Everything posted by Salvagedcircuit
My comanche's been a pretty great lil vehicle. The engine sounds good and idles smoothly at ~800rpm. The AW4 transmission seems to shift without issue and I'm pretty happy with it. I just replaced my muffler, tail pipe and window guides so the cab is quieter than ever. However, I am noticing a thudding sound whenever I initially accelerate from stop. It's not particularly loud and does not occur with gradual acceleration. Only when I'm putting my foot to the floor when accelerating from stop. I put a gopro under my comanche and recorded the drivetrain a few times. There is a bit of movement in the yolk, but that may be normal. Oddly, the gopro does not seem to pick up the thudding sound in audio. The thudding sound is a 3 to 4 knock on hard acceleration and then vanishes. It's completely gone after initial acceleration and does not occur when accelerating from 20-->30 or 30-->60, just the initial acceleration. I originally thought it was my speedometer cable, but it does not change with speed. I don't know what's causing this. I replaced the fluid in my transfer case 3 months ago. I replaced the coolant lines to my transmission since one was misshapen, I added transmission fluid to compensate for loss when removing my transmission lines. I replaced the transmission and engine mounts. I just greased the yolk fitting as well as the front / back drive shaft u-joints. I greased one u-joint in the double cardan joint as the other requires me to remove the cross member to grease. Edit: I looked back through the videos and noticed my muffler is moving a bit. I didn't tighten it down super tight because I didnt want to deform the pipe. It's a pain to remove when the pipes are dented and rusted together. I guess I'll have to tighten them down. Any ideas welcome. Thanks a ton guys!
Headliner Mounting procedure?
Salvagedcircuit replied to Salvagedcircuit's topic in MJ Tech: Modification and Repairs
This is good to know! I did not have plans to put sound deadening on the inside roof. Tryin to keep my center of mass on the wayyy low Gotta put the sport in sportruck -
August 2024 - Project Scuzzy
Salvagedcircuit replied to 89 MJ's topic in Comanche of the Month (MJOTM)
Nice job! A lot of great guides in that build thread. Well deserved! -
That's not a bad idea! I ended up velcro-ing the front dash carpet the other day and it came out excellent. I don't see why it would not work there. -
My MJ was missing a headliner. I eventually found one and installed it. However it seems the center rear sags a bit and obstructs the rear glass about 1in. Is this normal? The headliner was not creased or cracked. The rear b-pillars are the only thing that hold in the headliner in the back. Is there some bracket I'm missing? In the photos below I'm holding up the center with my hand in a before / after.
Front Fender Braces, Wheel Well Fender Flare Brackets
Salvagedcircuit replied to Salvagedcircuit's topic in Wanted
Thanks for the input guys. I found what I needed. -
Some mighty fine work there. Nice job
Looking for: Both Front Fender Braces, Wheel Well Fender Flare Brackets. They look like the attached images. I have the fender flares, just not the brackets.
Nice work! I just grabbed a pack of front grill wiring harness clips from aliexpress. I'm hoping they fit, they look close enough. Makes it far less fiddly when reassembling the front end. Otherwise the wiring loom gets pinched between the lower radiator and fiberglass front.
That makes a lot more sense now. So I either take the sending unit from an official 23.5gallon fuel pump, or I somehow bend the float arm or modify mine to work with a different fuel level.
Based on what @smokey found, I believe I have the same situation he has, a 23.5gal-limited-to-16gal tank. What I'm curious about is if I can continue to use my current fuel pump in the tank if I shorten the filler and overflow tube. Wouldn't I need to change the float arm height? Isn't the pump and sending unit one assembly?
There are 3 straps
Thread revival! I have a base model long bed comanche with a 16gal tank. If I grab a new 23.5gal tank, can I just reuse my old fuel pump? I checked MTS pumps and they only list one style fuel pump for the comanche: JPSU-6P4.0 I'm also considering removing my fuel pump and reducing the length of the filler and overflow tube like @smokey did. Instead of cutting an access hole for a sawzall, I think I may just be able to fit my arm in there and swing a small diameter and large diameter pipe cutter. Thanks!
If the fuel was bad, maybe replace the fuel filter. It's easy to get to and cost $3 from rockauto.
Nice! sometimes rockauto really delivers
1987 Comanche Pioneer Restomod
Salvagedcircuit replied to 996xj's topic in Member Projects: Your Comanches
Nice work! Also, finding a Mishimoto radiator in the JY - the Jeep gods must have been with you that day. Dang! -
aww yeah
Operation Comanche Chief Otter
Salvagedcircuit replied to js33rd's topic in Member Projects: Your Comanches
Looking good! Nice work! -
I have had success with the Grote 44891 2 Pin Flasher with separate GND wire. It clicks louder than my stock thermo-electric flashers which is nice. I grabbed one from advance auto when I was diagnosing my strange flasher issue. Another alternative is the one from @OffGridResearch which is available here.
I believe @schardein was one of the first to detail the use of the S10 Blazer lights as replacement MJ B-pillar lights on CC. I purchased a pair from him and a pair of the Euratech lights. The Euratech lights have an inline diode so the lights can work independently. The blazer lights are missing the diodes and both would turn on simultaneously whenever one was switched on. Not ideal. Here's some photos of adding the inline diode for anyone who goes this route. A 1N4004 silicon diode will be more than enough to do the job. The wiring diagram from the Euratech lights is there for reference.
My lower dash was cracked in multiple spots from the previous owner's sloppy CB radio install, but after the plastic welding it's nice and straight. The hairline cracks give it character lol. I've read a bunch on here about people having luck with SEM paints. Cool. I think I just got lucky that my door cards cleaned up with melamine / mr.clean eraser. Nearly all the marks vanished and the melamine left no residue or staining. I covered up the botched speaker hole with slightly larger 5.25in Goldwood metal speaker grill covers and the result is pretty clean. They clear the window cranks and take some abuse when my foot accidentally hits them, which works for me. I'm definitely going KJ liberty rear axle purely because they are slightly wider to match up the front / back wheel tracks, have the complete disc setup and have the same rim bolt pattern. I previously purchased the ~$800 teraflex disc conversion kit for D35 / D44 and after looking it over, it was not worth the effort, especially on earlier non C-clip axles. I returned the kit. This thread was very helpful to me: -
Woah what an update. Nice job on the dual diaphragm booster + master. That is the best bang/buck combo In terms of the cracked grill, I have had some great success plastic welding broken plastic parts with a soldering iron and stainless window screen mesh. I attached some photos. a simple 70w soldering iron is enough. The mesh just melts into the back in a few seconds. It isn't going to make the crack seam on the front completely vanish, but it greatly closes up the crack and prevents further damage. The repair is also unnoticeable from the front side. Curious, what did you use to refresh the door cards? The rear axle welds look nice, reminds me that I should finally grab that rear axle from the manual liberty at my nearby junkyard. Rear discs hubba hubba hubba. -
I was passing through Connecticut today on 8/5/24 and there was a small car show on the side of the road. Someone had a lowered gray Comanche that looked badass. I forgot which town it was in. I think it was this dude's: https://www.instagram.com/johnsharkey/p/CvVw8BCr9AL/ I was in route to pickup a truck for my brother and couldn't stop :/
