what did you do to your MJ today?
JeepcoMJ
Took the throttle body off to clean it. Found that one of the IAC bolts was loose, causing a slightly elevated idle. Cleaned it up and made sure all bolts are tight. It now idles nicely and maybe it'll improve my MPG, which has gone down lately.
removed the cad and reinstalled it 3 times using several methods to lock it over, none will get rid of the ratcheting sound, finally locked the cad to the unlocked position and fixed the sound issue... installed some small fog lamps
Eva helped change the thermostat and the housing, then taught her how to drive a 5 speed. while we where out on some back road we turned around at the only spot that was available, it was a small patch of grass maybe 20' by 30'.. then this old couple drive up and fuss at us saying we are trespassing on privet property and we need to leave.. well that spot is the only spot on the road to turn around, sora need to trespass to leave... and if you don't want people trespassing put up some signs that state NO TRESPASSING and or put up a fence.. the road we where on was a old county dirt road with maybe 4 houses on it.
We had a sudden snowstorm saturday night, like 16" lost power on saturday just got it back sometime last night
Woke up on sunday to this.
Tree snapped off like 25 feet up. Nothing terrible damage wise, but going to see if I can get any insurance money.
changed the transmission oil lastnight and managed to get some black stuff on my arm... Dish detergent, hand soap (x6 washes), gojo (x3), bar soap, and body wash will not remove it...
The only non caustic hand cleaner I've had good luck with is GOOP Hand Cleaner. It can also be used as a spot cleaner on fabric.
