Everything posted by relyt120
anywhere but chuys :ack:
89 Mj 2Wd To 4X4 Conversion Questions
relyt120 replied to Manche_Base89's topic in Member Projects: Your Comanches
4x4 requires at least the transmission, transfer case, 4x4 front diff/axle, front drive shaft, shorter rear drive shaft, shifter/linkages. This is assuming the two trucks are matching in transmission type. you should be able to use the 87 mj parts in your 89 but the 87 may have a less desirable transmission (especially if it is manual). Really not enough info to say if the 87 is worth 1000 or not, pics help. good luck, others will chime in. -
http://driveev.com/jeepev/home.php
I think I have what you want in gray
:needpics:
I'd like in on this action too, how much we talkin?
That's the fuel pressure regulator, you need a new oring and maybe a spacer. I've only ever gotten them from a replacement part from advance, someone else may have a better source for just the oring.
light blue on light blue :drool: also grill is upside-down :ack:
Broken Odometer...anyone Know How To Fix?
relyt120 replied to Rohls's topic in MJ Tech: Modification and Repairs
The quick and easy fix would be to just grab one (a cluster) out of an HO(91-96) Cherokee and swap it in. They are plentiful and with no speedo cable in the HO gauge cluster they are simple to swap. Though someone may be able to chime in with a more technical answer; to me any fix is going to require removal of the thing and if you already gotta remove it you may as well throw a replacement in and skip all the hassle of messing with it and hoping that it ends up working. -
Cummins B3.3 Powered Mj Build!
relyt120 replied to krustyballer16's topic in MJ Hardcore Tech: Epic Journeys to Greatness
:drool:- 299 replies
- diesel
- cummins 3.3l
(and 1 more)
Tagged with:
Hayduke's Operation Comanche Repower - 88 To 98 Swap
relyt120 replied to GHayduke's topic in Member Projects: Your Comanches
What is the diameter of that tube ur bumper is made out of? -
:agree: All day everyday Shoot, I broke 3 bolts and the thing still didn't leak with the felpro, and I was able to reuse it after I changed the head gasket.
Got around to installing some red fenders and headerpanel i picked up for this guy, still need to install that new mirror, also need to paint the fender flare for the driver's side so i can install it! Slowly this thing is becoming less yellow/black and more red all over :yes: Oh yeah! I also picked this up for it! I may need to notch the bumper to mount it but it will look sweet!
that mat looks really good all cleaned up!
http://www.jcroffroad.com/mm5/merchant.mvc?Store_Code=J&Screen=PROD&Category_Code=XJB&Product_Code=DIY-MJ-R
Receiver Hitch/bumper
relyt120 replied to Jeep Driver's topic in MJ Tech: DIY Projects and Write-Ups
I like it. -
Cooling Fan Electrical '90 4.0
relyt120 replied to TNCave's topic in MJ Tech: Modification and Repairs
the temp switch for the fan is in the radiator and it switches on a relay , also the ac activates it too. Many people wire up a relay and switch to the dash to manually control the fan if they don't want to deal with fixing the factory wiring. Furthermore, if you ever swap a renix radiator it is common that the replacement won't have the bung hole for the fan switch so some people get an HO t stat housing and run a switch there instead. I like the manual switch myself. good luck! -
You should be able to run a full size "spare" on your hoist. I would just mount a tire on a spare rim and call it a day. Those temp tires are crap anyway.
That may have been me :oops: I almost got that tailgate so don't complain! lol if you need anything let me know I have a bunch of stuff shoved in my garage. ps: nashville pull-a-part right?
More TN people, what joy! a few of us meet up sometimes please put a correct taillight on the drivers side that thing is killing me!
got this one from auto zone for mine, fits like a glove! http://www.autozone.com/autozone/parts/Walker-Exhaust-Pipe/1989-Jeep-Comanche-2WD/_/N-ihexuZ9iyc8?itemIdentifier=287159_245476_5164_
New To The Renix: Safety Maintenance
relyt120 replied to MoeBoy's topic in MJ Tech: Modification and Repairs
:rotf: jim is such a smart alec -
You shouldn't need to get it to 5k rpm, I've never purposefully gotten my renix 4.0 to 5k rpm during normal operating, even on the highway. Always a good place to start:http://comancheclub....ers-renix-tips/ -
JEEP - Commanche (Global) - Rear - Open - Dana 44, 30 Spline --$229
