pizzaman09 Posted January 29 Share Posted January 29 2 hours ago, fiatslug87 said: While replacing the water pump and thermostat I snapped the head off the upper t-stat housing bolt. Was able to drill it out and found the housing to be in pretty bad shape so I’m waiting for a new one but luckily have an extra bolt. Also replaced the harmonic balancer since I was in there. The harmonic balancer looked like it was ready to be replaced. Link to comment Share on other sites More sharing options...
Salvagedcircuit Posted April 25 Share Posted April 25 Added a tissue box holder. Cut down a standard sized 4.5" cube tissue box to about 1/3 of the original volume. Fits pretty nice and the tissues come out naturally with no fiddling. Uses standard sized 8.3in tissues. Winnner winner, chicken dinner. Link to comment Share on other sites More sharing options...
Tex06 Posted May 8 Share Posted May 8 FINALLY! AFTER 10 YEARS..... NO MORE "MAINT REQD" LIGHT!!!!! Link to comment Share on other sites More sharing options...
pizzaman09 Posted May 9 Share Posted May 9 13 hours ago, Tex06 said: FINALLY! AFTER 10 YEARS..... NO MORE "MAINT REQD" LIGHT!!!!! Congrats! How'd you fix it? Link to comment Share on other sites More sharing options...
watchamakalit Posted May 9 Share Posted May 9 6 hours ago, pizzaman09 said: Congrats! How'd you fix it? If I'm not mistaken the maintenance required light is simply run off a timer. I believe it was set up so that light would come on at certain mileage intervals to remind you to take it to be serviced. But it's been a long time since I had a maintenance timer. Link to comment Share on other sites More sharing options...
Tex06 Posted May 11 Share Posted May 11 On 5/8/2025 at 9:03 PM, pizzaman09 said: Congrats! How'd you fix it? Bought a Snap-on MT2500 🤣🤣🤣 Link to comment Share on other sites More sharing options...
watchamakalit Posted May 11 Share Posted May 11 Pull the timer out. As far as I know without special equipment it can't be reset. Link to comment Share on other sites More sharing options...
Salvagedcircuit Posted May 11 Share Posted May 11 I duplicated the screw plugs in the front trim pieces. The fit, finish and color are so close its crazy. The front caps are smaller than the rear ones. All the ones shown here are printed. Link to comment Share on other sites More sharing options...
MancheKid86 Posted May 11 Share Posted May 11 Turned it on been a few years since i could do this 20250511_154653.mp4 Link to comment Share on other sites More sharing options...
Tex06 Posted May 12 Share Posted May 12 16 hours ago, watchamakalit said: Pull the timer out. As far as I know without special equipment it can't be reset. That's renix. I have an H.O. so there is no timer. Link to comment Share on other sites More sharing options...
watchamakalit Posted May 12 Share Posted May 12 5 hours ago, Tex06 said: That's renix. I have an H.O. so there is no timer. Well the only solution I see to that, is to do a renix swap. Then you could just pull the timer. Link to comment Share on other sites More sharing options...
coheed Posted May 12 Share Posted May 12 18 hours ago, Salvagedcircuit said: I duplicated the screw plugs in the front trim pieces. The fit, finish and color are so close its crazy. The front caps are smaller than the rear ones. All the ones shown here are printed. That's fantastic. Are you gonna make these available for purchase, either the finished ones or an stl? What kind of build plate are you using for that surface finish? Link to comment Share on other sites More sharing options...
Salvagedcircuit Posted May 12 Share Posted May 12 5 hours ago, coheed said: That's fantastic. Are you gonna make these available for purchase, either the finished ones or an stl? What kind of build plate are you using for that surface finish? I'm thinking about it! What color are you looking for? I used a rough texture pei plate and printed the first layer slow for better texture. Thanks Link to comment Share on other sites More sharing options...
coheed Posted May 12 Share Posted May 12 45 minutes ago, Salvagedcircuit said: I'm thinking about it! What color are you looking for? I used a rough texture pei plate and printed the first layer slow for better texture. Thanks I would need honey for my interior, no clue what filament would match that. Suppose they could always be painted. I have a smooth pei sheet on mine and the factory magnetic sheet that creality has that makes a little texture, but it's not as rough or close to original as yours. Link to comment Share on other sites More sharing options...
MancheKid86 Posted Sunday at 02:43 PM Share Posted Sunday at 02:43 PM gave it some washers 20250524_170031.mp4 Link to comment Share on other sites More sharing options...
White_Comanche Posted 18 hours ago Share Posted 18 hours ago On 5/11/2025 at 1:14 PM, Salvagedcircuit said: The fit, finish and color are so close its crazy. Bet if you thought about producing these, they would go like hot cakes on here. Link to comment Share on other sites More sharing options...
GonzoTheGreat Posted 7 hours ago Share Posted 7 hours ago 11 hours ago, White_Comanche said: Bet if you thought about producing these, they would go like hot cakes on here. On 5/12/2025 at 1:15 PM, Salvagedcircuit said: I'm thinking about it! What color are you looking for? I used a rough texture pei plate and printed the first layer slow for better texture. Thanks I would definitely buy a set of medium blue hotcakes if you start producing these. You've got quite a portfolio of parts drawn up. You should totally start selling stuff. Link to comment Share on other sites More sharing options...
