren called me and woke me up from a wet dream I was having about my MJ :grrrr: Link to comment Share on other sites More sharing options...
Geonovast Posted April 25, 2009 Share Posted April 25, 2009 What pouring rain? We are in the middle of a heat wave with 85 degrees and perfectly blue sky here in Ohio. Average high for this time of year is ~60. Being as you're 540 miles from me, weather conditions may vary. :nuts: Link to comment Share on other sites More sharing options...
dasbulliwagen Posted April 25, 2009 Share Posted April 25, 2009 Took the 87 into work this morning to see if I could figure out the wiring for the AC. Thanks to the downloadable 1988 service manual PDF from one of our other esteemed members, I was able to find a better wiring harness diagram and found that I just needed to add a relay to it and have the unused pins from the dealer installed AC connector hooked to the relay, etc. etc. etc.... and viola! it works!!! Still need to add refrigerant oil to the system though, so no real tryout till next week....someone locked up the AC machine at work, and it has the oil injector I need to put the oil in. Next project... Install the 4:10 rear axle, then the front axle then the trans and transfer case. Maybe next weekend I can start on that! :brows: :brows: :brows: Link to comment Share on other sites More sharing options...
JeepcoMJ Posted April 25, 2009 Author Share Posted April 25, 2009 I drove it to the jefferson swap meet developed death wobble....gonna remove EVERYTHING in the front end and start over with fresh joints everywhere, and finally put the AGR steering box in. while I'm doing that (several weeks away) I'll sand a different header panel for ot that's not pitted so bad, and paint the truck. also gonna plate the frame at least on the driver's side. anyways, picked up a wrangler (unknown classification i.e. yj tj cj) tuffy lock box WITH pioneer deck and remote for $75, and got my 97 header (in immaculate shape) with headlight buckets, turn signals, one bezel, and one side marker for $60 my brother bought 35x12.50 mud terrains (similar tread pattern to BFG) on cragar soft 8's with the right bolt pattern for $350 and got some KC fog lights as well. Link to comment Share on other sites More sharing options...
jbhill Posted April 25, 2009 Share Posted April 25, 2009 i unloaded it off the trailer were its ben sittin for a month lol. Link to comment Share on other sites More sharing options...
Jeepcom23 Posted April 25, 2009 Share Posted April 25, 2009 Put a brand new slider backglass in it for my bday. Anyone need a Good non slider backglass??? 35% tint Link to comment Share on other sites More sharing options...
JeepcoMJ Posted April 25, 2009 Author Share Posted April 25, 2009 :D threw my bro's 35's on it. he's thinking he wants to go bigger, but he wants the rims. fine by me...this thing looks ridiculous now. also put the tuffy lock box in the truck...mocked up for now but it's very nice, fits perfect with my xj rocker seats (slightly higher seats...the factory center console was too low b4 but it's perfect height now), and pulled my camo seat covers out of the cover to discover that the white...has a pinkish hue. time to bleach :P Link to comment Share on other sites More sharing options...
TNT Posted April 26, 2009 Share Posted April 26, 2009 I heated mine with a torch and beat it with a hammer. Link to comment Share on other sites More sharing options...
mvusse Posted April 26, 2009 Share Posted April 26, 2009 Replaced oil in front axle and tested the temp sensor in the new thermostat housing. Also replaced front axle U joint on the Cherokee and removed the brake dust shield while I had the hub off. Link to comment Share on other sites More sharing options...
BPB Posted April 26, 2009 Share Posted April 26, 2009 Woke up from a nap and thought about it. Link to comment Share on other sites More sharing options...
BPB Posted April 26, 2009 Share Posted April 26, 2009 talked about it at a bar Link to comment Share on other sites More sharing options...
fasheeryfo Posted April 26, 2009 Share Posted April 26, 2009 ordered front CV shaft assembly to fix my front axle... Keeeeeeept on sprayin PB blaster on diff. covers, buying a better torq bit tool cause mine suuucks. looking at RE lift kit components to find out I need $855.70 Link to comment Share on other sites More sharing options...
TNT Posted April 26, 2009 Share Posted April 26, 2009 talked about it at a bar Quit wasting bandwidth and padding your post count with you stupid BS responses.... :thwak: Link to comment Share on other sites More sharing options...
