Everything posted by Tex06
'92 shortbed 2wd. 2.5L. Clean title. Dent in roof, otherwise the body is in good shape. Has comanche bedliner. 5spd trans. Not currently running. $1000. New Orleans
Damn, still not showing up.
Can you repost the picture?
Damn, I could use this but it's a haul from S. Louisiana to SC.
Frame Rot :(, What Are My Options?
Tex06 replied to VorTekX's topic in MJ Tech: Modification and Repairs
Honestly, not that bad. You already have a plasma cutter and MIG. Get a small cutoff tool (like 3" cutoff or a regular 4" grinder with cutoff wheels and a dremel for the nitty gritty stuff. Cut out areas that are more or less rectangular while the truck is on jack stands (take as much load off of that area before you start cutting). Remove inner fenders and other stuff that may be in the way. Use cardboard (beer boxes work great!) and a sharpie and scissors to make templates for each piece you cut out. Doing it in bigger pieces is better, but I've patchworked several frames and unibodies (XJ and MJ) with good success. Make sure that where you're welding to is solid metal. If it's thin/rusty/iffy....it's gonna suck to weld to. Also, clean the area as best you can with a wire wheel before welding....clean steel is easy to weld to, dirty steel is not. Lastly, youtube is your friend. Look for "rusty frame repair" videos. You can weld in heavier metal to the thin unibody. Lots of people have done this with good success. Good Luck! -
No, but pull-a-part has several 4x4 cherokees we can go snag one from. The NP231 is pretty easy to find around here.
That 2wd AX-15 isn't still available by chance is it?
Can ship on buyer's dime but would prefer to sell all together if possible. Core 4x4 adjustable control arms set (Tier 1, about 4 years old Now called their "Cruise Series") - $180 Rough Country control arm drop brackets and hardware- $60 4" lift coils (Old Man Emu, ran for 3 months... they still have the tags on them) - $130 4" rear springs (unknown manufacturer... they're 4 leaf and ride well) - $200 5x4.5 to 5x5 wheel adapters (so you can run newer wheels) - $100 4" Alcan Rear Springs (Used less than 1 month; True 4" lift on 4x4, closer to 5.5" on 2wd) - $700 AX-15 4x4 crossmember (fits 91-92 MJ, 91-01 XJ) - $250 Control Arms, drop brackets, crossmember, and wheel adapters Picture of my truck with Alcan and OME springs plus Core arms and drop brackets with 31" tires Alcan 4" springs in foreground (1250lbs/in). Newer 6" lift behind it (1300lbs/in). 8 leafs/spring. Tag on the OME 4" coil springs. Lift on the 4" OME coils. Bucket to body is right at 15.5" (with a 4.0) Lift with the Alcan springs 11.75" from frame to axle tube. (I *think* this is the 4" ones, I will confirm)Spring rate is 1250lbs/in which gives a *very* comfortable ride with an empty truck or about 500lbs in the bed. Drop brackets and control arms right before removal from the truck. Another shot of the drop bracket.
I've got a TruTrac in my nova with a GM 10 bolt.....that thing is AWESOME for racing!
I've got a shop in Harvey, we can do it in a weekend if you want. Even if I'm not getting the 2wd transmission, my shop is open to other Comanche owners. I think I even have a spare AX-15 crossmember laying around somewhere.
I don't know, the holes in the wall of my last shop made me chuckle after I calmed down....how you gonna let an old truck, made by Mopar of all people, get the best of you?
You ever find one? I've got a 4wd AX-15 I would trade for a 2wd AX-15
Where are you located? I've got some fender flares I was holding on to.
Why is my eagle overheating?
Tex06 replied to eaglescout526's topic in MJ Tech: Modification and Repairs
Glad ya got it sorted. In the age of FI and even direct injection, we forget that there are other contributors to problems! -
Following, would take a set for my '92.
I had issues with housing clearance with the thick gears and when I called Eaton they said it was not uncommon and they don't recommend thick gearsets. Had similar issues with my aussie locker up front in the Dana 30 and had to purchase a new carrier for standard thickness gear and new gears for front and rear (4.10:1, my MJ came stock with 3.07:1).
Did you ever replace the radiator or get it serviced? -
The Detroit Locker I used specifically will not work with thick gearsets. Didn't look at E-Lockers.
Missing and Holding at 20 mph then fine?
Tex06 replied to fiddlermj's topic in MJ Tech: Modification and Repairs
Fuel or spark. Checking pressure and condition of the spark plugs would be my first go to....can you get it to misfire in park by revving? If so, pop the hood at night and see if the plug wires have any electrical leaks. -
Keep us updated with pics, I've got a set of fold forward XJ seats from a 2-dr that I'm going to be putting in (hopefully this year).
Chiming in since I did this a couple years ago. Thick gearset works fine unless you are trying to go to a locker (I went with a Detroit on the 2nd go around instead of limited slip). 3.07 was my gearing,I still had the tag on the axle. You can also just chock one wheel and count the turns of the driveshaft, 3 vs 4 for one rotation of the wheel is pretty easy to tell. Thick gearsets don't have any drawbacks that I'm aware of, actually made the rebuild easier the first time since the shims were really really close.
