87MJTIM
    9
Everything posted by 87MJTIM
  1. One more post and the classified will open up to you.
  2. I don't have an auto. The 88 electric manual labels it the "Gear Selector" switch, but I think its the same as a NSS. The TCU reads when the trans is in N or P. Don't let the wiring scare you. If you haven't downloaded the 88 electric manual, you should do so. Print out the pages for the wiring you a researching. Study it. Get under the truck and examine the wires and connectors carefully before taking things apart. In simple terms: electricity flows from a power source (Bat +) through wires and connectors, to a switch, to a load (like a light), then to a ground (Bat -). The switch will either close the circuit - allowing electricity to flow to the load (light on) - or open a circuit - breaking the flow (light off). When the trans is shifted in to reverse, the switch closes allowing electricity to flow to the lights. That's why I have you test the electric at the connector feeding the switch. If you have Bat + in to the switch, but not coming out of the switch when KOEO in reverse, then the switch is bad or just dirty from 40 yrs of dirt. If power is coming out of the switch then the issue is further down the line. Use the wiring diagram to assist with tracing the wires.
  3. The last picture is the gear selector switch. The rev. light wires run through that connector. Unplug the connector and test power on the engine side of the connector. It should be a Black/yellow wire, pin A. (The wire is Yellow on the switch side. ) Test for power on the engine side with KOEO. Power runs back to the lights first through a White/Black on the switch wires then to a Brown/white on the engine side - pin E. Keep working backward until you find where the power stops.
  4. Crawl underneath the truck. Locate the switch screwed into the trans. With KOEO, use a test light to check for power getting to the switch (black/yellow). Put the trans into reverse. Back probe the wire coming out (brown/white?). Does the test light lite up? If not, replace the backup switch. If you have power in, the check for power back. From the rear, locate the wire coming the back (brown/white). It you have power at the rear, then check the light and the sockets
  5. First things you should do is read through Cruiser54.com and perform most of the procedures. At least, perform all steps necessary to get it running. The stopping once you let off the gas may be the idle air control valve. This is located on the throttle body. It may not be opening properly. Try cleaning it with Throttle Body cleaner before throwing more parts at it.
  6. That’s the CC clutch switch. The metal tab inside the connector is a jumper since yours is an automatic.
  7. Seat belt mechanism - unique to MJ
  8. There’s already a thread running on this.
  9. …fuel pump and sending units…
  10. Take a trailer and get the 87. From the XJs, what are the years of each? If they're 86-90, then start grabbing common parts to the MJ. If 91+, the engine parts swap would match if you have 91-92 MJ. If there is a 2 dr XJ grab the front seats. These tilt forward. Other may (will) add more.
  11. Following Henry Ford's option model: Any color you want, as long as it's black.
  12. Not really speaking to me. Not a fan of the black cases. Different color options?
  13. Not CC related. There are no relays for the CC system.
  14. Is the fuel rail bent?
  15. Selling some? How much?
  16. If you have already done so, go to Cruiser54.com and perform the Mostly Renix Tips. Since you most likely unplugged and unhooked all the sensors and hoses, just go back through all the procedures again (and again) to verify you put everything back correctly. If everything is installed correctly, then start testing sensors. Another good website for the Renix sensors is Lunghd.com.
  17. Is the old o-ring still inside the port? Pull the fuel rail/injectors and shine a light inside a see if there is anything in the way.
  18. Ok. How about the radio/LED clock display relay C354? The location and wire colors appear to match. p. 59 of the 88 electrical manual.
  19. #3 the blue box is the seat belt/key/light buzzer. #4 the blue box is the horn relay. #5 is the transmission control unit (TCU) #7 is the heater vent
  20. There is a weighted pendulum that activates the locking mechanism. Tugging on the belt doesn't always cause the pendulum to move enough to trigger the lock. You could try parking on a downhill and tugging or driving slowly and step on the brakes.
