john.silm
    Central NC
john.silm's Achievements
  1. Woah! That rebuild kit is way cheaper than what I was looking at. Thanks for linking it. I will definitely snag an extra 1/2 synchronizer and start the rebuild this summer...
  2. Sounds good, I'll look into it... I appreciate your help with this!
  3. Thank you for your input... any quality concerns about the rebuild kit for rock auto vs novak vs _____? is it worth spending almost double the price on the novak kit? I am on a pretty tight budget but don't wanna buy junk. https://www.novak-adapt.com/catalog/transmission/transmission-parts/ax15-parts.html
  4. Hey All! My 4wd ax-15 is on its way out and I found a nice 2wd ax-15 at the junkyard for under $200. I have read that the spline counts are different (4wd 23 ; 2wd 27), but I am under the impressions the tail housings are interchangeable and want to make it work because a transmission rebuild kit is $400 from Novak. My question is if anyone has any thoughts about making it work... perhaps a new input shaft for my 231? Sorry if anything in this post is off, I am a bit new. Something along these lines... NP231/233 Input Shaft, 27 spline, '88-'94, Wide Bearing; Part # 17191
  5. Thanks for the reply. That was my first thought as well but I went through it this afternoon and it all looked ok. The only thing out of place was that it was missing was the side marker bulbs. Will replace soon but I doubt that's the issue.
  6. Hey all! Long time lurker, first time poster here. I recently acquired a 1991 jeep comanche and am sorting through its electrical problems. The main one I am concerned about is that when I turn the headlights on, the driver side headlight stays off and the driver brake light turns on instead. it stays solid and is not overridden by turn signals or hazards. The driver headlight is functional with high beams, but the driver brake light still stays on. Another one is the hazards blink aggressively fast and turn solid when the brakes are pressed, and the reverse lights do not come on despite new reverse lights. It is worth mentioning I am using LED headlights and have a front end faceswap. I already checked the taillight ground, replaced the bulbs with the appropriate ones, and there are no hacked in trailer harnesses that I can see. Any help would be greatly appreciated
